  1. Mar 3, 2012 at 9:02 AM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    Played a little in the snow/slush/rain.....:rolleyes:
    After 8+" of snow we are now getting freezing rain quickly turning over to plain rain for the next 10-12 hours...:eek:..
    I have to be nice to the Tacoma....it is the only vehicle for the next 2-3 weeks...Camry sold and arranging the time to go "South" is frustrating....
  2. Mar 3, 2012 at 10:06 AM
    lonzorizo
    lonzorizo Well-Known Member
    Lonnie
    Hoopa, Ca
    2003 TRD OR, 2016 TRD OR Tacoma
    @ttran what is this other route you speak of?
  3. Mar 3, 2012 at 10:14 AM
    JoshM
    JoshM Active Member
    Franklin, TN
    1998 RCSB 4x4
    Well, this is what I'm doing today:
    All 3 belts
    Spark plugs
    Front rotors and pads.
  4. Mar 3, 2012 at 10:14 AM
    Jonyd182
    Jonyd182 What do you mean I can't go up there...Watch this!
    Jonathan
    Columbia, SC
    '99 SR5 TRD 3.4
    Armored to the teeth, 35's, Crawlbox, Boxed Frame
    x2
  5. Mar 3, 2012 at 10:20 AM
    ruler1
    ruler1 stump thumper
    palmetto fl
    97 2.7 4x4 5speed
    header, k&n intake, ome coils, springs and struts,diff drop, Urd simulator, dynomax exhaust, slotted roters, bpv relocater
    Just seafoamed my truck. Holy crap at the smoke show. I'm guessing it was the first time it's been done and I'm almost at 160k
  6. Mar 3, 2012 at 11:04 AM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    what LEDs are these
  7. Mar 3, 2012 at 11:21 AM
    JSFoster75
    JSFoster75 Well-Known Member
    Scott
    Bluff City, TN
    2018 Wrangler JLU Sahara
    Too many to list.
    Now that's a big canoe, mine is really wide, it's the Coleman Scanoe with a transom on the back for up to a 4hp motor. I use a 40 lb. thrust trolling motor though... I think mine is rated to hold just over 900 lbs....
  8. Mar 3, 2012 at 11:34 AM
    atvlifestyle
    atvlifestyle Well-Known Member
    Michigan
    01 trd tacoma
    supercharged with MCM front kit
    Not sure. They have been talking about them in the long travel BS thread and they are cheap. Figured worth a try. The store belongs to a member on here.
  9. Mar 3, 2012 at 1:19 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
  10. Mar 3, 2012 at 1:27 PM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    Added a thule moab and extension to the top.
  11. Mar 3, 2012 at 2:25 PM
    B ryan
    B ryan Well-Known Member
    Bryan
    Washington
    '00 3.4 sr5 4wd
    K&N intake, Flow series exhaust, bfg all-terrains, Line-X bed liner, 2.5'' leveling kit, diff drop(just to be safe), hard wired inverter, Delta tool box, high lift mounted in bed, Jerry can mount for in the bed, spidertrax wheel spacers, all-pro rear bumper, gray wire mod
    I see that you had to cut your frame rails to get your bumper on. How many inches did you have to cut off of them? I ask cause I've got one in the works from Tim and was wondering how it turned out for you. I think it's like 4" or so. Did you have to do a lot of trial and error to get it to fit right? Any install advise you got? Did I ask enough questions?
  12. Mar 3, 2012 at 2:37 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    Installed the new 882 coils this afternoon, truck sits nice and level and rides very nicely now.
    Anyone want to buy a used sets of 881s?
  13. Mar 3, 2012 at 2:43 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Pics?
  14. Mar 3, 2012 at 2:45 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Was about to say the same thing.
    :worthless:
  15. Mar 3, 2012 at 2:52 PM
    JDMcQ
    I did not take a before shot, but I gained about 2" on the shop floor.
  16. Mar 3, 2012 at 2:55 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    Took the truck up in the hills to find some antler and totally wasted the day yesterday cleaning it becaus eit is filthy now...
  17. Mar 3, 2012 at 3:07 PM
    Jonyd182
    Jonathan
    Columbia, SC
    '99 SR5 TRD 3.4
    Not a problem, I had the same questions.
    It was a straight shot after I took a few measurements.
    The pic below should help. I took just over 3" off the front and the center of the bolt hole is 2.5 from the mounting point on the bumper. I probably took about 1/4 inch too much off but I'll have that filled when the new frame ends are welded on.
    I'll also send you some instructions that I have from another member.
  18. Mar 3, 2012 at 3:40 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    How do you think the 882s would ride on my stock double cab? I want to go with those instead of 881s because I see a plate bumper in my future, but that won't be for a year or two after I lift...So would running the 882s without any extra weight be bad? Or would it just be a stiffer ride?
  19. Mar 3, 2012 at 3:51 PM
    JDMcQ
    Might be a little high and stiff, but I am sure you can live with it. I had the 881s for two years and loved them. I swapped them out when I got 285/75/16s and the heavier bumper on the front. It is not a huge deal to swap out the longer springs when you get your bumper. $160 in parts and a quick install.
  20. Mar 3, 2012 at 3:58 PM
    ffirg
    mike
    Anchorage, Alaska
    Hmmm, well that's good to know. Maybe I'll just settle for the 881s to enjoy the ride for a while. Besides, I would be taking the front end apart anyway to install the bumper so I might as well just do the springs at the same time.
