  1. Nov 5, 2016 at 4:07 PM
    ocaldwell332
    ocaldwell332 Well-Known Member
    Owen
    2004 Silver Tacoma V6 PreRunner
    Threw my lightbar on finally! :D
    2002Tacoma4x4 and Bulldogs129 like this.
  2. Nov 5, 2016 at 4:08 PM
    Cadmus
    Cadmus Un-Known Member
    Fort Collins CO USA
    '04 4door 4x4 TDRoffroad
    Thanks, I knew of these sources and had wondered if the ones at ruff stuff might work (the ones with the bolt heads on the same side) but given the minimal photographs i can not tell. Do you know where there are more photos?
    $36-40/each is a little ridiculous so I figured a DIY or local machinist or Chinese machinist might be a better option since i no longer have access to a metal shop.
    Regardless, for both me and the archival value to the site, thanks for the links.
  3. Nov 5, 2016 at 4:22 PM
    tntacomaguy
    tntacomaguy Well-Known Member
    Didn't "flush" it persay. Just took a turkey baster and sucked it all out of the reservoir. Filled it up and drove it shifting several times. Then sucked it out again and filled it again. Gonna let it go a few days and see if it's dirty if not I'll let it go. Mechanic friend said I could open a bleeder and flush it that way, but doing it alone I would risk getting air in the system.
    Bulldogs129[QUOTED] likes this.
  4. Nov 5, 2016 at 4:25 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    My bad brotha....for some reason it looked like a DB
  5. Nov 5, 2016 at 4:32 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Are rear brakes a pita? I think mine need some attention....
  6. Nov 5, 2016 at 4:37 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    It's way too tall is what it is.
  7. Nov 5, 2016 at 4:53 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Found out my radiator has a slight leak, that or the hose is seeping. Hard to tell. Either way another thing to watch I guess
    Bulldogs129 likes this.
  8. Nov 5, 2016 at 4:55 PM
    JKO1998
    Utah
    Damnit...
  9. Nov 5, 2016 at 5:12 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Pre runner non problems? Lol
  10. Nov 5, 2016 at 5:28 PM
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    How is it too tall? It's eibach/bilstein with v6, bumper and soon to be winch. Also it's probably the angle of the pic that makes it look too tall
  11. Nov 5, 2016 at 6:16 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Maybe its the angle ..your pee runner is sexy bro. I dig it
  12. Nov 5, 2016 at 6:43 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Anybody have any idea the hub to fender measurements on rears before a lift?
    Also, does anyone run the wheelers 8 leaf pack?
  13. Nov 5, 2016 at 6:52 PM
    jules04taco
    jules04taco Well-Known Member
    Trish
    PNW
    04 xtra cab 4x4 TRD
    Camburg UCA, Kings, URD short shifter, K & N performance air intake
  14. Nov 5, 2016 at 7:00 PM
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    For machined 4130 it's not a bad price for what you get. You won't get it cheaper at a local machine shop unless you make them mild steel or a run of 1000+ or both. Call Ruff stuff and ask, they also have tons of email sales going on so you might be able to save 10-20%. What are you going to use them for?
  15. Nov 5, 2016 at 7:00 PM
    viverr
    viverr Member
    WA
    '02 dcsb
    For anyone who's replaced their door seals, did you glue it with the plastic panelling off and then stuff the panel ends behind the new seal? Can't find the FSM page with the actual process but I think that's how it's supposed to go to keep the panels tight. 3M the inner clip molding and wait for cure, then pop the panels behind the inner seal lip?
  16. Nov 5, 2016 at 7:09 PM
    Cadmus
    Fort Collins CO USA
    Need to add a hang glider rack. (using it to bring home 20' metal sticks and lumber also) But i need to keep the bed free for a camper so it is looking like a half assed exo-cage.
  17. Nov 5, 2016 at 7:56 PM
    WinSlow939
    WinSlow939 Road Salt Life
    Nate
    The Rock, Mass
    2002 with some '99 thrown in for fun
    All the Money I Have
    I looked up mine too, sure enough.. no recall. These have to be considered wear items now, so regardless of recall, I gotta change mine out. Grease has leaked on drivers side, still tight. But the nightmares must stop. So, $200 shipped OEM to my door, elbow grease and some locktite...I'll be ok
  18. Nov 5, 2016 at 8:02 PM
    Bulldogs129
    Bulldogs129 Don't find fault, find a remedy
    Malcolm
    Mississippi
    2018 TRD, OR, 4wd, Dblcab, 3.5l, & 2002 Tacoma 4wd, SR5, TRD, 3.4L, auto
    No problem. Keep an eye on yours, the 1st gen had LBJ issues.
    jules04taco[QUOTED] likes this.
  19. Nov 5, 2016 at 8:09 PM
    Bulldogs129
    Malcolm
    Mississippi
    Good move! Watch your bolts trying to back out from vibrations. Tighten about 1.5 eyeballs tight, not quite 2 eyeballs. Don't white knuckle to much.
    WinSlow939[QUOTED] likes this.
  20. Nov 5, 2016 at 8:14 PM
    Shortman5
    Supercharged TRD
    Eyeballs?
