  1. Jan 11, 2017 at 1:25 PM
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Yea that's exactly what I thought so we did but still made a squeak. Thinking it may be a bearing or something
    The lca bushing does suck and causes the truck to kinda wander when braking but I'll do them this summer and possibly burn or drill the bushings out. Mine are probably fused together :bananadead:
  2. Jan 11, 2017 at 1:26 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    new belts tend to take a bit to quiet down too. But could easily be an idler pulley too. the AC one is common since its low and can get dunked a lot.
    snowboard704[QUOTED] likes this.
  3. Jan 11, 2017 at 1:27 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    The AC pulley is the one that went for me. Got an OE replacement the next day all good. Easy fix.
    But start with cheaper stuff, like tightening the belts a bit more
    snowboard704 likes this.
  4. Jan 11, 2017 at 1:28 PM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Thanks I'll keep it in mind!
    Usually goes away and quiets down a bunch once warmed up also
  5. Jan 11, 2017 at 1:30 PM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    Yes, but I found if you cut it at the y-pipe on the passengers side as long your nuts/studs come out fine on the engine it's just a matter of maneuvering to get both sides out. One cut and cut the bolts that connected both cats and it came out, unfortunately I wasted a whole hell of a lot of time trying to get the nuts off the y-pipe which were frozen...soaking them heating them up. I should of just listen to Gadget and cut it out from the beginning :facepalm:
  6. Jan 11, 2017 at 1:34 PM
    01MUD.TACO.SC.V6
    01MUD.TACO.SC.V6 Well-Known Member
    Clive
    MAXWELL AFB
    01 Tacoma 4WD SR5 Supercharged
    TRD Supercharger, URD 7th Injector Kit, 2" Body Lift, Rear Manual Air Bag Suspension, Marlin Crawler Rear Bumper
    what brand of headers did you go with?
  7. Jan 11, 2017 at 1:42 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    In jbas instructions they just straight up tell you to cut off stock crossover. I snapped every single stud off mine ahaha. Unfortunately i didnt have any shinny new headers to put back on and had to suffer through drilling the studs out with a 12" bit and hand drill
    QMEDJoe[QUOTED] likes this.
  8. Jan 11, 2017 at 2:23 PM
    TheDude22
    TheDude22 Well-Known Member
    Destin, Florida
    White 04 Taco 5speed 4x4
    ARB bumper, Smitty bilt 1000 winch, KC fog lights, Custom rear bumper with tire swing. Toytec lift,
    Finally came up with my own way to mount my jack. Will probably mount a shovel/axe on there too.
  9. Jan 11, 2017 at 2:27 PM
    QMEDJoe
    Joe
    TRD, there still available at Bev Smith Toyota in Fl.
    http://m.ebay.com/itm/261651782417
    They're the ones for the 95-98's. The only thing different is the y-pipe. From '99 on w/ the 1st gens they went with 2 cats so the y-pipe had to be shorter. But you can modify after the y-pipe and it'll work. I happen to find the y-pipe that corresponds to the 99-04's. All I have to do is cut the 3 bolt flange on the cat and weld a 2 bolt flange and it'll be good to go
  10. Jan 11, 2017 at 2:29 PM
    QMEDJoe
    Joe
    That sounds absolutely terrible! I've snapped a few studs/bolts at work. Easy outs do not like me
  11. Jan 11, 2017 at 2:38 PM
    Madjik_Man
    Colorado Front Range
    More info and pics please.
    Thanks
    jjsul likes this.
  12. Jan 11, 2017 at 3:28 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Looks good.
    What he said. ^^^
    jjsul likes this.
  13. Jan 11, 2017 at 3:39 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Currently stuck!
    Been digging for an hour or so, chained up and such. No luck. Have someone coming up to give me a pull.
    Just letting everyone know it is possible to get stuck.
  14. Jan 11, 2017 at 3:41 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Take pics and vids dammit!
    jjsul likes this.
  15. Jan 11, 2017 at 3:41 PM
    JKO1998
    Utah
    Awwwww
  16. Jan 11, 2017 at 3:41 PM
    Speedytech7
    Also use your floor mats as traction aids.
    jjsul likes this.
  17. Jan 11, 2017 at 3:45 PM
    JKO1998
    Utah
    Like I said, I've dug, chained up, locked my diff, all said things.
    I literally got too far to the right 4" and just get sucked off the road, driver error, my fault, yell at me, call me dumb, tell me what you would have done.
    You know the TW way.
    Help is on the way.
    BYJOSHCOOK, QMEDJoe, jubei and 5 others like this.
  18. Jan 11, 2017 at 3:45 PM
    JKO1998
    Utah
    I did the back up and forward thing and that's why my back end is farther in.
  19. Jan 11, 2017 at 3:47 PM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    Yupp. Looks stuck to me.
  20. Jan 11, 2017 at 3:48 PM
    JKO1998
    Utah
    Hoping for that Grader now
    Jarob11 and sente3[QUOTED] like this.
