  1. Sep 28, 2016 at 12:02 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Recent weekend carnage.
    UssMoGn, jjsul and Speedytech7 like this.
  2. Sep 28, 2016 at 12:04 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Looks good! What did ya scrape on?
  3. Sep 28, 2016 at 12:09 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Debating on doing synthetic oil change or stick with dino. 190K miles.
  4. Sep 28, 2016 at 12:12 PM
    TashcomerTexas
    My bumper skidded against a tree. And my rear had a boulder hitched between the leaf spring shackle and the trailer hitch. Not ideal in pitch black lol.
    Speedytech7[QUOTED] likes this.
  5. Sep 28, 2016 at 12:16 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Time for a wrap around rear.
    WinSlow939 and Chipskip like this.
  6. Sep 28, 2016 at 12:19 PM
    TashcomerTexas
    Yes sir. High clearance to be exact.
    Silver02Taco likes this.
  7. Sep 28, 2016 at 12:59 PM
    Speedytech7
    6 of one, 1/2 dozen of the other. If you have normal and not extreme change intervals it will make zero difference. I change my dino oil out every 4200mi and it comes out nice and clean, haven't had a Blackstone test in a long time but last time it was all bueno.
    Boerseun likes this.
  8. Sep 28, 2016 at 1:00 PM
    PROseur
    Pussy
    I do 5K intervals
    90% highway. 10% city.
    At 5,000 mile interval, DINO is still nice and golden.
  9. Sep 28, 2016 at 1:03 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    No need for a high clearance rear bumper on our trucks unless you really just like the look. A wrap around bumper will hide that corner damage just fine.
    jubei and Chipskip like this.
  10. Sep 28, 2016 at 1:03 PM
    Speedytech7
    It's probably not worth the extra cost for full synthetic and a synthetic rated filter then. Send an oil sample to Blackstone labs and see what they say, if the Dino oil your buying has a good additive package and doesn't shear down too easily you may be able to run it longer and they'll tell you that.
  11. Sep 28, 2016 at 2:27 PM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    I like synergic for those -40 morning here. But if I lived where it's always warm I wouldn't bother
  12. Sep 28, 2016 at 3:53 PM
    TashcomerTexas
    Yeah but I want it.
    because_wumbo-truck likes this.
  13. Sep 28, 2016 at 4:35 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I disagree.
    If you say high clearance isn't needed on a 1st gen you need to wheel harder trails.
    My bedsides would be destroyed without it, nor would I trust a wrap around or be satisfied knowing it's an area you can gain clearance easily and hit often.
    malburg114 likes this.
  14. Sep 28, 2016 at 5:01 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I don't think it's nessiscary. The frame is lower and shackles are lower. You'll hit the bed sides regaurdless or shackle and frame first.
    No point in cutting them. Wrap around is plenty strong or just a guard tube under it.
  15. Sep 28, 2016 at 5:02 PM
    99SuperTaco4x4
    99SuperTaco4x4 Well-Known Member
    1999 3.4L V6 Tacoma, 4x4, TRD Supercharger
  16. Sep 28, 2016 at 5:13 PM
    Squeaky Penguin
    Brett
    The frame is not lower, and is also a foot inboard of the bedsides. What if you hit something from the side, and not down vertically? Frame won't help you there. I cut off quite a bit and the sides of my bumper are even with the frame.
    I'm not saying it's the way to go for most on here, but if you do any amount of serious wheeling and want the best clearance, cut the bedsides off, they're doing nothing for you.
  17. Sep 28, 2016 at 5:27 PM
    WinSlow939
    WinSlow939 Road Salt Life
    Nate
    The Rock, Mass
    2002 with some '99 thrown in for fun
    All the Money I Have
    I'm not even wheelin that hard and mine get beat up...stupid people in parking lots that dont know how to back out of a spot have hit my lower bedsides plenty of times for instance. I'm planning on trimming mine for the wrap-around bumper eventually too, but I agree it ain't for everyone :)
  18. Sep 28, 2016 at 5:28 PM
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    so whats the verdict on rear bumpers? I dont wheel hard enough, well havnt been true wheeling yet
  19. Sep 28, 2016 at 5:31 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    Prerunners need hc bumpers, but 4x4s are good with wrap arounds
    YotaOverAll likes this.
  20. Sep 28, 2016 at 7:28 PM
    CStoy
    CStoy mountain-top maniac.
    majestic gold 4x4... 1/4 million miles and counting!
    improved toyota goodness.
    put a set of bilstien 5100's set at 1.25'' and new OEM springs on the front today!
    and laughed at the "bro lean" because my front end sits at 5 1/2 inches above the sagging rear for the next 2 weeks till I get my deavers...
    ate some wheelers candy :cool:.
    jjsul and Chipskip like this.
