  1. Nov 23, 2016 at 3:48 PM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    If you haven't done the following recently, I suggest:
    Spark plugs & wires
    timing belt (if you have one)
    water pump & related parts
    PCV valve
    replace brake fluid
    replace trans fluid
    replace gear oil in trans, t-case, diffs
    power steering fluid
    fuel filter
    clean TB
    clean MAF sensor
    grease zerk fittings
    inspect balls joints and replace if needed
    u-joints
    carrier bearing
    All that comes to mind right now. I'm working on that list myself, since I am at 175K. I did a little over half of them during the Spring. Looking to do most if not all of the rest next year.
  2. Nov 23, 2016 at 4:24 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Thanks guys I believe I hit just over 198,000 today. My idle at startup (not all the time) recently starts to get a bit rough around 570-600 rpms. No cels and ultragauge doesn't detect any codes. Curious to know what this is related to...
    Also don't seem to hear any vacuum leaks.
    WinSlow939 likes this.
  3. Nov 23, 2016 at 4:38 PM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    Yeah the scangauge how you like it?
  4. Nov 23, 2016 at 4:45 PM
    WinSlow939
    WinSlow939 Road Salt Life
    Nate
    The Rock, Mass
    2002 with some '99 thrown in for fun
    All the Money I Have
    I had the same thing before I did the 100K tune up...it made a huge difference in the way the truck sounded and operated, especially with all OEM shit. I bet your rough idle would go away with the items listed above or at least narrow the culprits
  5. Nov 23, 2016 at 4:46 PM
    TashcomerTexas
    I'm with you on that. As long as it's running with no codes I'm good for the time being.
  6. Nov 23, 2016 at 5:41 PM
    The Driver
    The Driver Trail Runner/Barefoot Beach Runner/Snow Skier
    Raph
    Lakewood (Green Mountain), CO.
    '02 Extra cab 4X4 TRD SR5 3.4
    Aftermarket tranny cooler, 5100 Series Bilsteins, ToyTec Bilstein front coilovers, SPC UCA's, Alcan leafs, Class 3 Hitch, Tundra Front Brakes,
    Cleaned the MAF, cleaned the throttle body, replaced spark plugs, replaced spark plug wires, replaced fuel filter.
    Next week, I'm replacing the vacuum lines.
    taco terror likes this.
  7. Nov 23, 2016 at 6:44 PM
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    I personally like it, I picked it over the ultragauge only because you can change the colors and it offered trans temp readings.
    The problem is that they never figured out the programming to display the trans temp so we actually can't use that feature. Knowing that I woulda probably opted for the cheaper ultraguage.
    I do like how this one is compact and I can fit it where it's at. There isn't much space for gadgets in these trucks.
  8. Nov 23, 2016 at 6:59 PM
    CStoy
    CStoy mountain-top maniac.
    majestic gold 4x4... 1/4 million miles and counting!
    improved toyota goodness.
    that seems low... mine is 700- 750 rpm and smooth to the point I have to look at the tac to know it is still running...it will run 800-900 rpm (and a touch over 1k if it is below 0*f out) for the first 30 sec or so at cold start...
    no codes showing at the moment and 270,xxx miles...
  9. Nov 23, 2016 at 7:06 PM
    sente3
    sente3 -
    North Jersey
    You're only at 800-900 with a cold start? Mine goes upwards up 1500rpm and over the next few minutes goes down from there until it hits that 750ish mark.
    Jarob11 likes this.
  10. Nov 23, 2016 at 7:10 PM
    TashcomerTexas
    Yeah I know it is, enough to shake the truck a bit. When I started it from work it was 750-800. When I started it here about an hour ago it was at 600. It's only at start up; if I'm idle at a light it's normal. No codes.
    I can actually hear my truck, it's supercharged.
  11. Nov 23, 2016 at 7:44 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    What others have said, plus valve cover gaskets. It'll give you a chance to replace and clean a good amount, plus check valve clearance.
  12. Nov 23, 2016 at 7:48 PM
    TashcomerTexas
    Can anyone get me part #s for what I need for water pump and timing belt?
  13. Nov 23, 2016 at 8:42 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Are you in fairwood for the weekend?
  14. Nov 23, 2016 at 8:45 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    I got mine from eBay, they've got a ton of sellers with all oem components. I'll see if I can find what I got, but it was a few years ago.
    Edit:
    Found it
    http://m.ebay.com/itm/180729034728?_mwBanner=1
    Jarob11 likes this.
  15. Nov 23, 2016 at 8:48 PM
    Digiratus
    Roaming the PNW
    The RedHead
    The X-code programming for the trans temps only works on newer 1st gens. '98 and newer IIRC.
  16. Nov 23, 2016 at 9:00 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    yessir
  17. Nov 23, 2016 at 9:13 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Hook up for a few? Maybe Fri or Sat?
  18. Nov 23, 2016 at 9:15 PM
    Speedytech7
    Fri should work, shoot me a txt when you'll be off work
  19. Nov 23, 2016 at 9:24 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Not working that day but I may have a hangover
    Speedytech7[QUOTED] likes this.
  20. Nov 23, 2016 at 9:26 PM
    CStoy
    yes.
    I thought that was normal? ...although mine did run 1200 or so at startup at first before I replaced the plugs, wires, o2 sensor, and cats ...
    I can too if I think about it... but not over the radio :D
