  1. Nov 10, 2016 at 8:09 AM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    I'll get some pics up today
    jtb1798 likes this.
  2. Nov 10, 2016 at 8:21 AM
    charliegt35r
    charliegt35r MALL CRAWLERs
    CenCal
    2003 tacoma dc
    OME 2.5 LIFT 285/75/16
    Their raceline monster, 15x8 and 4" bs
  3. Nov 10, 2016 at 9:04 AM
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    I'm about to get into that for the truck and the lady's jeep. It worked wonderfully for my truck last winter, barely any sign of rust
  4. Nov 10, 2016 at 9:12 AM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    Thread-locked and torqued my LBJ bolts to spec. Hadn't done so since they were taken out when swapping the CVs this weekend. And I retorqued all 24 lugs for the hell of it.
    MY50cal, Bulldogs129 and cynicalrider like this.
  5. Nov 10, 2016 at 9:20 AM
    RedManRocket
    Red
    2002 Double Cab LT
    This is as far as I've gotten. My phone doesn't really do it just, but I've only spent a few minutes on it with red scothbrite. It's taking quite a while so I'm thinking of taking a DA to it with maybe 320, I just want to try and preserve the texture. Maybe a super smooth dash won't be that bad. I'll sand it more when I head outside.IMAG0423.jpg
    Bulldogs129 likes this.
  6. Nov 10, 2016 at 9:21 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Are you running any wheel spacers behind those wheels? They seem to be sticking out further than what 4" of BS alone would give.
  7. Nov 10, 2016 at 10:03 AM
    charliegt35r
    CenCal
    2003 tacoma dc
    No wheel spacer, I had to trim some stuff to clear because it rubs when turning. I had 285/75/16 with 4.5 bs on before and it clears with no triming needed
  8. Nov 10, 2016 at 10:03 AM
    RedManRocket
    Red
    2002 Double Cab LT
    Bulldogs129 and jtb1798 like this.
  9. Nov 10, 2016 at 10:11 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Those look like 3.5" bs to me. At least.
  10. Nov 10, 2016 at 10:16 AM
    Digiratus
    Roaming the PNW
    The RedHead
    That is what it looks like to me as well. Unless there is some optical delusion going on with the photograph.
    I'm going by how far past the tire is from the fender flares. Looks like 3.5" or even less maybe. :notsure:
  11. Nov 10, 2016 at 10:18 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I had to go look at my old setup with 33x12.5r15s when I had 4" bs and then 2.5".
    Doesn't look close to 4". Looks closer to the 2.5" to me, though not that wide. So I'm still going with 3.5"
  12. Nov 10, 2016 at 10:18 AM
    a.smo
    a.smo Well-Known Member
    Aaron
    PHX, Az
    '99 Trd Xtra Cab 4x4 5sp
    Thats amazing. Post pictures too when your done please!
    jtb1798 likes this.
  13. Nov 10, 2016 at 10:19 AM
    RedManRocket
    Red
    2002 Double Cab LT
    Will do, I'll probably end up spraying it with some type of uv resistant clear
    Bulldogs129 and a.smo[QUOTED] like this.
  14. Nov 10, 2016 at 10:21 AM
    charliegt35r
    CenCal
    2003 tacoma dc
    haha, you are correct! Just measure my spare, they are 3.5" bs, I was going off what the old owner told me :thumbsup:
    Blackdawg[QUOTED] likes this.
  15. Nov 10, 2016 at 10:22 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Thank god I'm not crazy haha
  16. Nov 10, 2016 at 11:18 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Def want to go gallon and gun next go around. Much more economical than the individual cans. It will probably make welding frame plates on more of a chore but it will be worth it to make the brand new frame last longer.
    WinSlow939 likes this.
  17. Nov 10, 2016 at 11:20 AM
    Madjik_Man
    Colorado Front Range
    Ah... you removed the whole upper dash panel.
    I'm trying to avoid that. If I were to I'd just paint it and be done with it.
    Looks great though for just sanding it.
  18. Nov 10, 2016 at 11:23 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    You can remove the whole dash in about 45 mins, having done it once or twice I can say if you aren't changing HVAC stuff just removing the beauty cover is easy.
  19. Nov 10, 2016 at 11:43 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    There a write up on it somewhere? i want mine all black to match rest of my interior
  20. Nov 10, 2016 at 12:22 PM
    Madjik_Man
    I heard it's a serious PITA
