  1. Jan 25, 2017 at 11:03 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    He said the wheel was wobbling though so wouldn't that rule out a CB? Although yeah the possibility for a bent shaft is certainly there.
    Katchaser00 likes this.
  2. Jan 25, 2017 at 11:04 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Oh.
    I mean if he can see the wheel wobbling..then something major is fucked up and i wouldn't be driving it at all. A simple wheel swap will tell if its the wheel or the hub/axle.
  3. Jan 26, 2017 at 5:38 AM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    Depends who you are getting them from, sometimes you can get them pre assembled but otherwise yes you'll have to compress the 881s
  4. Jan 26, 2017 at 6:55 AM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Is our corner light replacement bulb a 3157?
  5. Jan 26, 2017 at 6:58 AM
    robupstateny
    robupstateny Well-Known Member
    Rob
    Upstate NY
    2003 Lunar Mist Tacoma DLX
    Gray wire mod, Gentex 177 mirror, cupholder from @bradrn22, custom dog seat., AJT Design shift knob., Cb install
    my front side marker on the 03 is a 168, switched to a 194 cause its what I had.
  6. Jan 26, 2017 at 7:09 AM
    Katchaser00
    Katchaser00 Well-Known Member
    Luke
    10,000 lakes
    Yeah luckily there aren't too many parts in the rear that could be the culprit. After work today ill have to jack it up and see whats going on. I don't think its a bent wheel, as the tire guys would have probably caught that when they were going through it. I am putting my money on the rear bearing, but we will see. I haven't noticed any major noises coming from the rear end though, really only a constant, but mild "sway" will driving hwy speeds, and now after proper inflation last night, a vibration/shake when getting up to 60+mph. So it's more noticeable now. Thanks for your help sir!
  7. Jan 26, 2017 at 7:15 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Eh I'd say it's only worth it if you really need the extra clearance to play in some gnarlier rocks. It's not just cutting up your truck, it's the gearing and shit that needs to go with it, not to mention the extra wear you will likely see on all bearings due to the massive BS you need to make it happen. Not for the faint hearted or those with limited funding.
    jubei likes this.
  8. Jan 26, 2017 at 7:15 AM
    Katchaser00
    Luke
    10,000 lakes
    Yeah the tire guy said it was just a little loose, but nothing to invoke not driving 'till its fixed. Not going to take his words 100 percent, but made me feel a little at ease. Ill have to tinker with it later today and see what's up. Honestly might not hurt to go through all four corners and replace key components anyways. I'm not sure the last time any of that stuff has been fixed since I bought the truck last year.
  9. Jan 26, 2017 at 7:25 AM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Awesome. Thank you.
  10. Jan 26, 2017 at 7:35 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Im not worried about much of that besides the regearing. I can get some 4.56 diffs off a buddy for a few hundred buckaroos. Not exactly 4.88s or 5.29s but better than 3.91s.
    Wel see. Wel see
  11. Jan 26, 2017 at 7:37 AM
    robupstateny
    Rob
    Upstate NY
    20170126_102132.jpg Got my filters in from Toyota of York. It's really to bad they got shut down and booted out of TW. A big thanks to Jeff Kish for hooking me up CHEAP!
    FLBAdrian likes this.
  12. Jan 26, 2017 at 7:45 AM
    robupstateny
    Rob
    Upstate NY
    20170126_103929 (1).jpg Wow like christmas here today. LOL. Just waiting on the firestik and the mount from cbi offroad. :bananadance:
    Taco Addiction likes this.
  13. Jan 26, 2017 at 7:54 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Why'd they get booted?
  14. Jan 26, 2017 at 7:57 AM
    robupstateny
    Rob
    Upstate NY
    According to Tcbob they don't want anyone else selling new parts at this time.
  15. Jan 26, 2017 at 7:57 AM
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    What do you guys recommend for an air tank to be able to fill 4 35" tires after deflation? How many gallons? 2, 3, 4......Found a 3 gallon for like $60 with some fittings.
    http://m.ebay.com/itm/3-Gallon-Air-...on-WITH-all-fittings-/371655159936?nav=SEARCH
    Got some auto brass deflators for $9.....
    http://m.ebay.com/itm/6-30-PSI-4WD-...rkt%3D25%26sd%3D281765060710&_trksid=p2056116
    And a quick deflators with gauge for $24
    www.amazon.com/gp/aw/d/B00NQGCDC8/ref=ya_st_dp_summary
    Fernando likes this.
  16. Jan 26, 2017 at 8:00 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Air tanks don't really help for filling tires. The best way to fill a 35'' tire is CO2.
    An air tank on the rig is useful only to run air tools really. Which CO2 can do as well.
    The dual ARB compressor is the way to go for filling tires and air tools though if you wanna stay with a compressor. Takes about 1:30 to do a 35. Takes about 30 seconds with co2
    j0shu4[QUOTED] and Fernando like this.
  17. Jan 26, 2017 at 8:01 AM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Could you PM me contact info ?!
  18. Jan 26, 2017 at 8:01 AM
    j0shu4
    Good to know......got the h.o. arb compressor but it took f'ing forever to fill em.
  19. Jan 26, 2017 at 8:03 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    haha could be worse...trust me. Least you're not trying with a tiny compressor.
    Thats why i love the CO2. Its freaking fast. Less time wasted on that chore.
    nudavinci64 likes this.
  20. Jan 26, 2017 at 9:05 AM
    PROseur
    Pussy
    For the guys that have rear spare on the bumper who makes that ?
    because_wumbo-truck likes this.
