  1. Feb 21, 2017 at 6:39 PM
    Penten
    Penten Well-Known Member
    Peter
    Iowa
    Alright guys. best way to drain the fuel tank ?
  2. Feb 21, 2017 at 6:56 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    :burnrubber:
  3. Feb 21, 2017 at 6:58 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    Shove a screw driver into it
    jjsul and SwampYota like this.
  4. Feb 21, 2017 at 7:15 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    siphon hose or transfer pump, ideally after you've driven it til it's as close to empty as possible.
    Jaysjammin likes this.
  5. Feb 21, 2017 at 7:19 PM
    Penten
    Peter
    Iowa
    1 out of 3 for not trolling is pretty good . I think I may have gotten rain water in my tank since I have the hoses off and the bed off as well . So I'm just looking for the best way to completely empty it . I'll try the siphon it with a pump first
  6. Feb 21, 2017 at 7:21 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Disconnect fuel line from fuel rail, add a length of hose and put it in a gas can. Turn on key and let the fuel pump, pump the tank dry.
    Might take several gas cans depending on how full the tank is.
  7. Feb 21, 2017 at 7:27 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    There's about 1/2 - 3/4 of a gallon that the fuel pump can't get to though, as it doesn't sit right on the bottom of the tank. Also not real good for the pump to run it dry (cavitation damage and all). And you don't want to get a water/fuel mix in your fuel filter, fuel line connections, etc. for corrosion issues.
    Edit: depending on how much water got into your tank, there are fuel dryer products like Rislone that can remove water from the fuel.
  8. Feb 21, 2017 at 7:31 PM
    koditten
    Kirk
    Central Michigan
    Then dropping the tank is the only other option to get all the liquid out.
  9. Feb 21, 2017 at 7:56 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    That makes sense then
  10. Feb 21, 2017 at 7:57 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Junkyards sell 16" proper tacoma steelies for $30 each
    Fjc steelies 17" are $35 each
    Locally they have 100s of these
  11. Feb 21, 2017 at 7:58 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I just like how they look :anonymous: but they are so heavy and the equation for rotating mass says that's a pretty big nono with a 4cyl and awful gears.
    TheSaint and BYJOSHCOOK[QUOTED] like this.
  12. Feb 21, 2017 at 8:01 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Idk what about them that I don't like. But every truck I've seen them on just :puke:
    blue_goose likes this.
  13. Feb 21, 2017 at 8:05 PM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    They are a bit harder to find around here.
  14. Feb 21, 2017 at 8:06 PM
    Speedytech7
    I like most steelies, my favorite are D window steelies on old muscle cars or lowered trucks. I'm not sure if I'll keep the F5s for the next round of tires or not yet, they are holding up great other than where I've dragged them against stuff. But I like so many other wheels out there now.
  15. Feb 21, 2017 at 8:08 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Oh those steelies are fine, it's the "stock" ones that are the spares.
  16. Feb 21, 2017 at 8:09 PM
    Speedytech7
    I like those too, it's got a simple look, but again major downside being heavy as hell.
  17. Feb 21, 2017 at 8:19 PM
    PROseur
    Pussy
    Guys are hilarious on this forum
    They put ridiculous heavy tires
    RTT
    Ridiculous front and rear bumper
    Ridiculous sliders
    Ridiculous winches
    They never weigh any of these and don't realize how much weight they add
    But God they won't add steelies because it will weigh it down
    Lmao
    I run the lightest wheel and tire combo of any 6 lug member on this forum (28inch and 225s) and the hypocrisy is hilarious
    Nedrolls likes this.
  18. Feb 21, 2017 at 8:24 PM
    Speedytech7
    I'd be happy to tell you the weight of all those items (minus roof tent, don't have one) as I did weigh them. Rotating mass, especially rotating mass beyond the mechanical advantage of gear reduction as wheels are is multiplied. If you're curious (doubtful) I know of some videos that can explain this better than I can.
    Perhaps the third gen section would like to hear this complaint though, seems better suited there.
  19. Feb 21, 2017 at 8:25 PM
    PROseur
    Pussy
    I am a cunt and I know it
    You don't have to hate me
    I hate my cunt self
    Thanks for the high horse post though. Didn't expect it from you all people
  20. Feb 21, 2017 at 8:30 PM
    Speedytech7
    Sometimes taking the bait is fun. My horse smokes only the finest hay.
    I never asked but why did you change your name from lotuscupcar to @PROseur
