  1. Feb 15, 2017 at 12:46 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    The backing plate I believe is the only side specific part.
    snowboard704[QUOTED] likes this.
  2. Feb 15, 2017 at 12:48 PM
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    And the backing plates are pressed on correct?
  3. Feb 15, 2017 at 12:52 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    I'm thinking its 02. But there are 2 different types a "N" type and "S" type. How do I know which goes to my radiator? And there's 3 different pressure ratings.
    Also why does it stop at 2001? Difference in radiators?
  4. Feb 15, 2017 at 1:01 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Yeah the bearing is pressed into the backing plate and then that onto the axle.
  5. Feb 15, 2017 at 1:05 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    N (N/A) S (supercharged) ?
  6. Feb 15, 2017 at 1:14 PM
    TashcomerTexas
    I think I found my answer. Difference in the shape of the cap; really had to dig for this shit all for a $30 cap.
    Still curious why they said up to 2001. Aren't all 1st gen radiators (v6, 4x4 height) the same?
    cruiserguy likes this.
  7. Feb 15, 2017 at 1:30 PM
    Scoobarooo
    Scoobarooo Well-Known Member
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    3" OME/Bilstein, Retrofits, Custom Bed rack/Toolbox, Amsoil Everything, tons of others.
    Now only if ya lived closer. Get all shot of them
  8. Feb 15, 2017 at 1:37 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Got my rack back from the powder coaters.
  9. Feb 15, 2017 at 1:50 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
  10. Feb 15, 2017 at 1:55 PM
    TheDude22
    TheDude22 Well-Known Member
    Destin, Florida
    White 04 Taco 5speed 4x4
    ARB bumper, Smitty bilt 1000 winch, KC fog lights, Custom rear bumper with tire swing. Toytec lift,
    After finding a boot torn on my passenger cv and hearing a loud popping noise I decided to replace and went with napa axle. After replacing and into about a 15 min drive I am still hearing this popping noise from the passenger side while turning left or going over speed bumps. Does the angle of my cv look like it's too much and causing the axle to bind or should I be looking elsewhere? IMG_0305.jpgIMG_0304.jpg IMG_0307.jpgIMG_0309.jpg
  11. Feb 15, 2017 at 1:56 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Look else where, pretty sure my angles are worse than yours and I have no popping
  12. Feb 15, 2017 at 1:58 PM
    wildfyr3
    wildfyr3 KEØGLC
    Forrest
    Eagan, MN
    2000 xtracab 2.7L manual
    DR coilovers Dakar Leaves Icon rear shocks BFG 33x10.5x15 KM2 Trail Gear front bumper Relentless fab rear bumper DIY sliders
    Yes! Can't wait to see how the headlight hoops look on a TG once mounted up. Not that I really looked all that hard but I haven't seen anyone else with them and I was thinking of making some up for mine in the future.
  13. Feb 15, 2017 at 1:59 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    WOw
  14. Feb 15, 2017 at 2:00 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I can't even tell if the boots are rubbing or not because the inners are all scrunched up.
  15. Feb 15, 2017 at 2:00 PM
    JKO1998
    Utah
    I took it off.
    My hoops are a little extreme.
    Pretty crazy huh.
    j0shu4 and wildfyr3[QUOTED] like this.
  16. Feb 15, 2017 at 2:02 PM
    PROseur
    Pussy
    Almost started touching myself
  17. Feb 15, 2017 at 2:03 PM
    JKO1998
    Utah
    Buy it.
    PROseur[QUOTED] likes this.
  18. Feb 15, 2017 at 2:05 PM
    PROseur
    Pussy
    It's cum stain safe ?
    Link to sale ad ?
  19. Feb 15, 2017 at 2:05 PM
    TashcomerTexas
    Round of applause for taking my criticism on the hoops
  20. Feb 15, 2017 at 2:06 PM
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    I took my sway bar out. I've replaced a bunch of worn parts I found on my search. Upper and lower ball joints, steering rack bushings, outer tie rods, and steering rack guide. :fistbump:
    Pretty sure the lca bushings are toast, but like I said I wanna run a go pro under there to be sure. I took a quick video this morning before work and there is def some play in the one bushing I shot. We will see. Should be a fun project for the spring :thumbsup:
