  1. Oct 8, 2016 at 3:12 PM
    shelby0808
    shelby0808 Well-Known Member
    Shelby
    Georgia
    2004 toyota tacoma
    sub'd to this because apparently im a terrible truck owner because i do none of this.
    Bennett707 and jubei[QUOTED] like this.
  2. Oct 8, 2016 at 3:13 PM
    shelby0808
    Shelby
    Georgia
    2004 toyota tacoma
    carry both of those in my door. thank you. i dont know much about truck stuff. i am learning.
  3. Oct 8, 2016 at 3:14 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    You can get it at a parts store. I can't recall the number though. I know it's the same as the climate control lights on the 98-00 taco
  4. Oct 8, 2016 at 3:15 PM
    shelby0808
    Shelby
    Georgia
    2004 toyota tacoma
    youre the man!
  5. Oct 8, 2016 at 3:17 PM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    I wouldn't say that you're a terrible truck owner.
    I'm just more of an OCD truck owner :D
    shelby0808[QUOTED] likes this.
  6. Oct 8, 2016 at 3:17 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    I *think* it's a 74 bulb
    Speedytech7 likes this.
  7. Oct 8, 2016 at 3:17 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    bulb is a t5 or 74
  8. Oct 8, 2016 at 3:18 PM
    shelby0808
    Shelby
    Georgia
    2004 toyota tacoma
    i bought my truck from a guy who hadnt bought new tires for it since he bought it, new, in 2004. i bought it in 2014. im slowly working on it. lol
  9. Oct 8, 2016 at 3:18 PM
    shelby0808
    Shelby
    Georgia
    2004 toyota tacoma
    ill pick it up tomorrow!
  10. Oct 8, 2016 at 3:19 PM
    jubei
    NoCo
    Stuff. Also things.
    Nice! Good for you. These trucks are great, and they'll go damn near forever if you take care of them!
  11. Oct 8, 2016 at 3:19 PM
    devinzz1
    devin
    2023 aclb trd or mt
    id recommend buying a pack of led ones. much nicer.
    edit: actually if you havent already done so pick up some 194 leds aswell for the dash. one of the best interior mods you can do imo.
  12. Oct 8, 2016 at 3:52 PM
    552Jrider
    552Jrider Well-Known Member
    Jeremy
    Norcal
    2002 DC 4x4
    Put my mtrs on today:jellydance:... and yes i put them on. Kinda fun to put ur own tires on. 5th one is coming monday and im ordering a matching 5th wheel monday too. Pretty skoked to be back to mud terrains.
  13. Oct 8, 2016 at 4:20 PM
    WinSlow939
    WinSlow939 Road Salt Life
    Nate
    The Rock, Mass
    2002 with some '99 thrown in for fun
    All the Money I Have
    @jubei777 Looking for some additional info regarding the 60,000 mile regular maintenance interval for my 2002 3.4L V6 4x4 5MT extended cab.
    Any thoughts?
    - For the coolant, I'm planning on going OEM.
    Awesome choice. Flush well, then fill block first, then rad, then run and let the rad burp the excess air
    - I'm planning on using the OEM oil filter, and synthetic 5W-30 oil. Also going to be installing a Fumoto valve and lock.
    - Diff oil has been replaced recently after regearing. Using Lucas 85W-140, per ECGS recommendation.
    I'm running the Lucas 85W-140 as well, great gear oil
    - New tires were installed recently enough to start rotation at next oil change.
    - Currently running a K&N CAI until it gets replaced with a stock air box and snorkel.
    Good idea to clean your MAF sensor with the K&N, the oil likes to gum it up. stock air box/snorkel FTMFW
    - How does one know if one is running a non-platinum spark plug? I'm planning on replacing with OEM if they need to be changed.
    Change them out anyway, peace of mind
    - Can I run an NLGI-2 grease such as Lucas X-Tra Heavy Duty grease for all of my chassis zerks?
    I do, but others recommend a different grease for double cardan joint
    - What are your recommendations for transmission and transfer case oil(s)?
    I run Redline MT-90 for trans and its been awesome, and Redline 75W90 for the transfer case
    - What are your recommendations for belts? OEM? I'm using this as somewhat of a baseline service since this is the first major service since I bought the truck and I have no idea if the PO took care of anything more than oil changes.
    OEM belts FTMFW
    - When the owners manual references the 'propeller shaft bolt', are these the bolts connecting the driveshafts to the pinion flanges, or are they specifying the pinion but itself?
    They are the four bolts connecting the flanges, good idea to re-torque, I even found I was missing one!
    Also a good idea to flush power steering fluid, making sure the screen in the canister isn't plugged with crap
    Brake fluid could be flushed if its lookin old
    Could also clean throttle body and replace PCV valve
    Thanks in advance, you guys!
    ETA: Sending out the Bat Signal!
    @BDN @Squeaky Penguin @Blackdawg @alee891 @TMFF @Robmonster117 @cynicalrider
    Thanks, fellas!
  14. Oct 8, 2016 at 4:28 PM
    jubei
    NoCo
    Stuff. Also things.
    You're a good dude, Nate! Thanks a ton!
    I'm gonna hold off on the transmission and transfer case oil until I get a few more opinions. Seems like those are pretty individual choices, and may be based off of the region they're in and the mileage, etc.
    Where do you get your plugs from, btw?
    Thanks again!
    shelby0808 likes this.
  15. Oct 8, 2016 at 4:30 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I run MT-90 in my trans too and regular Valvoline 75-90 in the t-case although if you felt like it you could put MT-90 in that too (not really important as it only has one synchro)
    jubei[QUOTED] likes this.
  16. Oct 8, 2016 at 4:44 PM
    WinSlow939
    Nate
    The Rock, Mass
    No problem man, glad to help!
    I got my plugs from Toyota, and also ordered new wires from them as well, online. Can't really go wrong with OEM, plus I do all the work myself, so the money I save paying a mech can go toward the best quality parts. At least thats what I tell myself
    jjsul and jubei[QUOTED] like this.
  17. Oct 8, 2016 at 4:45 PM
    WinSlow939
    Nate
    The Rock, Mass
    Exactly, t-case wont notice whats in it also long as the weight's right
  18. Oct 8, 2016 at 4:45 PM
    jubei
    NoCo
    Stuff. Also things.
    Nice! I've got a list of stuff to get from the dealer, and I'm gonna add the wires and plugs to it now. Thanks, bud!
    jjsul and WinSlow939[QUOTED] like this.
  19. Oct 8, 2016 at 4:47 PM
    WinSlow939
    Nate
    The Rock, Mass
    Hell yeah, give it heck man! and enjoy the happy truck :cheers:
  20. Oct 8, 2016 at 5:20 PM
    brother moses
    brother moses Well-Known Member
    Brandon
    Washington
    02 Double Cab Supercharged
    Light Bars, deck plate mod, Camburg 2.5 coil overs, Dakars, AP sliders, NWTI Bumpers
    First off, Nice truck! Now, when I bought my 02 double cab about 5 years ago, the e-brake didn't work. It turned out to be the little crank lever on the back side of the drums. froze solid. took me longer to unstuck that than do the brake job itself. there should be tons of information on ebrake stuff.
    The power steering rack bushings are not that hard, should take no more than an hour or 2.
    I got all of my dash lights from superbrightleds.com. they were easy to replace, just make sure to test them before you reassemble, because they can go in backwards and not work.
    jjsul likes this.
