  1. Feb 5, 2017 at 8:37 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Hit or miss. I think there's a few different part numbers. Have the grab the joints and see if they have bolts with them.
    FWIW, I was unable to find them at any local hardware store. They're grade 10.9 flanged M10 fine pitch or something like that.
  2. Feb 5, 2017 at 8:37 AM
    2BeersPlease
    2BeersPlease Well-Known Member
    To get a nice mask on the plastic trim between the flare and the body, I just taped over it and used a sharp utility knife blade to carefully cut the tape along the seam between the plastic trim and the flare. I ran my thumbnail along it to create a nice crease. Made a nice, defined line to following for cutting. Peel away the tape and you have a near-perfect mask.
    I used 1-inch painter's tape. It made the job a little tedious. I'm going to use at least 2" tape for this part on the other three fenders.
    PROseur[QUOTED] and cruiserguy like this.
  3. Feb 5, 2017 at 8:44 AM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    Yeah I'll see if it comes with them. If not, I'll order through Toyota if possible. If I can't, I will look around or order online if I have to. Thanks for the info.
    Of course, it's Sunday, so I will have to wait until tomorrow. Sunday is the worst day of the week.
  4. Feb 5, 2017 at 8:50 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    As usual, like anything having to do with paint, the key to how well it turns out is in the detail of the prep.
    Nice job, attention to detail. :thumbsup:
    2BeersPlease[QUOTED] likes this.
  5. Feb 5, 2017 at 8:57 AM
    ToxicTwin
    ToxicTwin Money Talks...It Says Goodbye
    Robert
    Glendale AZ
    2009 TRD OR
    Finally replaced my original factory installed shocks with 247,000 on them! PO didn't do anything on the suspension from what I can tell.:notsure: So it will become new a little at a time...got the very gently used shocks and springs off OfferUp for very little cash, so that will hold me over until I decide what lift to put on.
    2BeersPlease, jjsul, rngr and 4 others like this.
  6. Feb 5, 2017 at 9:18 AM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Thanks will do
    Taco Addiction likes this.
  7. Feb 5, 2017 at 9:21 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    FWIW...
    I have used both Rustoleum and Duplicolor rattle can bed liner. And the Duplicolor kicks the Rustoleum's ass. The Rustoleum stuff flakes off and rubs off. The dupilcolor stuff is more "rubbery" and flexes better. I like the finish of it better too and it lasts way longer.
    Speedytech7, PROseur and cruiserguy like this.
  8. Feb 5, 2017 at 9:28 AM
    sente3
    sente3 -
    North Jersey
    I'll have to try the Duplicolor when my leftover Rust-Oleum is gone. I did my sliders with Rust-Oleum and I haven't been impressed. Granted, I did do them when it was cold, which is not ideal, though I waited longer than typical for drying. Still, I will try Duplicolor next.
  9. Feb 5, 2017 at 9:31 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I did my sliders with the rustoleum stuff too and my front bumper. Redid the bumper in duplicolor and its MUCH better off. All my other stuff is always done in the duplicolor stuff and works great. Holds up well and doesn't fade. Easy to touch up too.
    Taco Addiction and PROseur like this.
  10. Feb 5, 2017 at 9:33 AM
    sente3
    sente3 -
    North Jersey
    Sounds like it's the way to go. Once I finally get around to cleaning the truck, I will touch up the sliders. Sort of looking forward to running out of Rust-Oleum so I can justify buying the Duplicolor.
    But first, gotta replace that LBJ.
  11. Feb 5, 2017 at 9:37 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Do both. Might as well.
    jjsul likes this.
  12. Feb 5, 2017 at 9:39 AM
    sente3
    sente3 -
    North Jersey
    I do plan on doing both, as well as the other UBJ. But those driver side parts might have to wait a little bit for funds to catch up.
    jjsul likes this.
  13. Feb 5, 2017 at 9:40 AM
    PROseur
    Pussy
    How hard is replacung she cold only on high mileage truck?
    Should rear leaf be replaced too ?
  14. Feb 5, 2017 at 11:45 AM
    ToxicTwin
    Robert
    Glendale AZ
    2009 TRD OR
    I'm not following...:help:
    Speedytech7 and devinzz1 like this.
  15. Feb 5, 2017 at 11:49 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    The LBJ bolts are available from Mcmaster Carr for a fraction of the price of the dealership. 5 bucks for a 10 pack, then you have two trail spares:homer:
    https://www.mcmaster.com/#95735a631/=1512f4e
    @sente3
    ToxicTwin and cruiserguy like this.
  16. Feb 5, 2017 at 11:49 AM
    cruiserguy
    Elijah
    SEKS
    How hard is it to replace shocks only on a high mileage truck?
    Should I do the rear leaf springs as well?
    @lotuscupcar, no it's not hard at all to replace rear shocks. Leaf springs aren't too difficult either.
    PROseur likes this.
  17. Feb 5, 2017 at 11:50 AM
    cruiserguy
    Elijah
    SEKS
  18. Feb 5, 2017 at 12:01 PM
    ToxicTwin
    Robert
    Glendale AZ
    2009 TRD OR
    On mine it was a PITA! Everything was rusted...even after soaking in PB Blaster, it took a lot of effort to break them loose. Ended up cutting a couple of bolts off. PO spent the 1st 4 winters in Boston before moving to Arizona. So some rust issues.
    jjsul and PROseur like this.
  19. Feb 5, 2017 at 12:23 PM
    ToxicTwin
    Robert
    Glendale AZ
    2009 TRD OR
    Sorry lotuscupcar, I wasn't trying to be a dick, just could not follow what you were trying to say...:thumbsup:
    PROseur[QUOTED] and retroboy1989 like this.
  20. Feb 5, 2017 at 12:39 PM
    sente3
    sente3 -
    North Jersey
    I should be able to have the LBJ on Tuesday. I'd prefer to replace the part the same day. I see they have a next-day air option, but usually that's some absurdly high cost. And it would likely end up costing more than going through the dealer. And I can't seem to view shipping costs before putting all of my information through.
