  1. Feb 24, 2017 at 8:42 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I shredded my cable earlier this winter when I slipped a chain :(, haven't gotten around to it yet...
  2. Feb 24, 2017 at 8:46 AM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    Do you know where it is sticking? I'm not sure which version your truck has but the bell cranks on mine are a common part to stick. I tried to clean and lube mine and it would only last until the next time it rained. I have new ones ordered as well as all new cables.
  3. Feb 24, 2017 at 9:14 AM
    TheSaint
    TheSaint Regular Guy
    Mark
    Prescott, Arizona
    White 2003 4x4 TRD DC
    OME lift, 265/75s, pickup shell, couple of dents.
    I flushed mine a couple of months ago, it wasn't that hard. I had to do the full flush because the screen at the bottom of the reservoir was totally caked with gunk, I had to pull off the entire reservoir and clean it out with brake cleaner. I had my kids sit in the cab and turn the wheel lock-to-lock while I topped up the reservoir, they got a kick out of that.
    SwampYota and Crodell6[QUOTED] like this.
  4. Feb 24, 2017 at 9:39 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Is there a difference in 2wd and 4wd steering racks? I keep seeing conflicting information.
    This is the correct p/n for 4wd right 4425035042
  5. Feb 24, 2017 at 9:39 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yes...and no..
    Very different racks for the 5 lug vs the 6 lug version.
    Prerunner's use the same rack as 4wd trucks.
    Reh5108[QUOTED] likes this.
  6. Feb 24, 2017 at 9:40 AM
    Reh5108
    Idaho
    Thanks!
  7. Feb 24, 2017 at 9:44 AM
    Reh5108
    Idaho
    Anyone have experience with cvjs rebuilt racks?
    alee891 likes this.
  8. Feb 24, 2017 at 10:02 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Go OEM, it's your best bet.
  9. Feb 24, 2017 at 10:04 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yeah it's at the bell cranks on the drums, all I do to un-stick it is release the lever and go pull on the cable at the axle and it comes loose.
  10. Feb 24, 2017 at 10:10 AM
    ClevSix
    IL/IA
    Anybody have advice on how to get the lens off the front corner marker light without braking it? Maybe a heat gun? I think it is just glued on but I'm not sure. Tkanks
  11. Feb 24, 2017 at 10:11 AM
    Reh5108
    Idaho
    That was my original plan but, seems like cvj has a lot of respect around here so thought I might give them a shot. They use oem parts and test everything so how much different can it be from a new oem?
  12. Feb 24, 2017 at 10:14 AM
    ClevSix
    IL/IA
    Those things are near impossible to keep working once they go bad. I'm going to try to seal the new ones if I can figure out a good way to do it.
  13. Feb 24, 2017 at 10:14 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I don't know of the difference other than it's still a rebuild. I was burned on an aftermarket rack and had to shell out the coin again for the OEM rack and it is working much better. IMO it may hurt a little to pay the extra, but once the tires get bigger and the trail gets harder, the rack really takes it in the shorts. It didn't make it a full year and had a lot of play.
  14. Feb 24, 2017 at 10:14 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    They use OEM "hard parts" not OEM seals and what not.
    But not sure if anyone had bad experiences with them. So far all I know is people have issues with Safari and Rack Doctor.
  15. Feb 24, 2017 at 10:15 AM
    WildLand
    WildLand Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    Doesn't work.
    I just ran some experiments with mine to try to color match them. The only way to do is pry the lens off with a small screwdriver. This however leaves marks on the plastic lense as well as the housing. When you pry, you crack the glue and keep working your way all the way around. However, you are at risk of cracking the housing. 2 out of the 3 I tried, the lense cracked. The lense did not crack on the OEM one so maybe it will work on OEM, not aftermarket.
    Also when you are finished removing the housing, where the glue is, it looks like cracked glass when you put it back together. Looks pretty bad.
    Any heat high enough to melt the glue will melt the lense and housing so heat wont work
  16. Feb 24, 2017 at 10:21 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    That, or maybe with a buddy. :D
  17. Feb 24, 2017 at 10:25 AM
    Reh5108
    Idaho
    Maybe I'll give them a try. Truck isn't a daily anymore so it won't be seeing as many miles. I'm not to worried about the soft parts not being oem.
    alee891 and Digiratus like this.
  18. Feb 24, 2017 at 10:40 AM
    ClevSix
    IL/IA
    Hmm, is it actually glued or did they thermally "weld" the two pieces together?
  19. Feb 24, 2017 at 11:18 AM
    Speedytech7
    We ran out of snow here finally, I think I'll just lube up all the pivot points and see how it fares tonight.
  20. Feb 24, 2017 at 11:26 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    This. about $530 from camelback
    Deathbysnusnu[QUOTED] likes this.
