  1. Oct 26, 2016 at 2:39 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I would not use red.
    A couple Toyota techs I've talked to said not to use any at all. That being said, I've used blue the last couple times.
    jjsul, Deathbysnusnu and snowboard704 like this.
  2. Oct 26, 2016 at 2:41 PM
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
    Someone a few days ago posted that the dealership had replaced their lbj under the recall. They reused the old bolts....I doubt they added any loctite.
    snowboard704 likes this.
  3. Oct 26, 2016 at 2:41 PM
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Okay thanks:hattip:
    I did buy the toyota ball joints and new bolts for them. Blue lock tight it is.. hopefully all goes well. Not really that complex of a job
    jjsul and quetzal[QUOTED] like this.
  4. Oct 26, 2016 at 2:43 PM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Mine were replaced under recall at 30k:ballchain:
    So the small side to side wiggle in the front is either lbj or inner/outer tie rods
  5. Oct 26, 2016 at 2:48 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    How are you guys checking the ball joints?
    Are you jacking up on the frame until the wheel comes of the ground?
    Place a bar under the wheel and pry it up looking for slop in the joint?
    jjsul likes this.
  6. Oct 26, 2016 at 2:49 PM
    quetzal
    Mario
    Long Beach, CA
    The LBJs are super easy. Make sure you have the Pitman arm puller and you're good to go. Don't forget to properly torque everything and use a new cotter pin.
  7. Oct 26, 2016 at 2:52 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    My driver's side passenger seatbelt (xtra cab) is fully retracted and no longer has any spring retention. Do I need a new seatbelt or is it easy to fix it?
  8. Oct 26, 2016 at 2:53 PM
    Squeaky Penguin
    Brett
    If you read the post I quoted yesterday regarding LBJ info, one would be wise to note the acceptable amount of vertical play in the joint, as stated by Toyota, is .020".
    If you notice ANY play in the joint using that method, you're way past a proper service interval.
    Adventurer_Alex likes this.
  9. Oct 26, 2016 at 2:53 PM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    I was planning just to hit it with a hammer to get the tie rod out? They claim a few hits will do it
  10. Oct 26, 2016 at 2:54 PM
    tacomatrd22
    tacomatrd22 TRD SuperCharged Tacoma
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    FlowMaster Super 44 2" lift Gray wire Fog light
    I'm gonna try and get them done before I hit 140K on her. Plus a new tranny filter and oil cooler is gonna be installed sooner or later.
    Good luck. Big topic on that earlier on this trend.
  11. Oct 26, 2016 at 2:56 PM
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    That's what I did. Save that for gas money.
  12. Oct 26, 2016 at 2:58 PM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Yea im sure, lbj’s are always popping in and out of this thread. I don’t have the time to always keep up with it:annoyed:
    Free to rent at auto zone, just requires a deposit
    tacomatrd22[QUOTED] likes this.
  13. Oct 26, 2016 at 3:00 PM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    From reading/research etc. The inner/outer tie rods don’t look very hard to do either.
    Any comments? (Other than ill need an alignment after)
  14. Oct 26, 2016 at 3:00 PM
    quetzal
    Mario
    Long Beach, CA
    I thought and read the same thing about the stock control separating from the spindle with just a few blows with a 4lb maul until it didn't work for me. Luckily I was prepared w/a 4 1/2" angle grinder and had to cut the bitch of a bolt off in order to separate the two. Better to be over prepared.
    snowboard704[QUOTED] likes this.
  15. Oct 26, 2016 at 3:00 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Common problem. Take it out and wash in soapy water.
  16. Oct 26, 2016 at 3:01 PM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Yea I suppose ill rent one because ill have to stop for blue lock tight anyways:thumbsup:
  17. Oct 26, 2016 at 3:09 PM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    Before 140K? Nice. I was at about 171K and the fluids were all original, according to how they looked and my service records.
  18. Oct 26, 2016 at 4:35 PM
    retroboy1989
    retroboy1989 Single Cab 4x4
    99 2.7L 5spd 4x4
    Plan on buying at least one new tie-rod end.
    Hammer method to deform the tappered hole and release the tre didnt work for me. Also, the castle nut is too soft, so dont try threading it on and hitting it. I ruined my TRE by trying that.
    Grab a pitman arm/tre puller and a ball joint separator pickle fork to make life easy.
  19. Oct 26, 2016 at 4:40 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    It's not stuck, it's fully retracted. It won't go back into the mechanism. If I pull or push on the belt nothing happens.
  20. Oct 26, 2016 at 5:29 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Or play in the steering rack. Pull the driver side rack boot back then shake and observe the rack shaft and inner tie rod.
    You need to understand that the normal state of the LBJ is in tension. No amount of shaking or prying will show play in the joint if it is already under tension. The tension must first be relieved. The wheel should be off and the lower control arm jacked up to as near to "ride height" as possible. Only then can a pry bar between the LBJ and the spindle show the actual play. Keep in mind that the (OEM type) upper control arm bushings themselves are capable of placing tension on the LBJ if the test is done with the suspension in "droop", below normal ride height. The upper control arm pivot bolt is intended to be tightened at "ride height" so at any droop below ride height the UCA bushings can be putting the LBJ in tension.
    See above, even the FSM fails to note the torsional effect of the upper control arm bushings on the LBJ and essentially says to check at full droop, fail.
