  1. Oct 8, 2016 at 12:01 PM
    shelby0808
    shelby0808 Well-Known Member
    Shelby
    Georgia
    2004 toyota tacoma
    i was under lighting. :facepalm:
  2. Oct 8, 2016 at 12:02 PM
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    off light bar topic but...
    I thought these billit ucas were only made for 05+ ??? :eek:IMG_4196.jpg
    shelby0808 likes this.
  3. Oct 8, 2016 at 12:02 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Icons. Think you can still get them. But idk.
    snowboard704[QUOTED] likes this.
  4. Oct 8, 2016 at 12:03 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    that a v8 in there?
  5. Oct 8, 2016 at 12:04 PM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Yea not sure either, first time I had seen them on a first gen
  6. Oct 8, 2016 at 12:10 PM
    Tacofart
    Tacofart Well-Known Member
    Brennan
    San Diego
    04 3.4 4x4 Dual cases/ Lockers
    Yes the Marlin 4.7. Not sure exactly. Bought the truck with it on, then 1k later it's toast.
  7. Oct 8, 2016 at 12:29 PM
    shelby0808
    Shelby
    Georgia
    2004 toyota tacoma
    what is taco box
  8. Oct 8, 2016 at 12:37 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    crawlbox. Dual transfer cases for double lo range
  9. Oct 8, 2016 at 12:51 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Lol the only thing that is probably remotely close to that is that one guy's "economic" t100 build with the makeshift trailer.
  10. Oct 8, 2016 at 1:05 PM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    IMG_4202.jpg:spy:
  11. Oct 8, 2016 at 1:08 PM
    devinzz1
    devin
    2023 aclb trd or mt
  12. Oct 8, 2016 at 1:13 PM
    TashcomerTexas
    Dude probably drives like a senile grandma.
    TacoVio likes this.
  13. Oct 8, 2016 at 1:42 PM
    shelby0808
    Shelby
    Georgia
    2004 toyota tacoma
    :bowdown: my kinda taco box
    pittim and snowboard704[QUOTED] like this.
  14. Oct 8, 2016 at 1:46 PM
    Phessor
    Phessor Well-Known Member
    Bob
    1998 TRD XTra Cab
    Stuff
    It may be a stupid question, but what all do the wires go to? I cant get the dash lights to work with mine.
  15. Oct 8, 2016 at 2:45 PM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
  16. Oct 8, 2016 at 2:56 PM
    shelby0808
    Shelby
    Georgia
    2004 toyota tacoma
    anyone wanna come fix the little light on my gear shift? :rofl:
  17. Oct 8, 2016 at 2:58 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    If you were close by maybe. It's not too bad. Just gotta unscrew 4 screw iirc to remove the shifter console then twist the light out and pull
    shelby0808[QUOTED] likes this.
  18. Oct 8, 2016 at 3:06 PM
    shelby0808
    Shelby
    Georgia
    2004 toyota tacoma
    awww. thanks. can i buy the bulb at a parts store or is it one i have to get from toyota?
  19. Oct 8, 2016 at 3:10 PM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Looking for some additional info regarding the 60,000 mile regular maintenance interval for my 2002 3.4L V6 4x4 5MT extended cab.
    Any thoughts?
    - For the coolant, I'm planning on going OEM.
    - I'm planning on using the OEM oil filter, and synthetic 5W-30 oil. Also going to be installing a Fumoto valve and lock.
    - Diff oil has been replaced recently after regearing. Using Lucas 85W-140, per ECGS recommendation.
    - New tires were installed recently enough to start rotation at next oil change.
    - Currently running a K&N CAI until it gets replaced with a stock air box and snorkel.
    - How does one know if one is running a non-platinum spark plug? I'm planning on replacing with OEM if they need to be changed.
    - Can I run an NLGI-2 grease such as Lucas X-Tra Heavy Duty grease for all of my chassis zerks?
    - What are your recommendations for transmission and transfer case oil(s)?
    - What are your recommendations for belts? OEM? I'm using this as somewhat of a baseline service since this is the first major service since I bought the truck and I have no idea if the PO took care of anything more than oil changes.
    - When the owners manual references the 'propeller shaft bolt', are these the bolts connecting the driveshafts to the pinion flanges, or are they specifying the pinion but itself?
    Thanks in advance, you guys!
    ETA: Sending out the Bat Signal!
    @BDN @Squeaky Penguin @Blackdawg @alee891 @TMFF @Robmonster117 @cynicalrider
    Thanks, fellas!
  20. Oct 8, 2016 at 3:11 PM
    devinzz1
    devin
    2023 aclb trd or mt
    its a standard size. you can replace yourself in a few mins with a phillips and a 10mm socket.
