  1. Sep 25, 2016 at 6:34 AM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    I started pulling things apart to fix a leaking water pump. The PO apparently F'd up the install and the seal blew after 30K mi... all the belts still look new. I'm still going to replace them all and do a few extra things while I'm in there. This is the first time I have dug this far into a motor on my own. It's been an interesting experience so far and if I ever have to do this again it will go MUCH faster...
  2. Sep 25, 2016 at 7:23 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    I was just wondering. For someone that would want to piece together their lift one piece at a time rather than buying everything at one time.
  3. Sep 25, 2016 at 7:37 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Yeah, the way you clarify here is how I understood your question as well. I don't see a lift being mandatory to be able to run the uniball UCA's. And if the ride height remains untouched, I can't see an alignment being necessary either. This may be off, just sharing my thoughts as I think about it. I'm not speaking on experience. I'm sure others here understand this better and have much more experience with this than I do.
    A decent point you bring up, as this would allow you to escape the possibly detrimental effects of running the stock control arms and ball joints. Hmmmm...
  4. Sep 25, 2016 at 8:13 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    The uniball ucas usually have more caster and change the camber to something more suited for a few inches of lift.
  5. Sep 25, 2016 at 9:02 AM
    cruiserguy
    Elijah
    SEKS
    Oh gotcha, so they're designed to accommodate the camber of an already lifted truck. Is there enough room on them to go backwards with the caster to get them into spec if installed on a non-lifted truck? I thought they were direct replacement and just allowed for more caster when needed. Thanks for the info.
    Edit : nevermind, the caster is built into the arms, right? Derp, don't know what I was thinking. Yeah I feel dumb, I got it now.
  6. Sep 25, 2016 at 9:27 AM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    No harm done, man. You have to get educated on this stuff somehow, right?
    DustStorm4x4 likes this.
  7. Sep 25, 2016 at 9:32 AM
    WinSlow939
    WinSlow939 Road Salt Life
    Nate
    The Rock, Mass
    2002 with some '99 thrown in for fun
    All the Money I Have
    I think my account got hacked, seeing some posts I didn't write... a little confused here o_O
  8. Sep 25, 2016 at 9:33 AM
    cruiserguy
    Elijah
    SEKS
    Lol, yeah, I guess, I'm new to the world of coil overs. My land cruisers have all been solid axled except for the couple 100 series I've owned. Even then, those had control arms but no struts. Shock and torsion bar set up. But regardless the principle of adjustment is all the same, just new terminology to learn, lol. And I guess new areas on suspension where the adjustments take place.
    jubei[QUOTED] likes this.
  9. Sep 25, 2016 at 9:33 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    :drunk:
    Deathbysnusnu likes this.
  10. Sep 25, 2016 at 9:36 AM
    WinSlow939
    Nate
    The Rock, Mass
    :anonymous:
  11. Sep 25, 2016 at 9:44 AM
    WinSlow939
    Nate
    The Rock, Mass
    Disregard my postings last night I have no idea what happened, sorry :oops: What I meant to say was thats awesome you got it done!! Glad the pipe method worked out and you didn't have to pay a ton to get fixed :) And the learning experience is the best part!
    BYJOSHCOOK[QUOTED] likes this.
  12. Sep 25, 2016 at 9:47 AM
    jwhyota101
    jwhyota101 Member
    jonathon
    1996 3400 four cam
    Just tires for now and a start on a Kevlar bed liner paint job
    Just installed tube style bumper. This is my first bumper build
  13. Sep 25, 2016 at 10:03 AM
    jubei
    NoCo
    Stuff. Also things.
    Beefy!
    jwhyota101[QUOTED] likes this.
  14. Sep 25, 2016 at 10:38 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Ha no problem! I too was :drunk: so I understood what you were trying to say :rofl:
    WinSlow939[QUOTED] likes this.
  15. Sep 25, 2016 at 12:12 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Where's the best place to buy heavier rates replacement springs for my kings? Id go look but I (comes up with good excuse)
    Fernando likes this.
  16. Sep 25, 2016 at 12:28 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    DSM
  17. Sep 25, 2016 at 12:33 PM
    jubei
    NoCo
    Stuff. Also things.
    Truthiness.
  18. Sep 25, 2016 at 12:39 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Im thinkin of a heavier coil as well
  19. Sep 25, 2016 at 1:00 PM
    cruiserguy
    Elijah
    SEKS
    I changed the engine oil. After reading all the posts about discrepancies on the fill quantity, I paid a little more attention to the change. This is my first oil change since taking possession of this Tacoma. The dipstick showed oil over the full line. I'd estimate a half inch or so higher. 6 quarts came out. The PO had the previous oil change done at a lube shop(sticker on windshield). The oil filter was the Napa equivalent of the OEM filter, so same amount of oil as the filter going in. I put in a jug of 5qt Mobil 1, 0w-40 European spec(same oil Porsche uses from factory). The oil is very fairly priced at Wal-Mart, I think it was 22 bucks. Also not looking to get into a pissing match about the brand oil, lol. Everyone should just use or continue to use what you feel sufficient or best, I will too, lolol. After the change the dipstick marked almost exactly halfway between the full and low line. I'll likely pick up a quart of the same oil and fill it to the full line. I'm stating this only for a data point. I don't know if anyone is even keeping track of this oil stuff anymore. Anyway, it's done.
    ClevSix and because_wumbo-truck like this.
  20. Sep 25, 2016 at 1:04 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    You used 0w-40 and not 5w-30?
    devinzz1 and Adventurer_Alex like this.
