  1. Jan 16, 2017 at 2:15 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    So for the grey all you can do is change the rotor wipers now?
  2. Jan 16, 2017 at 2:15 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Not the same rotors? Wow that's surprising.
    But you can get a full rebuilt from magneson if you have a 2nd gen blower then.
  3. Jan 16, 2017 at 2:23 PM
    1997tacomav6
    Denver
    You can get a full rebuild from lots of different companies but if your rotors are worn out then you might have a problem finding new rotors
  4. Jan 16, 2017 at 2:32 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    How much does a full r3build run? I have a 2nd Gen SC btw.
  5. Jan 16, 2017 at 2:37 PM
    License2Ill
    Ian
    GTK. Thanks.
  6. Jan 16, 2017 at 3:02 PM
    GreenMachine8
    GreenMachine8 Well-Known Member
    Elko, NV
    1996 Olive Drab Tacoma DLX 2.7L 4X4
    Off road fiber glass, rhino lined olive drab, retrofit headlights, kings/total chaos mid travel suspension.
    UPS man brought some goodies as I was workin on the truck :D
  7. Jan 16, 2017 at 3:11 PM
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    Do you guys think a 750cca oriellys battery will hold up to a 9.5xrc winch with and extra 6ga cable running straight from alt to the battery
    Or
    Should I do the cs-144 alt? Or dual batts?
  8. Jan 16, 2017 at 3:13 PM
    1997tacomav6
    Denver
    I like yellow top optima battery
  9. Jan 16, 2017 at 4:45 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Crusty snow slows things down a little, could have made it through but didn't really need to go any farther.
    Yes my bumper sticks out far on the sides,
    Thank you.
  10. Jan 16, 2017 at 4:48 PM
    retroboy1989
    retroboy1989 Single Cab 4x4
    99 2.7L 5spd 4x4
    I wonder if your adventures have anything to to with your crappy mpg...:rolleyes:
    Holy schmidt likes this.
  11. Jan 16, 2017 at 4:50 PM
    JKO1998
    Utah
    For sure could. When I brought that up I was really only talking about the times I knew I spent 95.99% of my tank on the pavement in 2 wheel drive.
  12. Jan 16, 2017 at 4:53 PM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
  13. Jan 16, 2017 at 4:58 PM
    Speedytech7
    I'm not sure about him, but anytime there's shitty weather or I go on a trip MPG becomes a fun stat not an important stat.
    JKO1998 likes this.
  14. Jan 16, 2017 at 4:59 PM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    [​IMG] check your local Sam's Club for cheap Optimas
  15. Jan 16, 2017 at 5:10 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Any Tacoma will benefit from a larger alternator. My stock one strains at idle to do my windows..
  16. Jan 16, 2017 at 5:11 PM
    JKO1998
    Utah
    I don't ever really care about it, it is what it is. But if there's something fixable on on my truck and it's negatively effecting my mileage, I'd like it fix it. :)
  17. Jan 16, 2017 at 5:48 PM
    TacomTyler
    TacomTyler Well-Known Member
    Tyler
    Georgia
    2000 sr5 tacoma
    Finally finished my truck today, new timing belt, water pump, thermostat, tensioner, idler, drive belts, valve cover gaskets, spark plugs and wires, tube seals, rear axle seals and shoes. Hopefully I'm good to go for a good while!
  18. Jan 16, 2017 at 6:05 PM
    99toytacotrd
    99toytacotrd Member
    groves
    1999 toyota tacoma
  19. Jan 16, 2017 at 6:27 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    It's an addicted off-road tube bumper.
    nibster11111 and jubei like this.
  20. Jan 16, 2017 at 6:41 PM
    GreeGunc
    Jacob
    North GA
    Thanks guys, guess I'll go ahead with it
