  1. Dec 15, 2016 at 8:24 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Thought you were asking about CBs. The Yaesu FT-2900r is a Ham radio, not a CB.
  2. Dec 15, 2016 at 8:26 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I don't know if that one will pick up the channel all the people I run around with uses.
    Well heck I dunno they've always been called cbs around me.
  3. Dec 15, 2016 at 8:34 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I think you got your facts confused. A CB and a Ham are both radios with a mic and an antenna, but that is where the similarities end. Totally different in every other respect.
    You can't legally use a ham radio without an FCC license. You got one of those. If so, go with the yeasu.
  4. Dec 15, 2016 at 8:38 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yea dude you can use that radio without a license.
    You bought the wrong radio.
  5. Dec 15, 2016 at 8:38 PM
    JKO1998
    Utah
    Guess I'll get my shiz figured out and come back.
  6. Dec 15, 2016 at 8:39 PM
    JKO1998
    Utah
    Haven't made the purchase yet.
    I have a bigger list of stuff and things than I do wallet...
  7. Dec 15, 2016 at 8:49 PM
    Madjik_Man
    Colorado Front Range
    I have the Cobra 75 hand held. Control box is in my lower center console compartment, adapter is in my switch panel
  8. Dec 15, 2016 at 8:51 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Good. Then get the 520xl pro
  9. Dec 15, 2016 at 8:58 PM
    bayareayota
    bayareayota Well-Known Member
    Bay Area
    2004 Toyota Tacoma extra cab v6 Trd
    Prinsu 32" K02 OME
    Alright guys, you convinced me to go with the all pro!
    to be fair it was a very good deal.
    Now I am putting on the 2882 OME lift, which means I should be able to clear 285/75/16 yes?
  10. Dec 15, 2016 at 9:01 PM
    retroboy1989
    retroboy1989 Single Cab 4x4
    99 2.7L 5spd 4x4
    Finished my second cluster swap:
    Factory:
    98-00 Cluster:
    01-04 Cluster
    For those that are interested, clusters from mid 1997 through 2004 are interchangeable with the same number of cylinders. This is a plug and play mod. The 4 cylinder clusters with tach are fairly tough to find. Shameless plug: my black one is listed in the marketplace and has an open bid on eBay right now.
    The ONE minor issue I have had is that the fuel light on the white cluster is not functional because my truck, a 1999, is not wired for a fuel light. No big deal. I traced the circuit on the back of the cluster and found that the pin is unused in the connector. I suppose I could add a pin and run a wire to the sending unit in the tank.... if I have the sending unit. The irony is that I have a washer fluid light that is functional... :confused:
    Anyway, I very happy with this one because what do you see more than the cluster? What do you guys think?
  11. Dec 15, 2016 at 9:02 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    You can clear any size tire you want. Just depends on how much cutting you want to do.
    With 285 your going to have to do some trimming / bfh work if you want everything to fit when offroad.
    stumbles likes this.
  12. Dec 15, 2016 at 9:21 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Just happened. Chick next to me shat herself lol
    fiziks and BYJOSHCOOK like this.
  13. Dec 16, 2016 at 4:07 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Damn millennials :anonymous:
    Hate my generation :bananadead:
    because_wumbo-truck likes this.
  14. Dec 16, 2016 at 7:13 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    Don't we all
    jubei likes this.
  15. Dec 16, 2016 at 8:26 AM
    JKO1998
    Utah
    I was gonna put it on the roof or get a longer antenna and put it my bumper some how. I just need to figure out what radio I need to get.
  16. Dec 16, 2016 at 9:16 AM
    JKO1998
    Utah
    What ham radios do you guys run?
  17. Dec 16, 2016 at 9:51 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :facepalm:I told you and mike told you what radio to get...
    WildLand likes this.
  18. Dec 16, 2016 at 9:52 AM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
  19. Dec 16, 2016 at 10:01 AM
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    We're not all bad :D:anonymous:
    :anonymous:
    Listen to mike and monte :facepalm:
    Some people struggle in the listening department...:facepalm::annoyed:
    FirstGen Jer likes this.
  20. Dec 16, 2016 at 10:04 AM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    This is what I currently run... no complaints :notsure:IMG_4789.jpg
    :rofl:
