  1. Oct 28, 2016 at 2:07 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    Remove airbag
    ClevSix likes this.
  2. Oct 28, 2016 at 2:09 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Wheelers Off Road, standard extended line, it is close but not tight. Not my truck either but that is my hand up under it's skirt.
    jjsul and chrslefty[QUOTED] like this.
  3. Oct 28, 2016 at 2:24 PM
    Cadmus
    Cadmus Un-Known Member
    Fort Collins CO USA
    '04 4door 4x4 TDRoffroad
    No. that turns the light on. Or at least it did on every vehicle i owned since the 1990s. try black tape.
  4. Oct 28, 2016 at 2:31 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    Does anyone have any idea where I could find this or what it's called? Its the little plastic knob that the gas door hooks onto, goes where that square hole is. Somehow I broke it while putting my bed back together.
  5. Oct 28, 2016 at 2:56 PM
    Bennett707
    Oregon
    :anonymous:
    side note - anyone have a recommendation for steering rack bushings? energy suspension i'm assuming?
  6. Oct 28, 2016 at 2:57 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    So I checked my tranny fluid today while the engine and tranny was hot and running after pulling my trailer around town. the fluid was about a half inch above the top cold marker. anybody know how approximately how much trans fluid I should add and what kind? I have a v6 auto prerunner btw
  7. Oct 28, 2016 at 3:00 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Air bag system on these trucks are pretty simple. If there has been no accident to trigger the SRS ECU, then the only thing that can cause the light to come on is a bad connection.
    When the truck is first started, the SRS ECU does a system check. This check is nothing more than a continuity check. The SRS ECU is checking the resistance at all the sensors on the truck. If you have a bad sensor, you get the light. If you have a connector not seated fully, you get the light.
    Sensors to check first: Look at the connectors and crash sensors on the front frame and core support. There have been reports of corrosion on the sensor connectors.
    The ribbon cable or clock spring assembly located under the horn in the steering column can fail as well. When this goes, sometimes you get erratic turn signal or horn malfunction. A common cause to fail the ribbon cable is when the steering rack is replaced and the wheel is not locked in position. People accidently turn the steering wheel more than 3.5 turns right or left. It breaks the ribbon cable. Fortunately, this part is pretty cheap.
    One thing nice about SRS on all cars is the wiring is covered with a very bright yellow loom or sheathing. It the only wiring that uses this color and it really stands out. Chase these cables down and look for issues that could cause a poor connection.
    Another nice thing about the SRS is that if you have a fault or check air bag light, is once the issue is fixed, the light goes away on its own. You don't need a code clearing tool.
  8. Oct 28, 2016 at 3:28 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    That would be 2.5 turns left or right of center.
  9. Oct 28, 2016 at 3:40 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Replaced the pos aftermarket rack today with a brand spanking new OEM from our friends at Toyota. Totally worth it.
    After hooking up the rack, I had 1 3/4 turn from center, left or right, in the steering wheel. It went full lock both ways and was consistent, I assume it was ok?
    I assume you are talking about a steering wheel that is unhooked from the rack?
  10. Oct 28, 2016 at 3:46 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    A thing of beauty.
    Yes, your fine. The spiral cable cartridge itself allows a total of 5 turns from "bind to bind" or "when resistance is felt" in Toyota speak.
    Deathbysnusnu[QUOTED] likes this.
  11. Oct 28, 2016 at 3:49 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Thank you! :thumbsup:
    Dirty Pool[QUOTED] likes this.
  12. Oct 28, 2016 at 4:14 PM
    koditten
    Kirk
    Central Michigan
    I figured I had that one wrong. Luckily its stamped on the spiral cable assembly.
  13. Oct 28, 2016 at 4:48 PM
    CStoy
    CStoy mountain-top maniac.
    majestic gold 4x4... 1/4 million miles and counting!
    improved toyota goodness.
    check the white connector under the drivers seat... my airbag light was solid on for a while ever since I disconnected the plug to do some sound proofing and forgot to reconnect it... reconnecting it turned my light off and the light hasn't come back on since.
  14. Oct 28, 2016 at 5:17 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Where and how much? Ill be picking one up next month. Doing lbj's again. Upper bj's again. I think i should jusy sas this bitch
    jjsul and quetzal like this.
  15. Oct 28, 2016 at 5:27 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Dealership purchase, I did the work, overpaid of course. Everything is tight for the moment though, so hopefully it sticks this time. :)
    jjsul, quetzal and Fernando[QUOTED] like this.
  16. Oct 28, 2016 at 6:00 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Mines like always on, I've given up on the airbag system tried fixing it a few times but it's gotta be a busted wire with how it's so intermittent.
  17. Oct 28, 2016 at 7:26 PM
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
    Or uniball uca's?
    Fernando[QUOTED] likes this.
  18. Oct 28, 2016 at 7:29 PM
    Speedytech7
    What about uniball LBJs?
  19. Oct 28, 2016 at 7:32 PM
    quetzal
    Mario
    Long Beach, CA
    :pray:
  20. Oct 28, 2016 at 7:38 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Finally copied @PcBuilder14 and put in my usb extension.
    Also finally cut my interior pieces to fit after I tubbed. :anonymous:
    Deathbysnusnu, jubei and PcBuilder14 like this.
