  1. Feb 4, 2017 at 8:27 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    285s are not close to a 34''..barely a 33''..
  2. Feb 4, 2017 at 8:31 AM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Do people run 33 on stock suspension ?
  3. Feb 4, 2017 at 8:34 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well technically, if you want to actually USE your suspension, as in the full travel. You have to make it clear. Remember a lift doesn't allow for bigger tires really. I mean it's not changing the geometry of the suspension. So if you want to stuff a 33'' tire, it doesn't matter what suspension you have. Stock stuffs the same as kings and UCAs would.
    So...yea you can. Might rub a bit more then normal ride height would with a small lift. But you could make it work. The goal no matter what is to not rub through the whole movement of the suspension.
  4. Feb 4, 2017 at 8:40 AM
    PROseur
    Pussy
    Thanks
    I don't have interest in it
    I am happy with my Asian tiny penis 28 inch tires on my puny truck
    Just was curious what's the tallest tires mall cruises can install without rubbing on stock suspension
  5. Feb 4, 2017 at 8:41 AM
    Spewed
    Spewed Well-Known Member
    Kolton
    2017 Toyota Tacoma 4x4
    Installed lift. SCS ray 10 wheels and master craft courser MXT
  6. Feb 4, 2017 at 9:28 AM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    AHHHHH!!! A TURD GEN!!!!!
    TheDude22, j0shu4, MtRSQ and 5 others like this.
  7. Feb 4, 2017 at 9:42 AM
    Robmonster117
    Robmonster117 Well-Known Member
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
  8. Feb 4, 2017 at 9:44 AM
    Spewed
    Kolton
    Lmao apparently I did get lost. Sorry guys. My bad
    TheDude22, RedManRocket and JKU3000 like this.
  9. Feb 4, 2017 at 9:55 AM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Nice looking truck, though!
  10. Feb 4, 2017 at 10:17 AM
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Just giving you some crap my dude. Its kindof a pastime in here :D
    LogCabins likes this.
  11. Feb 4, 2017 at 10:23 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Washed it yesterday. Went down a new road today.
    jjsul, TheDude22, BYJOSHCOOK and 7 others like this.
  12. Feb 4, 2017 at 11:14 AM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Anyone here into go karts? I've go a project that's needs to be set up and I know nothing about them. Currently have a Briggs animal engine and frame. PM me if anyone can help me set it up.
  13. Feb 4, 2017 at 11:17 AM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    Replaced the passenger side UBJ. Of course, it wasn't the problem. :annoyed:
    So back to diagnosis.
    At least I know how to do that job now, I suppose.
  14. Feb 4, 2017 at 11:19 AM
    RedManRocket
    Red
    2002 Double Cab LT
    What seems to be the problem
  15. Feb 4, 2017 at 11:25 AM
    sente3
    sente3 -
    North Jersey
    I don't know. Nothing really.
    During wheeling this past weekend, the truck developed a clunk when the passenger side front tire moves up and down. Sounded like it was coming from the UBJ, like it had worn and started having up and down movement. And the sound happens less often and typically not as loud with a passenger, which made sense for the UBJ case in my mind.
    But now it's replaced, and it hasn't gone away. I still can't tell where the sound is coming from. Seems perhaps it's lower than I thought.
    I haven't a damn clue if it's related or not, but I noticed moisture on the outside of the steering boot on that side and I can see a little hole between two of the fins. I have no idea if this is new and potentially related to the issue or if it's been there and I never noticed. But nothing about steering has changed, so I have my doubts it's related to the noise.
  16. Feb 4, 2017 at 11:36 AM
    RedManRocket
    Red
    2002 Double Cab LT
    I'd make sure no bolts or nuts are loose causing any movement, tie rods, shock mounts, cv, etc. If none of them are loose jack the truck just enough so the tire comes off the ground then, give it a good wiggle side to side checking for any play, and take a pry bar, or a leverage bar of sorts, and wedge it between the tire and ground and pull up(or push down, depends on what type of bar your using) to check for play there as well.
  17. Feb 4, 2017 at 11:39 AM
    sente3
    sente3 -
    North Jersey
    Yeah that's my next plan. Doesn't seem like WB to me, but I'm gonna check with that method anyway. But the thing is, if I don't get the tire to travel much (or rock the truck side to side, same result) there is no noise. It has to move a good bit. Not that that is any trouble with my soooft stock suspension.
    But I will definitely check for play and look at all nuts and such.
    jjsul and RedManRocket[QUOTED] like this.
  18. Feb 4, 2017 at 12:20 PM
    2BeersPlease
    2BeersPlease Well-Known Member
    I stand corrected. I was looking at 285/75-17s, which are 33.83 according to TW's size calculator. Sorry about that.
    Edit: I've been tire shopping, so I'm a little distracted.
    Blackdawg[QUOTED] likes this.
  19. Feb 4, 2017 at 12:21 PM
    sente3
    sente3 -
    North Jersey
    hmm getting a hammer under the tire and moving it up and down, I can tell it's either the UCA or the LBJ. I can't tell which. And that's fucked because it's as far away from each other as it can get. But it does sound and feel more like UCA.
  20. Feb 4, 2017 at 12:40 PM
    RedManRocket
    Red
    2002 Double Cab LT
    Get another person to move the hammer and you look and see where the movements coming from
