  1. Nov 11, 2016 at 9:35 PM
    MtRSQ
    MtRSQ I am that I am.
    Brandon
    Utah
    3rd Gen, White, 4Door, V6, TRD, 6MT.
    285 70 R17 BFG KO2's,17” Bronze SCS Billet Wheels, 2.5" Ebaich Lift, MagnaFloe Overland Catback Exhaust (turned down @ axle), Rear Axle Breather Mod,
    More pictures of your dual set up... the mount... where your overflow went etc
    Bulldogs129 and ClevSix like this.
  2. Nov 11, 2016 at 9:37 PM
    CLL17P
    CLL17P Well-Known Member
    curt
    steamboat springs colorado
    04 double cab tacoma
    Donahue racing lift kit, TG low profile bumper, TG rock sliders, Skid Row skid plates, and currently building.
    I added a leaf but it is way to stiff, i intend on removing them and either use Dakar or Deaver 10 leaf with maybe 5 inch shackles. I inquire of the axle adjustment because I want 255/85/16 BFG tires which will fill the wheel well for sure.
  3. Nov 11, 2016 at 9:39 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Your an 01-04. And a double cab.
    Get the relocation plates, you'll need them.
    3/4'' forward work perfect for me and many others. Im running 255/80r17s..same size as you just a 17'' rim.
  4. Nov 11, 2016 at 9:44 PM
    CLL17P
    curt
    My son and i were drinking coors light and crown that night. We did not take pictures of the battery mount but we welded a plate to the toyota and then welded a vertical plate and tab with hole for bolt to squeeze the top hold down metal piece. The top piece is simply bent and hooked under the edge lol and bolted on other side. Because the battery on sale was larger then optima red top for my 04 tacoma, we had to do away with stock over-flow catch and replace with mountain dew plastic bottle for now lol. I will take better pictures tomorrow and post them here so you can laugh with us about our welds while FWD fabricating while drunk lol
    Bulldogs129 and Digiratus like this.
  5. Nov 11, 2016 at 9:45 PM
    CLL17P
    curt
    Thank you Monte
    Blackdawg likes this.
  6. Nov 11, 2016 at 9:46 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    this ^^^
  7. Nov 11, 2016 at 9:47 PM
    RLD831
    RLD831 Active Member
    Rob
    2001 Tacoma Doublecab PreRunner Limited
    Thanks. That's enough to make me want to do it now. I like it with the texture too. I might start out with the red scotchbrites and see how much effort it takes. Definitely post up when you're finished with the sandpaper. If the smooth doesn't come out too bad, I might have to steal that idea from you.
  8. Nov 11, 2016 at 9:49 PM
    CLL17P
    curt
  9. Nov 11, 2016 at 9:51 PM
    CLL17P
    curt
    Mike that photo with the mountains in the background is awesome.
    Dalandser likes this.
  10. Nov 11, 2016 at 10:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    those things look tiny.
  11. Nov 11, 2016 at 10:29 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Thanks Curt. That is from our adventure this summer in British Columbia. Glacier country.
    What? The bottle of Crown?
  12. Nov 11, 2016 at 10:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No the batteries
  13. Nov 11, 2016 at 10:37 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, I commented on that earlier. One looks like a group 34/78. Not sure what the other, smaller one is. It is interesting that both are red tops.
  14. Nov 11, 2016 at 10:43 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea not my first choice for duals. But it works I guess
  15. Nov 12, 2016 at 1:00 AM
    Tacoma530
    Tacoma530 Well-Known Member
    Devin
    Anderson
    white 1997 tacoma 2.7 (3rz) stock
    All stock
    Well I did a full rebuild on my 3rz and installed a stage 3 clutch system
    Bulldogs129, jubei, boostedka and 2 others like this.
  16. Nov 12, 2016 at 1:06 AM
    Tacoma530
    Devin
    Anderson
    All stock
  17. Nov 12, 2016 at 3:54 AM
    2002Tacoma4x4
    2002Tacoma4x4 TRD 4x4 double cab
    C K
    Limited Edition Double Cab TRD off road 4WD
    Chassis saver clean up immediately if you rub with Saliva and clean rag.
    Cadmus[QUOTED] likes this.
  18. Nov 12, 2016 at 6:30 AM
    tsheldon18
    tsheldon18 Active Member
    Trevor
    Tennessee
    2004 3.4L SR5 4x4 Tacoma
    -3" eibach coils with bilstein 5100s in front -1.5" extended shackle in the rear -Satoshi custom mesh grille with Tacoma raptor style letters -33x12.50 atturo trail blade m/ts -18x9 mayhem warriors -Trail Gear Low Profile Tube Bumper
    Got my new setup put on today!:yay:
  19. Nov 12, 2016 at 7:55 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    How big are those wheels and tires?
  20. Nov 12, 2016 at 8:21 AM
    TotesMagotes
    TotesMagotes Too Drunk To Taste This Chicken
    British Columbia
    '01 Double Cab 4x4 V6
    OME Lift, 285's
    I haven't yet, it's a bit off. I believe I just need to add some axle shims to center it.
    Very cool. That would be a dream...what do you ride?
