  1. Jan 25, 2017 at 8:05 PM
    Isais101
    Isais101 Active Member
    Got a new to me tool box today $100 of Craigslist
    jubei and LogCabins like this.
  2. Jan 25, 2017 at 8:06 PM
    Isais101
    What you think
    jjsul and j0shu4 like this.
  3. Jan 25, 2017 at 8:07 PM
    Isais101
  4. Jan 25, 2017 at 8:09 PM
    Isais101
    And it was a nice day here in the Inland empire so I washed my truck
  5. Jan 25, 2017 at 8:23 PM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    San diego got some snow, had to get some before its gone, was super jealous of everyone else wheeling in powder! IMG_4548.jpg
  6. Jan 25, 2017 at 8:29 PM
    Captain Magma
    Captain Magma Well-Known Member
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Kings and desert pinstripes
    Laguna?
  7. Jan 25, 2017 at 8:49 PM
    Prayn4surf
    Socal
    Yep, most every trail was closed off so had to get in some snow where you could
  8. Jan 25, 2017 at 8:57 PM
    Katchaser00
    Katchaser00 Well-Known Member
    Luke
    10,000 lakes
    Took my '02 Tacoma into tire shop this evening as I had a small leak in one of my tires and decided to just get a rotation/balance while I was at it. The tire guy says my right rear wheel was loose when they were tinkering with it... then sure enough I get back on the highway after the tire shop visit and as I go over 60mph, my truck starts to rattle and shake worse than it ever has(tires were not fully inflated before going to the tire shop so I didn’t feel it as much). It’s nothing crazy, but it’s annoying. Everything looks fine, but wondering if it’s time to replace some key parts. Could it be the Rear ball-joints? Tie-rods? Any help would be appreciated!
  9. Jan 25, 2017 at 9:13 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    Maybe a wheel bearing? Jack it up and start moving things around and looking for play could also be that your wheel is bent a bit, and theres No ball joints in the rear
  10. Jan 25, 2017 at 9:23 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    Do it, maybe you'll be the first :p eBay bars are good to experiment with
  11. Jan 25, 2017 at 9:26 PM
    Katchaser00
    Luke
    10,000 lakes
    Yeah not sure. The tire guy was throwing all kinds out in the air, so I took it all with a grain of salt. Probably a wheel bearing. Ill do some more checking tomorrow in the daylight. Thanks man!
  12. Jan 25, 2017 at 9:38 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Link?
  13. Jan 25, 2017 at 9:46 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Good luck. You'll be cutting sheet metal to make them fit. There is about 1/4-maybe 1/2'' of space behind those filler plates.
  14. Jan 25, 2017 at 9:49 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    Anybody know if I'm gonna have to compress the springs to do 5100s 881s and the 10mm spacer?
  15. Jan 25, 2017 at 9:53 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not really. I have a 96. But even once you take out the plastic you'll have maybe an inch or 1.5''. You'll be cutting the core support to get them flush mounted. Be cool if you can get it to work though and fit nice.
  16. Jan 25, 2017 at 9:53 PM
    fiziks
    fiziks Well-Known Member
    Isaac
    El Paso TX
    01 DC Prerunner 4x4 5pd Conversion
    5 sp 4x4 conversion, OME lift, SCS F5s
    Care to point me in the right direction? I can't seem to find it on their page.
  17. Jan 25, 2017 at 9:57 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Also possible. Hope it works!
  18. Jan 25, 2017 at 10:34 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Kinda bummed because it looks like they simplified their response in the FAQ... This is from their FAQ now...
    The problem is that they are hydrophillic. This essentially boils down to meaning they can attract water and bond with it. So in an instance where water can enter (breather tube, condensation, axle seals) it will become chemically joined to the oil. Dino oil is hydrophobic and when the gearset creates heat will allow the water that is suspended (not bonded) to eventually evaporate. The reason this isn't an issue in engines is heat, and it really isn't an issue where large amounts of water can't enter either. I am by no means a chemist so I hope my rudimentary explanation is enough to spur you to further research it from those more informed.
    jubei likes this.
  19. Jan 25, 2017 at 10:37 PM
    Speedytech7
    No ball joints or tie rods on the rear end. That really only leaves the rear bearing or a bent wheel.
    Katchaser00[QUOTED] likes this.
  20. Jan 25, 2017 at 11:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    or the CB, or an axle shaft or axle bearing
    Katchaser00 likes this.
