  1. Nov 13, 2016 at 10:50 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yea anything is possible with enough time and effort. Sure you can.
  2. Nov 13, 2016 at 10:54 PM
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Ill come up with something similar and post pics when its done... all 1/4 of course
    Speedytech7 likes this.
  3. Nov 13, 2016 at 11:12 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    I'm pretty sure that's the reasoning behind the price, he just doesn't want to build them, and probably not making much at the old price to be worth it.
  4. Nov 13, 2016 at 11:13 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I known he doesn't. Has said it several times they are a pita.
    snowboard704 likes this.
  5. Nov 13, 2016 at 11:25 PM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Yea I definitely can see it.. all the different angles on the press etc
  6. Nov 14, 2016 at 3:23 AM
    retroboy1989
    retroboy1989 Single Cab 4x4
    99 2.7L 5spd 4x4
    Strange, mine came with bolts...
  7. Nov 14, 2016 at 8:12 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Yeah, BAMF. Got it in the original GB for 250$ I think.
    I have definitlely gotten good use outa this thing. This skid gets bashed on quite a bit (pun intended) for its cost and the fact that you lose about 1" of ground clearance but it is study AF and protects the back cover as well as the pinion flange/slip joint/u-joint. Very glad I have it.
    edit: I did not have to modify it. Fits like a glove.
  8. Nov 14, 2016 at 8:16 AM
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    Replaced my blower fan Saturday. I removed it about two years ago because it was making a clicking noise. Thought a leaf or pine needle was stuck in it. Holy cow it was dirty and I don't smoke or live on a dirt road. Blew it out with a air compressor and scrubbed the plastic wheel with a toothbrush (tried, but could not remove the squirrel cage). Note - If you use an air compressor, be mindful that a boatload of regular dust and black dust from the electric brushes will blow out.
    The clicking noise came back so I ordered a TYC replacement from Amazon. I'm sure the electrical drag has to be less since the cage on the new one spins so much easier!
    While I had the old one out, I used a cleaner/freshener on the ac condenser.
    I highly recommend you do this. I really wasn't expecting to see as much grime on the condenser as I did because again, I don't live on a dirt road, smoke or go off-roading. It's tighter than a dicks hat under the dash so I used a telescoping mirror with/light to view it.
    Using the extended straw I was able to feed it into the condenser space. Took about two minutes to empty the can. Residue, etc comes out the ac drain. An added benefit is that it smells great!
    https://www.amazon.com/TYC-700059-Toyota-Replacement-Assembly/dp/B000GOJWHM/ref=au_as_r?_encoding=UTF8&Make=Toyota%7C76&Model=Tacoma%7C1037&Year=2003%7C2003&ie=UTF8&n=15684181&newVehicle=1&s=automotive&vehicleId=1&vehicleType=automotive
  9. Nov 14, 2016 at 8:17 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
  10. Nov 14, 2016 at 9:28 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yeah def my bad for not having already armored it. Damage happens when you actually test you and your trucks limits.
  11. Nov 14, 2016 at 9:46 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    He wouldn't know what that is
    Speedytech7[QUOTED] likes this.
  12. Nov 14, 2016 at 9:56 AM
    2002Tacoma4x4
    2002Tacoma4x4 TRD 4x4 double cab
    C K
    Limited Edition Double Cab TRD off road 4WD
    :facepalm:On weekend washed pressure inside frame, install the skid plates that I removed week before for clean up. Like a pound of mud came of scrubbing in dry with screwdriver on holes of frame next to rack. Buch of pic, noticed oil leak:facepalm:
    Bulldogs129 likes this.
  13. Nov 14, 2016 at 1:11 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    The one and only with a RAT diff skid!
  14. Nov 14, 2016 at 1:12 PM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    :spy:
  15. Nov 14, 2016 at 1:37 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    oh, you have one too? lol....I thought I was special..haha
  16. Nov 14, 2016 at 1:54 PM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    No haha... I'm trying to get one from either RAT or bamf but probably end up just fabbing one up
  17. Nov 14, 2016 at 2:43 PM
    TrailRider2002
    TrailRider2002 Well-Known Member
    Cameron
    Powdersville, SC
    02 Tacoma 4x4
    -3in old man emu suspension lift with 882 coils, nitro chargers and rear add a leaf -1in Daystar Body lift -295/75 BFG KO2'S -flowmaster dual 40s
    What year 4Runner seats will fit in my truck?
  18. Nov 14, 2016 at 2:45 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    never updated you guys on my top plates I finished awhile ago so here it is after painting the whole bumper last weekend
  19. Nov 14, 2016 at 2:51 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    I believe third gen seats with a little modification to the brackets, theres quite a few threads on it
  20. Nov 14, 2016 at 2:58 PM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    Looks good. I quite like it.
    Lux[QUOTED] likes this.
