  1. Nov 27, 2016 at 3:53 AM
    2002Tacoma4x4
    2002Tacoma4x4 TRD 4x4 double cab
    C K
    Limited Edition Double Cab TRD off road 4WD
    Get recording camera that comes with GPS, imo Garmin has a couple 300 and 400 plus install, on my wish list as soon as cash out the lotto ticket.
    By the way I spend all this week painting the frame with chassis saver, I just load bunch of pictures of before and after on my 1st media TW album, still not finish, I missed some spots but I will get them next weekend, also pending to remove gas tank skid and treat it/ paint.
  2. Nov 27, 2016 at 6:13 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Painted my tool box separator and riveted it in. Also added bed lights so I can see my tie down mounts at night.
  3. Nov 27, 2016 at 7:20 AM
    WinSlow939
    WinSlow939 Road Salt Life
    Nate
    The Rock, Mass
    2002 with some '99 thrown in for fun
    All the Money I Have
    Exactly, the 3.4L stays pretty tight, even if it is a rattling ol coot sometimes. I ended up pulling the valve covers to check, its not a hard procedure. It is interesting to see the condition of your valves and how well the engine was cared for, could be clean as a whistle or burnt brown with sludge, you'd never know! But, after 150K at the time, everything was still in spec
  4. Nov 27, 2016 at 7:27 AM
    WinSlow939
    Nate
    The Rock, Mass
    Speaking of fuel vapor...I'm noticing gas smell after shutting the truck off last couple days..just popped a code this morning (p0440, of course). took off the gas cap, no hiss so system isn't holding pressure. The problem is most of this shit is brand new...as in tank, charcoal canister, pretty much all the VSV's, gas cap. Besides hoses which can be a bitch to trace, any other areas you guys have found to be causing leaks? the filler neck looks pretty beat but I doubt thats it..
  5. Nov 27, 2016 at 10:26 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Smoke test is easier than blind speculation
  6. Nov 27, 2016 at 10:31 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Pretty much everyone including myself that actually checks their 3.4 valves at around the 200K mark find a couple barely out of spec on the tight side. Plenty of cases in the last few years right here on this forum. Would they go another 100K? Good question, many folks never touch them for 300K or more. Fewer others burn valves and crack heads. It does seem that the 3.4 tightens to a point and then stabilizes to a degree, unlike the 4cyls.
    I like to combine the check with other jobs like valve cover gaskets, cam seals/plugs, injector issues or knock sensor problems and go from there.
    That being said it is pricey to pay for this service by itself and few shops stock the shims required for adjustment so down time becomes a factor. Of course the future plans for the truck bear consideration as well.
    The 03-04 got better exhaust valve seats so "in theory" they should hold up even better.
  7. Nov 27, 2016 at 1:21 PM
    Crock112
    Crock112 Well-Known Member
    Crock
    New England
    '04 2.7l SR5 4x4 xtracab
    Damn it. I rotated my tires yesterday and apparently forgot to tighten some lugs before I drove it 3 hours home from my parents house. I got home- dropped off my wife and dog and then headed to the store. One mile from my house I got a crazy wobble and pulled over expecting a flat tire- lost 3 lugs on the rear drivers side and snapped a stud. Could've been much much worse, but still sucks. Can't believe I was that stupid. :frusty: Very thankful it didn't let loose with my wife and pup on board while we were doing 80 on the freeway.
  8. Nov 27, 2016 at 2:35 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Glad to hear this turned out ok. Could have been way worse. Your lesson was relatively inexpensive.
    I carry a torque wrench who's primary purpose is to make certain the lugs are correct. Be sure to tighten them in a star pattern and torque them to 85 ft/lbs.
    jubei and markelhof like this.
  9. Nov 27, 2016 at 2:35 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    I go 100 ft/lbs :anonymous:
  10. Nov 27, 2016 at 2:42 PM
    Digiratus
    Roaming the PNW
    The RedHead
    a 100 seems a bit high. The spec is actually 83.
    Holy schmidt likes this.
  11. Nov 27, 2016 at 3:51 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    Speaking of lugs, what do y'all think about aluminum lug nuts? No way in hell? Or should be just fine?
  12. Nov 27, 2016 at 4:12 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Took it on tree duty.
  13. Nov 27, 2016 at 4:16 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Ive never had a problem with them always using anti-seize. but theres really no need for them on a truck? or do you just want some anodized ones for looks.
  14. Nov 27, 2016 at 4:22 PM
    Captain Magma
    Captain Magma Well-Known Member
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Kings and desert pinstripes
    Conquered another fire road today. EAF.
  15. Nov 27, 2016 at 4:30 PM
    2002Tacoma4x4
    C K
    gray223 likes this.
  16. Nov 27, 2016 at 4:48 PM
    WinSlow939
    Nate
    The Rock, Mass
    Not quite blind, but still speculation I guess :thumbsup: I'm hoping for an easy fix, is all :D
    Speedytech7[QUOTED] likes this.
  17. Nov 27, 2016 at 5:05 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I would be concerned with the number of threads on the stud if you are using aluminium lug nuts with a thicker alloy wheel.
  18. Nov 27, 2016 at 5:32 PM
    TacoVio
    Kolton
    CO/WY
    I figured lol
  19. Nov 27, 2016 at 7:09 PM
    TheDude22
    TheDude22 Well-Known Member
    Destin, Florida
    White 04 Taco 5speed 4x4
    ARB bumper, Smitty bilt 1000 winch, KC fog lights, Custom rear bumper with tire swing. Toytec lift,
    Finally repainted my rear bumper. It looks so much better.IMG_0092.jpg IMG_0096.jpg
  20. Nov 27, 2016 at 7:17 PM
    NightProwler
    Harlan
    Maricopa, Az
    Plenty of threads. Have extended studs.
    Deathbysnusnu[QUOTED] likes this.
