  1. Feb 15, 2017 at 10:28 AM
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Its a decent bar and plate IC. My previous was 3" in/out. This new one is 2.5" which matches up with my charge pipes so it theoretically should make the same flow. The new IC is smaller in thickness, height, and width. But it's still very sufficient for 2.5" charge pipes. Pretty sure Chris and everybody is running this one. Wonder if the volume of free standing air that was in there made the difference as the tb has more air to draw from in the overall pipe system? I never would have guessed it would impact my tune this much. I'm hoping with my ebc I can get it dialed in better if I suck in more air because it's running rich (my bad not lean).
  2. Feb 15, 2017 at 10:40 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Your boost pressure though is consistent with how it was before?
    The Volume you mentioned is possible. especially since it's smaller in every dimension.
  3. Feb 15, 2017 at 11:02 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Stole an awesome idea from @UtahTacoma02 and made it my own. Made a holder for my deflators and color coded them because I typically have the rears setup to a slightly higher pressure than the fronts. Blue will be fronts black will be backs. Also put my digital pressure gauge and spare valve stems/caps in the drawer too.
    Cheap fun projects ftw.
  4. Feb 15, 2017 at 11:14 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I need a fuse block. Too many accessories these days running a direct-to-battery connection. Any suggestions other than the Blue Sea ones?
  5. Feb 15, 2017 at 11:15 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Bussman all day man.
    MtRSQ likes this.
  6. Feb 15, 2017 at 11:16 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    do they have any with a cover? I didn't see any with a cover.
    Block will be in the engine bay.
  7. Feb 15, 2017 at 11:17 AM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
  8. Feb 15, 2017 at 11:19 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Yes please. Part number? Brand?
  9. Feb 15, 2017 at 11:23 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Forgot to mention I only need about 6 circuits. Right now I have the IPF lights in the front, Better bed lights, rear reverse lights, HID relay, and MAYBE the CB radio (unless it's piggybacked onto a fuse in the interior fuse box)
  10. Feb 15, 2017 at 11:25 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    It comes with a cover.
    You can wire up the bussman for 5 relay circuits and 5 fuse circuits: https://www.tacomaworld.com/threads/diy-build-and-install-a-bussmann-rtmr-fuse-relay-block.399454/
    can get the 10 relay one for 10 relays and 10 fused circuits.
    Delta00 likes this.
  11. Feb 15, 2017 at 11:31 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Delta00 and Blackdawg[QUOTED] like this.
  12. Feb 15, 2017 at 11:34 AM
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Anyone ever break a rear end axle?
    Splines striped or actually in half
    Wondering if I should sell the 8.4 housing with axles or if I should keep the axles as backup... if it's not a common problem think I'll sell them :notsure:
    malburg114 likes this.
  13. Feb 15, 2017 at 11:36 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not impossible per say..
    But not likely. All depends on your driving style and such.
    snowboard704[QUOTED] likes this.
  14. Feb 15, 2017 at 11:39 AM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Okay thanks for the quick reply :hattip:
  15. Feb 15, 2017 at 12:16 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Hey guys need a quick part #. Anyone have a TRD radiator cap that goes to the v6? Part #? I'm showing like 2 different ones. They increase the boiling point of the coolant by increasing the pressure rate.
  16. Feb 15, 2017 at 12:18 PM
    TashcomerTexas
    Looks good scoob. Catching up to me in mods, color match that grille.
  17. Feb 15, 2017 at 12:26 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Seen a clean break on a second gen once. Had the rear locked with a wheel wedged in a rock. If it was me I would keep them especially if they are setup with the rings/backing plate and axle. It's not just a bad axle that you can use it to swap, it's a bad bearing too.
  18. Feb 15, 2017 at 12:29 PM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Yea both sides are setup with the rings/backing plate and everything.
    Think I'll do that then.
    Are both sides interchangeable or are they marked L/R?
  19. Feb 15, 2017 at 12:30 PM
    Scoobarooo
    Scoobarooo Well-Known Member
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    3" OME/Bilstein, Retrofits, Custom Bed rack/Toolbox, Amsoil Everything, tons of others.
    I like the chrome
  20. Feb 15, 2017 at 12:42 PM
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    CBI brackets clear if you stack washers underneath. On their own they will not.
