  1. Sep 30, 2016 at 1:18 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    :anonymous:
  2. Sep 30, 2016 at 1:28 PM
    TrailRider2002
    TrailRider2002 Well-Known Member
    Cameron
    Powdersville, SC
    02 Tacoma 4x4
    -3in old man emu suspension lift with 882 coils, nitro chargers and rear add a leaf -1in Daystar Body lift -295/75 BFG KO2'S -flowmaster dual 40s
  3. Sep 30, 2016 at 1:48 PM
    SeattleCyclist
    SeattleCyclist Member
    2001 Taco OR DCSB
    How was the fit of the weathertech front floor liners. It doesn't give an option on the doublecab. I just wanted to know how the extended cab version fits in the DC.
  4. Sep 30, 2016 at 2:12 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Make sure on the chassis saver to apply light coats. It works by attracting moisture which makes it get hard. If the coating is too thick you will end up with air bubbles all in the paint.
    Most importantly really rough up places that are smooth/ have zero rust. It will flake off if you dont. And get all the rust that is flacking/chipping off as well.
    2002Tacoma4x4 likes this.
  5. Sep 30, 2016 at 2:13 PM
    KeptOnChooglin
    KeptOnChooglin Well-Known Member
    Phil
    Houston, TX
    2003 Crew Cab PreRunner L4 Auto
    DO NOT ORDER THEM. That was a mistake by me.
    It was a fail.
    The back inside corner (base of seat nearest tranny hump) of the mats doesnt fit. That applies to both mats. The mats have a pretty regular squared off corner there. Meanwhile the DC is diagonal at that point.
  6. Sep 30, 2016 at 2:24 PM
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    What intake you got
  7. Sep 30, 2016 at 2:28 PM
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    @sente3 I would pop the debt out as much as you can and then think about doing some kind of stripe/decal to hide it.
  8. Sep 30, 2016 at 2:48 PM
    Cadmus
    Cadmus Un-Known Member
    Fort Collins CO USA
    '04 4door 4x4 TDRoffroad
    Thanks. Yeah the instructions say do not use a converter. Maybe it was all those years of my dad making me strip and paint steel hull boats.... I just feel compelled to use phosphoric acid. The acid is more for the hidden spots at joints or in box frames. I spray it, wait 4-8 hours, rinse, and if i see significant iron oxides in the rinsate I repeat. There are sections that had no rust and are pretty smooth. Most sections that had rust are rough or rough with small amounts of rust. I think it will bind well and as you advise i will do light coats. My fear is the hidden/blind spots like the top mount for the shocks or the joints of the frame that are boxed. I can not get in there easy and I fear putting it on too thick.
    The second half of this post was my plan:
    https://www.tacomaworld.com/threads/do-you-guys-think-this-is-too-much-rust.450419/#post-13202842
    You said i could pick your brain about Chassis Saver and I meant to send a slimmed down version of that post for your feedback. If you advise doing anything differently, I am all ears. Thanks, Pete
  9. Sep 30, 2016 at 3:07 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Volant. Nothing wrong with it but I want stock so I can get a snorkel down the road
    jubei and alee891 like this.
  10. Sep 30, 2016 at 3:17 PM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    I tried to get it out today. Can only get my fingers touching it front behind and heatgun/compressed air didn't work. It's a long dent and appears to have a crease. Not easy to undo. I put a claim in. So I'll see how that goes. I pay for insurance, I guess I may as well use it.
  11. Sep 30, 2016 at 3:21 PM
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
  12. Sep 30, 2016 at 3:21 PM
    LSC15
    Logan
    2008 TRD D-Cab
    I may trade
  13. Sep 30, 2016 at 3:45 PM
    JRinReno
    JRinReno Well-Known Member
    Jim
    Southwest Idaho
    After waiting over a year for probate to end---this week, I finally got the paper work from the lawyer, went to DMV and got my new plates and title (coming in the mail soon). So, once it became officially mine (it has 116K miles on it), I got all 4 wheels/tires balanced, new replacement Bilsteins, got the timing belt and tune-up (due at 120K) done, had all fluids flushed, replaced the air filter, got the CEL cleared/fixed (P404 code-had to drop the tank and replace sensor). Whew, that's enough for this week, eh?
    Next comes fluid changes in the diffs, T-case, and transmission---in a week or two.
  14. Sep 30, 2016 at 4:03 PM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
  15. Sep 30, 2016 at 6:01 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    :rofl: :rofl:
    I've always wanted one :rolleyes:
    Just let me know, I had a deal lined up but the guy never got back to me
  16. Sep 30, 2016 at 6:13 PM
    Tacomang
    Tacomang Well-Known Member
    Norcal
    Trd Taco
    Got my rebuilt alternator back. Had bad bearings.
    Still looking around for any info on building a sub box for a 2002 ext cab search got me nowhere
  17. Sep 30, 2016 at 6:50 PM
    LogCabins
    LogCabins Well-Known Member
    Robert
    Oahu
    99 SR5 3.4L 4WD
    What size sub?
  18. Sep 30, 2016 at 7:55 PM
    Tacomang
    Norcal
    Trd Taco
    Probably just a 10. Was looking at under the seat options but those arent true subwoofers
  19. Sep 30, 2016 at 8:00 PM
    LogCabins
    Robert
    Oahu
    99 SR5 3.4L 4WD
    I had a single RE Audio 10 before but like you didn't want a box using up one side of the extra cab so I went with this http://xfireaudio.com/index.php/subwoofers/xfr-subwoofers/xfr6-44 with this under the passenger seat http://xfireaudio.com/index.php/amplifiers/efx-amplifiers/efx1000-1 and believe me this little thing is great....people trip out when they hear it and then see how small it is. I had a ported box built that fits in between the extra cab jump seats, so they are both still useable
  20. Sep 30, 2016 at 8:03 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    once upon a time there a was a guy trying to sell fiberglass boxes to hold a 10" behind the console. when i get a chance il make one for 2 8s instead of my ridiculous 15" setup.
