  1. Jan 20, 2017 at 8:04 AM
    Penten
    Penten Well-Known Member
    Peter
    Iowa
    See that cylinder on the right ? Next to the headlight . It's the line right on top of it . And it goes into another line connected with a big nut
  2. Jan 20, 2017 at 8:16 AM
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    @m3bassman
    @sente3
    @Blackdawg
    Thank you guys! My whole life I've ran my mirrors just off the body. On my way to work today I set them out more like you guys suggested and it's really cool! It's so simple but yet something I've overlooked. It does take some getting used to but it's very effective. And you can still see down the body when you lean into it. Anywho wanted to extend a thank you. It's what this community is about. Helping each other out, networking, sharing ideas.....Now just because I had my mirrors slightly off adjustment does that make me scum unworthy of a driver's license? Lol. Actually I went to the Jason Bourne School of High Performance Driving but they didn't teach proper side view mirror adjustments.
    @koditten
    I see you behind that keyboard.......
    Also put these tie downs in over the weekend. After I put the glass on and tool box I had trouble finding easy tie downs for whatever I haul because the box blocked the cab side ones off. They pop out when needed and push down flat when not being used. Put two in the box too.
  3. Jan 20, 2017 at 8:31 AM
    j0shu4
    Hey man got a question. Ive got the ARB compressor too and last time I went up it took forever to inflate the tires using the pump alone and deflate. Pretty sure I know the answer to this but that tank would greatly increase inflation time correct? Wondering if it has enough capacity to fill 4 35'S. Also is there some sort of speedy deflation device that you can screw onto the tire stems?
  4. Jan 20, 2017 at 9:11 AM
    bayareayota
    bayareayota Well-Known Member
    Bay Area
    2004 Toyota Tacoma extra cab v6 Trd
    Prinsu 32" K02 OME
    Arb makes a rapid tire deflator , and some companies make ones were you set your desired psi and the tire will automatically stop once that number is reached
    j0shu4[QUOTED] likes this.
  5. Jan 20, 2017 at 9:17 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I have both Staun style deflators and the arb deflator and both have their uses IMO. If you have a set PSI you always use when you go wheeling or whatever the Staun style is great. You set them ahead of time, then when time to wheel you screw them on and let them deflate to the desired pressure. If set properly they will stop at whatever you set them to. This is great especially on reallly cold days when you don't want to be outside fucking with manually deflating each tire. Problem is they are on the slower side. They deflate every tire at once but over maybe 10 minutes or so. Your other option is the ARB deflator with guage. You screw it on, remove the valve stem in a safe manner, and let air out FAST. I got my 35 from 33psi to 10psi in probably less than 30 seconds last weekend. Then you screw the valve stem back in and that tire is good to go. Great for when temps are better or you want to be very picky on what PSI you set it to.
    jubei, Tacofart and j0shu4[QUOTED] like this.
  6. Jan 20, 2017 at 10:00 AM
    j0shu4
    Good stuff. Thx gents. ^^^^^^^
  7. Jan 20, 2017 at 10:24 AM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    I didn't do much, but this punk tried getting in my truck last night/early this morning.
    E1BD62F2-F17E-4AE4-B584-8266CC35D44B_zps_196ca72759d154ac5aeaa00eed9ecbb4d4a8a28b.jpg
    TrailRider2002 likes this.
  8. Jan 20, 2017 at 10:32 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    ^punishable by death
  9. Jan 20, 2017 at 10:38 AM
    2004TacomaNavy
    2004TacomaNavy Well-Known Member
    Brian
    Oak Harbor, WA.
    04 Extra Cab 4X4 SR5
    All Pro rock sliders, U-Bolt flip kit, Shock mount relocation tabs, All Pro Billy 3" lift front and back, 2014 Tundra Bed Rail tie down system, Fuel 17X8.5 Wheels on 32's, LED front light bar, Raptor style grill W/lights, Tinted Headlights w/LEDs, ARB Dual Air Compressor W/ 2 Gal. Tank, Smoked Tail Lights, Double Din Sat radio w/ back-up camera, Redline Hood Struts, ARB Dual air compressor W/ 20 Gal. air tank, Sig P320C Security System!
    Yes, the tank will help a lot with inflation time. It will also allow me to seat a bead if it comes off.
    I use the ARB Tire deflator and its awesome! Really quick. Screw it on the valve, remove the stem and away you go.
    https://www.amazon.com/ARB-ARB505-E-Z-Deflator/dp/B004LQCDOA
    https://www.youtube.com/watch?v=mnKF-yG9wDE
  10. Jan 20, 2017 at 10:53 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
  11. Jan 20, 2017 at 10:54 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Look at mr.fancy with his mirrors that move by way of the dancing pixie
  12. Jan 20, 2017 at 11:15 AM
    j0shu4
    Naw man. From the heart.....even though I built my full LT turbo Taco pretty much by my self the mirrors were a thing of great mystery.....lol.
    rngr and LogCabins like this.
  13. Jan 20, 2017 at 12:43 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    IMG_0297.jpg Supposed to snow for the next 4 days, so I took it out in the sun while I could.
  14. Jan 20, 2017 at 12:45 PM
    LogCabins
    LogCabins Well-Known Member
    Robert
    Oahu
    99 SR5 3.4L 4WD
    You should hit up @LSC15 (Logan) for some retros
  15. Jan 20, 2017 at 12:47 PM
    JKO1998
    Utah
    Too poor. Only had a job for a week.... maybe someday.
  16. Jan 20, 2017 at 12:48 PM
    LogCabins
    Robert
    Oahu
    99 SR5 3.4L 4WD
    understood....looks like you can make some money shoveling snow in the next 4 days :D
  17. Jan 20, 2017 at 12:54 PM
    JKO1998
    Utah
    There's a good chance for sure.
  18. Jan 20, 2017 at 1:25 PM
    robupstateny
    robupstateny Well-Known Member
    Rob
    Upstate NY
    2003 Lunar Mist Tacoma DLX
    Gray wire mod, Gentex 177 mirror, cupholder from @bradrn22, custom dog seat., AJT Design shift knob., Cb install
    03 yota cup holder1.jpg Finally got my cup holder in03 yota mirror upgrade.jpg And the mirror
    03 yota dog bed.jpg And the kid's got some where to sit
    jjsul and Taco Addiction like this.
  19. Jan 20, 2017 at 1:51 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Fab up my new air intake pipe. Very little differance in noise level vs stock ( starting to crack at throttle body ) air pipe
  20. Jan 20, 2017 at 1:58 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I put new wheels on and drive to Montana for work
    These things are so badass
