  1. Nov 8, 2016 at 7:19 PM
    tacomatrd22
    tacomatrd22 TRD SuperCharged Tacoma
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    FlowMaster Super 44 2" lift Gray wire Fog light
    Yup I just hoping it won't be that hard installing it.
    Thank you, hoping this will last me another 10-15 years before I look for a high output alternator that'll last just as long as OEM. How much voltage does OEM put out?
  2. Nov 8, 2016 at 7:30 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    14-14.5 volts is the norm.
    If you dont need a ho alt then theres no need to get one. that being said i love my 160amp alt with my excessive audio and lighting setups. i also plan on a winch and other current drawing accessories so i think for me its a good investment.
    Bulldogs129 likes this.
  3. Nov 8, 2016 at 7:33 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Scrapping the ADS mid travel already?
  4. Nov 8, 2016 at 7:38 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Other truck
    Ice Horse likes this.
  5. Nov 8, 2016 at 8:11 PM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    Bulldogs129 and Silver02Taco like this.
  6. Nov 8, 2016 at 8:14 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    You can swap a GM 150 amp alternator, not sure if that is what you are talking about?
  7. Nov 8, 2016 at 8:34 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Yeah, just moved the belt over a rib or two.
    The issue isn't voltage, its amperage.
    As Devin said, an alternator in good working order should put out 14+ volts (or close to it) all the time. It is amperage out put at idle that I am comparing. It is ~40 amps for the OEM at idle and ~100 amps for the typical GM CS144 remans. IIRC, the OEM puts out about 80 amps at 3K RPM where the GM can be 140+.
  8. Nov 8, 2016 at 8:50 PM
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    I see what you mean. I don't believe I'll go to crazy with audio I'm only thinking about putting 1 sub behind the seat and call it good. As for lighting I'm just gonna run a possible 2 pods for backup, 1 30" lightbar and some halos for the headlights. Don't think I'll go to big on lighting. Got a write up about fitting a different alternator in your truck?
    Might look into this when I'm running more lighting. Might not be a bad idea to have another alternator just in case in the later years I'll get a GM alternator.
    Ahhh I see what you mean. Less risk of draining the battery when your running a lot of lighting or as devin said audio. There a write up about switching the alternator? The O'Reilly's brand didn't fit because I couldn't put the tensioner bolt where it connects to the bottom of the alternator through the mount.
  9. Nov 8, 2016 at 8:56 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I have one in franks build
    Bulldogs129 and Speedytech7 like this.
  10. Nov 8, 2016 at 8:59 PM
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    I'll take a look, thanks!
  11. Nov 8, 2016 at 9:03 PM
    Digiratus
    Roaming the PNW
    The RedHead
    https://www.tacomaworld.com/threads...trail-rig-and-bs.159436/page-154#post-6586377
    :hattip:
  12. Nov 8, 2016 at 9:09 PM
    devinzz1
    devin
    2023 aclb trd or mt
    At idle the factory alt is fairly useless. Running 8 55watt hids would have me well into the 12v range. i have a voltmeter in my cab and youl notice in gear stopped with the rpms dipped it really is barely charging even without a load. i actually swapped out the pully for a smaller one and it did a little better. still have it as a spare alt.
    Oh and i only have 1 sub behind the seat myself. it just happens to be quite a big one...
    Bulldogs129 and tacomatrd22 like this.
  13. Nov 8, 2016 at 9:37 PM
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    Thanks for the lead for the write up. Looks great and I don't even have to switch my belt since I have a supercharger. I'll do this someday. I'll have to read it a couple of times just for me to get a full understanding but rather do something completely right than wrong.
    I'll be on the lookout on my Ultragauge to see how many volts at idle the alternator is producing once I get her running again. And how big are we talking about?
  14. Nov 8, 2016 at 9:46 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    My two alternatora have both put out over 14.4v consistently. Anything below that is an underperformer.
  15. Nov 8, 2016 at 10:01 PM
    Digiratus
    Roaming the PNW
    The RedHead
    On mine, the voltage at any given moment is totally dependent on the state of charge of my batteries. On first start up, say after an evening of camping, the ML-ACR will have them separated. In this situation the voltage is typically 14.5-14.6 and I have seen moments of higher.
    When the ML-ACR brings the house battery online, it is not unusual to see voltage drop to 14.0 for a while until the two batteries equalize. How long this takes is totally dependant on how deeply the house battery was discharged overnight. Once they do equalize, typical voltage is 14.2-14.3 even when running a lot of accessories.
    I can imaging where the age of a battery would also play a role. My Northstars are still relatively fresh and take and keep a charge very well.
  16. Nov 8, 2016 at 10:02 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Wait till you have a fridge, bangin stereo, and lights running.
  17. Nov 8, 2016 at 10:04 PM
    Speedytech7
    Stereo can sometimes take mine down a bit 1800w of unused power lol. But I think winch will be my next real power worry.
  18. Nov 8, 2016 at 10:15 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    2 alternators? Is the 2nd ran off a bigger belt?
  19. Nov 8, 2016 at 10:20 PM
    Speedytech7
    No, I suppose I worded that poorly. I upgraded to a 120amp alternator from a jaguar but even my old 60amp stock unit put out 14.4 - 14.8v
  20. Nov 8, 2016 at 11:35 PM
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    Good thing I'm not have this worry until I get out of college unless I find a job paying good enough to buy a mod every month.
    Bulldogs129 and jjsul like this.
