  1. Feb 14, 2017 at 12:15 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    My parking spot everyday. Far from everyone else so I don't get anymore dents. Haha.
  2. Feb 14, 2017 at 12:19 PM
    retroboy1989
    retroboy1989 Single Cab 4x4
    99 2.7L 5spd 4x4
    He doesn't have a tach.
    An OE cluster swap is cleaner.
  3. Feb 14, 2017 at 12:37 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    So I'm currently getting an alignment done and they just told me that the bolt that adjusts my castor just spins and can't be adjusted. Has anyone ever had this happen?
  4. Feb 14, 2017 at 12:55 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Er, yes and no. The headers have a port for your bank 1 a/f sensor, but I don't know how your downstream o2 sensor will react to just one cat. I put a urd o2 simulator inline with that one a long time ago with no codes since.
    Also, the headers didn't quite make it back far enough to meet up with the pipe the downstream cat is in, I had to make a 6" section with flanges on it to bridge the gap. Pretty easy though.
    It sounds like @QMEDJoe had a slightly different way of getting everything to line up.
    QMEDJoe and SwampYota[QUOTED] like this.
  5. Feb 14, 2017 at 1:02 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    Thanks drr
  6. Feb 14, 2017 at 1:15 PM
    552Jrider
    552Jrider Well-Known Member
    Jeremy
    Norcal
    2002 DC 4x4
    Yea those are super cool. There are a few i hope to never have
  7. Feb 14, 2017 at 1:26 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    He bought the corrected y pipe. There was a discussion in my build about the whole TRD headers ordeal and how there was 3 different styles made.
    QMEDJoe likes this.
  8. Feb 14, 2017 at 1:27 PM
    TashcomerTexas
    This question still stands for anyone to answer.
  9. Feb 14, 2017 at 1:43 PM
    SwampYota
    Jon
    Floor mats
    I'll have to take a look at that build thread. Didn't realize there were three different styles, I did know about the shorter Y pipe for our years but based on QMEDJoe's YouTube video it looks like that pipe still has a two bolt flange instead of the three bolt flange needed to connect on the 2003.
  10. Feb 14, 2017 at 2:00 PM
    TashcomerTexas
    Yeah there was never a 3 bolt flanged TRD header for whatever reason. It's a simple fix for a welder or fabricator.
    SwampYota[QUOTED] likes this.
  11. Feb 14, 2017 at 2:04 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Yes...cam bolts are seized
  12. Feb 14, 2017 at 2:46 PM
    JKO1998
    Utah
    And this is when everyone replaces the LCA right.....
  13. Feb 14, 2017 at 2:52 PM
    JKO1998
    Utah
    That doesn't make sense to me now that I've really woke up...
  14. Feb 14, 2017 at 3:12 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    just need new cam bolts.
  15. Feb 14, 2017 at 3:18 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Not that easy because the sleeve is most likely rusted to the bushing.
  16. Feb 14, 2017 at 3:21 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    valid point..
    Cut em off on the end and press them out and do white line bushings is probably about the only way to fix it.
    or find some used LCAs and get new bolts.
  17. Feb 14, 2017 at 3:23 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    This doesnt make sense to me. The bolt is supposed to spin. You have to loosen it so the adjuster spins. The front mount you can see the bolt. The rear mount you can see the alignment cam. If the cam is spinning (the part that does the adjusting) then it has to be adjusting. If it was frozen I could see new cams but if its really spinning the cam and not adjusting then you have an issue with the cam tabs, not the cam. But I might be wrong or the way the tech is explaining it is weird
    TheSaint likes this.
  18. Feb 14, 2017 at 4:16 PM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    I drove it to work. Such a fun truck!
    TheSaint and sente3 like this.
  19. Feb 14, 2017 at 5:13 PM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    I ended up finding the y-pipe that corresponds to the 99-2004's but strangely enough some slight modifications to the cat had to be done.(it wasn't straight bolt on as stated) I also had a three bolt flange on the cat and had my exhaust guy weld a 2 bolt flange on.
  20. Feb 14, 2017 at 5:17 PM
    QMEDJoe
    Joe
    I've only read on here that 3 of the 4 bolts line up. I got lucky with finding a pair of Limited seats. I know a guy in Dallas that Had a grey pair, not sure if he still has them?
