  1. Jan 7, 2017 at 10:40 AM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    It wasn't the premixed. Shit was like cough syrup when I put it in lol. And blood red lol.
  2. Jan 7, 2017 at 10:53 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Sounds like you did it correctly, couldn't hurt to manually adjust them out some more (I would do it with the wheel off so you can spin the drum while you're doing it). If you do go too far and the drum locks up, just get something thin and pokey to push the adjuster arm off the star adjuster, then back it off with the screwdriver.
  3. Jan 7, 2017 at 11:10 AM
    retroboy1989
    retroboy1989 Single Cab 4x4
    99 2.7L 5spd 4x4
    I swapped my original thermostat last month. The rubber bellow thing was breaking apart and I was finding chunks of it under the radiator cap. My truck warms up so much faster now. I discovered it was hardly ever leaving warm up mode as my coolant temp was 20 degrees low. Instant cure to fast idle.
    jubei and TacoVio[QUOTED] like this.
  4. Jan 7, 2017 at 11:12 AM
    carofchoice
    carofchoice Well-Known Member
    Jeff
    Newton, IL
    2003 DC 4X4 TRD, 2012 X-Runner
    Finally got the rear completed.
  5. Jan 7, 2017 at 11:12 AM
    TacoVio
    Kolton
    CO/WY
    I think i saw that on the part diagram its a water seal or something behind the tstat right?
  6. Jan 7, 2017 at 11:13 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    My dealership actually offers 3 different Toyota coolant options. The correct one is dependent on the model year. There is a 50/50 pre-mix one that is for newer vehicles, but the correct one for our trucks is not a pre-mix one. It is red and thick as Kolton mentioned and you add water based on how cold the typical temps range.
    T-Stat is the first easy option but it could be the radiator too. If the coolant isn't circulating thru the radiator correctly, you will have the same symptoms you are seeing.
  7. Jan 7, 2017 at 11:32 AM
    TacoVio
    Kolton
    CO/WY
    Well I blew up The 00 radiator when I got the truck and I put my radiator on from my 04 which was the one from the wreck but it has been fine for over a year through other cold and over passes with no issues ever. I hope its just the tstat lol
  8. Jan 7, 2017 at 11:49 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Much thanks to @cynicalrider. For the abs help. Now if yall excuse me, its time to go romp on her!
    cynicalrider likes this.
  9. Jan 7, 2017 at 11:54 AM
    TrailRider2002
    TrailRider2002 Well-Known Member
    Cameron
    Powdersville, SC
    02 Tacoma 4x4
    -3in old man emu suspension lift with 882 coils, nitro chargers and rear add a leaf -1in Daystar Body lift -295/75 BFG KO2'S -flowmaster dual 40s
    Don't really get snow down here so when we do I try to make the most of it :bananadance:
  10. Jan 7, 2017 at 12:19 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    We didn't get jack shit for snow :pout:
  11. Jan 7, 2017 at 12:54 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    My truck is currently in hiding under about 14in of snow. Kinda afraid of what'll I'll find when I finally excavate it tomorrow.
  12. Jan 7, 2017 at 12:55 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    getting my snow tonight!
  13. Jan 7, 2017 at 1:08 PM
    Speedytech7
    How much are you supposed to get? It has been pretty brutal for the inland northwest this year. At least by our usual snow amounts.
  14. Jan 7, 2017 at 1:15 PM
    devinzz1
    devin
    2023 aclb trd or mt
    just calln for 20-30
  15. Jan 7, 2017 at 1:22 PM
    Speedytech7
    Mm,Cm, in, meters, yards, feet, kilometers, miles?
    Taco Addiction likes this.
  16. Jan 7, 2017 at 1:23 PM
    devinzz1
    devin
    2023 aclb trd or mt
    Centimiles
  17. Jan 7, 2017 at 1:25 PM
    Speedytech7
    You people in the Republic of Kanukistan use confusing units.
    nagorb likes this.
  18. Jan 7, 2017 at 1:39 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    "Snowed" here too. :rolleyes: Cold as balls though.
  19. Jan 7, 2017 at 2:14 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    went out in the snow (which a lot of people did today apparently lol)
  20. Jan 7, 2017 at 2:16 PM
    Speedytech7
    Light it on fire and walk away!
    The Durango I mean
