  1. Jan 22, 2017 at 1:19 PM
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    How many should a 488 have when counting? And is there anyway to test the locker itself? Hook air up to it possibly?
  2. Jan 22, 2017 at 1:46 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Been a good day for taco spotting around my neck of the woods. Seen a couple 1st gens with bumpers that were really unique. Wish I had seen them parked so I could take a pic.
  3. Jan 22, 2017 at 2:10 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    On my phone and can't remember teeth count. I'll get back on that. But yea. Hook it up to air and check for leaks.
    snowboard704[QUOTED] likes this.
  4. Jan 22, 2017 at 2:20 PM
    retroboy1989
    retroboy1989 Single Cab 4x4
    99 2.7L 5spd 4x4
  5. Jan 22, 2017 at 3:47 PM
    mountain mike
    mountain mike Woodsbum
    the backwoods...
    2003 DCSB 4x4
    just what I need to do what I want
    It's not that hard, just a little nerve-racking! I made a template of the lights, measured twice for equal distance from license light and the plastic bumper cover that hangs down over the edge, and to make sure they were level.
    I think it is 4 1/4" from the light and 1/2" down from the plastic cover. I used a Mikita angle grinder with 4" cut off wheels from Harbor Freight (get the 10 pack). Just be careful the grinder will want to "take off" while working in one direction versus the other based on the rotation of the grinder. Then just drill 4 holes-the lights did NOT come with mounting bolts and nuts. A quick trip to the hardware for 8 allen head bolts and lock nuts and was mounted. I used t-taps to tie into the green wire for the stock reverse lights, ran 14 ga wire, then used heat shrink to seal them all. Super bright. I hope this helps.
    JKU3000[QUOTED] likes this.
  6. Jan 22, 2017 at 3:51 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    For cuts in.thin.metal like that you can use a jigsaw with a metal blade. Drill holes at corners for start points.
  7. Jan 22, 2017 at 4:05 PM
    mountain mike
    the backwoods...
    2003 DCSB 4x4
    Yes that will work also, but a grinder is waaayyy faster. I did mine and my buddies, all 4 cuts, in like 15 minutes. Maybe practice on some scrap metal first.
    JKU3000 likes this.
  8. Jan 22, 2017 at 4:12 PM
    LifeOverTheEdge
    LifeOverTheEdge Well-Known Member
    Hackettstown, NJ
    2004 Tacoma Xtra Cab 2.4l 5 Lug Auto
    A whole lot
  9. Jan 22, 2017 at 5:43 PM
    wht95scort
    wht95scort Well-Known Member
    NJ
    2001 3.4 gas guzzler
    IMG_3606.jpg IMG_3614.jpg IMG_3616.jpg Installed some mini led's into the cup holders and console box. It matches the factory color perfectly. Also installed the GTA Bluetooth kit into the factory radio which I highly recommend.
  10. Jan 22, 2017 at 5:46 PM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    I quite like this. Where'd you get them & how did you install them?
    Also, you should replace the rubbery bits in the cupholders. They help a lot.
  11. Jan 22, 2017 at 5:54 PM
    wht95scort
    NJ
    Got them off eBay. Search 3mm orange led. Just make sure you get the ones with the black housings. I wired them to the shifter light. They will also dim with the dimmer knob. +1 on the rubber thingies
  12. Jan 22, 2017 at 6:03 PM
    sente3
    sente3 -
    North Jersey
    Hmm a bit of trouble for me, then. I've got a manual trans. So no shifter lights lol
    FLBAdrian and robupstateny like this.
  13. Jan 22, 2017 at 6:04 PM
    robupstateny
    robupstateny Well-Known Member
    Rob
    Upstate NY
    2003 Lunar Mist Tacoma DLX
    Gray wire mod, Gentex 177 mirror, cupholder from @bradrn22, custom dog seat., AJT Design shift knob., Cb install
    I was just thinking the same thing. :rofl:
  14. Jan 22, 2017 at 6:08 PM
    ToxicTwin
    ToxicTwin Money Talks...It Says Goodbye
    Robert
    Glendale AZ
    2009 TRD OR
    Sweet thanks.
    Scoobarooo[QUOTED] likes this.
  15. Jan 22, 2017 at 6:15 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    From what I've seen, either the ratio (4.88) or teeth counts will be stamped on the outside of ring gear. 4.88 should be 39/8
  16. Jan 22, 2017 at 6:18 PM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Okay thanks get back to me on that
    Roughly how much psi?
  17. Jan 22, 2017 at 6:19 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    90PSI is what is used on ARBs.
  18. Jan 22, 2017 at 6:20 PM
    devinzz1
    devin
    2023 aclb trd or mt
    80-100
  19. Jan 22, 2017 at 6:29 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  20. Jan 22, 2017 at 6:32 PM
    wht95scort
    NJ
    Tap into the cig light.
