  1. Jan 30, 2017 at 12:22 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    You aren't missing out
  2. Jan 30, 2017 at 12:23 PM
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Anyone run first gen tundra ebc rotors with the tundra calipers on your first gen or overkill?
    Been looking at the tundra upgrade (rotors/calipers) but wondering if doing that plus going to ebc pads will be worth it :notsure:
  3. Jan 30, 2017 at 12:27 PM
    bayareayota
    bayareayota Well-Known Member
    Bay Area
    2004 Toyota Tacoma extra cab v6 Trd
    Prinsu 32" K02 OME
    It's behind the interior fuse block
    At the top .
    Pull the lower panel under the steering wheel and then reach up and around behind the fuse block .
    MtRSQ[QUOTED] likes this.
  4. Jan 30, 2017 at 12:38 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    That's what I'm doing
    snowboard704[QUOTED] likes this.
  5. Jan 30, 2017 at 12:38 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    I'm running tundra brakes with EBC slotted rotors and green stuff pads. If you're going through the trouble of a brake upgrade, you might as well go all the way. It makes a big difference, especially with bigger tires. Don't bother with trying to upgrade your booster/MC though :anonymous:
    cruiserguy likes this.
  6. Jan 30, 2017 at 12:40 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    You got part numbers for the pads? I've found 2 different ones and not sure which is correct.
    Also which calipers and brake lines did you go with?
  7. Jan 30, 2017 at 12:45 PM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Cool, are the brake line end fitting, that goes into the new caliper the same as the stock taco caliper. Just asking because I already got stainless lines made for it now
    Think it's a banjo fitting
  8. Jan 30, 2017 at 12:45 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    They are 13wl calipers, napa remans. Brake lines are wheelers extended, had to use a couple copper washers to get the banjo bolt to seal correctly but no issues since.
    P/N for the pads is DP61657 - 6000 series
    BYJOSHCOOK[QUOTED] likes this.
  9. Jan 30, 2017 at 12:47 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yeah they are taco lines with a banjo fitting, I know the wheelers ones will work but you'll have to check your specific fitting.
  10. Jan 30, 2017 at 12:48 PM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    They should fit. If the tundra rotors takes a banjo fitting as well as the Tacoma the end fitment should be the same.. in theory
  11. Jan 30, 2017 at 12:52 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    drr[QUOTED] likes this.
  12. Jan 30, 2017 at 12:58 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Glad to know i wasn't the only one.
  13. Jan 30, 2017 at 1:00 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yeah I think I went way past the torque spec on those lol. No problems though.
  14. Jan 30, 2017 at 2:22 PM
    tacomatrd22
    tacomatrd22 TRD SuperCharged Tacoma
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    FlowMaster Super 44 2" lift Gray wire Fog light
    Maybe someday in the future you'll might see one than they start to multiply. That's what happened to me 4 years ago.
  15. Jan 30, 2017 at 2:23 PM
    CStoy
    CStoy mountain-top maniac.
    majestic gold 4x4... 1/4 million miles and counting!
    improved toyota goodness.
    mine bolted straight into the tundra calipers with no modifications to line or bolt- I did use new crush washers- but I just reused my factory lines as they where toyota OEM and brand new when I had the frame replaced not long before and I was not planning to lift it.
    one of my favorite mods to date; huge improvement in stopping power over stock!
  16. Jan 30, 2017 at 2:26 PM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Sounds good, braking feeling a little on then not so touchy side lately. Hoping I don't have a small leak somewhere
    Or mc going out :bananadead:
  17. Jan 30, 2017 at 2:54 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    found a nice sunset view and then went to NYC last night
  18. Jan 30, 2017 at 4:46 PM
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    I'm changing out my hawk pads for oem. The hawk pads always made my tires and wheels red from the dust. Real annoying.
  19. Jan 30, 2017 at 5:01 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    Can confirm. My wheels look like they've been powder coated in a nice rust color.
    kigmob[QUOTED] likes this.
  20. Jan 30, 2017 at 5:05 PM
    TrailRider2002
    TrailRider2002 Well-Known Member
    Cameron
    Powdersville, SC
    02 Tacoma 4x4
    -3in old man emu suspension lift with 882 coils, nitro chargers and rear add a leaf -1in Daystar Body lift -295/75 BFG KO2'S -flowmaster dual 40s
    What type of transmission fluid should I refill with?
