  1. Dec 29, 2016 at 5:45 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    If you're doing the lbj's and the uca's, you're right there where you need to be to replace the rack too. You'll have the tie rods ends off, might as well go a little farther.
    It's 3 bolts, one nut, a horseshoe shaped bracket, and the power steering connections. Then the splined shaft for the steering wheel.
    All very easy to get to.
    https://www.tacomaworld.com/threads/bretts-average-build-thread.305098/page-37#post-13538714
    I did a short write up, does not include the re-installation as it's really very straightforward. Goes back in the reverse order. I would just mention, before you install the new rack, make sure it's centered.
    If you reuse your otre's, count the number of turns to remove, and re-install the same number of turns on the new rack. And of course, when filling, do it with the engine off and cycle the steering wheel by hand and it will suck the fluid in and push the air out.
    Upon first start up, keep it short. Fire the engine and shut it off. Check the fluid level and don't be surprised if it drops, just top it off.
    I didn't even need an alignment when I was done.
  2. Dec 29, 2016 at 5:55 PM
    Madjik_Man
    Colorado Front Range
    So what happens if I sprayed a bit of TB cleaner into my throttle body (while still mounted) and some schmeg might have gotten into the IAC?
    I cleaned my MAF did that little diddy with the TB (yes, lazy) and now I'm throwing a P0120 code. Code is for a throttle position sensor which obviously could be the issue but I'm just thinking out loud in case it's not coincidence.
    Could the throttle butterfly be off a bit throwing this code?
    Plan is to remove the throttle body tomorrow and give it a real cleaning (even though it's not that dirty)
  3. Dec 29, 2016 at 5:56 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    How about a URD fuel injector?
  4. Dec 29, 2016 at 6:14 PM
    Macho Taco
    Macho Taco Member
    Brian
    2000 Tacoma prerunner
    Plasti dipped wheels badges and bumpers
  5. Dec 29, 2016 at 7:21 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Dude, thank you so much! I might just tackle this. Thank you!!! I know its possible.
    Im just being lazy..lol
  6. Dec 29, 2016 at 7:40 PM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    What size LED bar you got?
  7. Dec 29, 2016 at 8:14 PM
    Trigo
    Trigo Because fuck you that's why...
    Rodrigo
    San Diego
    1st gen
    Technically it's been months in the making so not today but it's almost done lol
  8. Dec 29, 2016 at 8:32 PM
    Macho Taco
    Macho Taco Member
    Brian
    It's a 42" curved
    FLBAdrian[QUOTED] likes this.
  9. Dec 29, 2016 at 9:24 PM
    jules04taco
    jules04taco Well-Known Member
    Trish
    PNW
    04 xtra cab 4x4 TRD
    Camburg UCA, Kings, URD short shifter, K & N performance air intake
    That's the official tow strap for our year/model of Tacoma!
    sente3[QUOTED] likes this.
  10. Dec 29, 2016 at 11:17 PM
    tacoRich87
    tacoRich87 Active Member
    What I've been doing last couple days.. ball joints in spindles were a pain to remove so if it wasn't for that would of went way smoother. Damn New England vehicles. (The whisky was defiantly necessary)
  11. Dec 30, 2016 at 6:48 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Tried to take it shooting but got stuck in the muddy muck of the farm fields. Was able to get it turned around and out but we opted to go back and get my buddies jeep since the mud was worse further down the trail.
    Pre runner problems :( :pout:
  12. Dec 30, 2016 at 6:50 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Pre-runner?
  13. Dec 30, 2016 at 7:28 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Yeah so I could run low range without engaging the blown front diff. Still saving for them gears. Not gonna lie it was a little emasculating getting stuck in easy shit.
    Fernando likes this.
  14. Dec 30, 2016 at 7:43 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    My problem was that I didn't know which direction we were supposed to go at a fork, and I stopped in the middle of a hill. Rookie mistake haha
  15. Dec 30, 2016 at 8:23 AM
    ocaldwell332
    ocaldwell332 Well-Known Member
    Owen
    2004 Silver Tacoma V6 PreRunner
    Well this happened today. Lift, wheels, and tires all installed.
  16. Dec 30, 2016 at 8:42 AM
    rodehard
    rodehard Active Member
    BKP
    2001 Tacoma Base
    K&N Intake. Gutted Cats. Slightly larger tires.
    Update for the seat belt cleaning, it really has made a huge difference. I did NOT do the spring re wind and only lubricated the internals by simply spraying the assembly with some wd-40 while working the seat belt. And of course the cleaning.
    But yea, this was by far one of the best things I've done for my truck. It reels itself back up at least most of the way every time and I have zero issue. When I take my belt off I just ensure it feeds the way it is supposed to and it all goes right into the housing where it is supposed to. And by this I mean I take it off in that direction.
  17. Dec 30, 2016 at 9:34 AM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    ill take it!
  18. Dec 30, 2016 at 10:54 AM
    retroboy1989
    retroboy1989 Single Cab 4x4
    99 2.7L 5spd 4x4
    I would drive that.
  19. Dec 30, 2016 at 10:55 AM
    retroboy1989
    99 2.7L 5spd 4x4
    Need to do this
    rodehard[QUOTED] likes this.
  20. Dec 30, 2016 at 11:26 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    you cant talk about getting your shit fixed :bananadead:
    Bennett707 likes this.
