  1. Feb 26, 2017 at 8:50 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    i like you too
    Speedytech7[QUOTED] likes this.
  2. Feb 26, 2017 at 8:51 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Aren't you a cable technician? I bet you can get your hand on a good hydro crimper
  3. Feb 26, 2017 at 8:51 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    If a crimmped connection corrodes it is because it was poorly done. I hydraulic crimper elimiates all air access to the joint. Without oxygen, no corrosion.
    He said hydrauilc :smack:
    ClevSix[QUOTED] likes this.
  4. Feb 26, 2017 at 8:51 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
  5. Feb 26, 2017 at 8:53 PM
    Bennett707
    Oregon
    nah man
    we dont get cool stuff
    but i do have a quality hammer
    :anonymous:
    :D
  6. Feb 26, 2017 at 8:54 PM
    Speedytech7
    Rockin that Estwing?
    Keep on Truckin' likes this.
  7. Feb 26, 2017 at 8:56 PM
    Bennett707
    Oregon
    not that quality
    klein :(
  8. Feb 26, 2017 at 8:59 PM
    Speedytech7
    That's good stuff too, couldn't keep the Klein tools section at Home Depot stocked..... mostly because people always stole from it. That was always fun, running Customer Service and Returns so I could hear about how we were sold out of an item and then see the dude who blatantly stole it try to "return" it for store credit.
  9. Feb 26, 2017 at 9:00 PM
    Bennett707
    Oregon
  10. Feb 26, 2017 at 9:19 PM
    Digiratus
    Roaming the PNW
    The RedHead
  11. Feb 26, 2017 at 9:20 PM
    Bennett707
    Oregon
  12. Feb 26, 2017 at 9:21 PM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    I fully agree, if done right crimped or soldered will work well but I don't expect someone to have a hydraulic crimper when working on things at home. If that is what he was intending to use then by all means go with crimped connections. I suppose on such large cable soldering it would be tough as well. With the tools and experience I have I would still choose soldering.
  13. Feb 26, 2017 at 9:26 PM
    Speedytech7
    Really just a matter of the right tool for the job, larger cables really should be crimped. For small in cab stuff and small engine bay stuff, up to about 12 gauge I'll still solder. Past that it is time to start crimping as you can't really expect solder to hold up to the force of a stiff cable and it becomes harder to achieve a uniform heat to avoid cold solder joints. Hydro crimpers are about as cheap as good torch and acid core solder, or alternatively a good soldering iron and transformer setup, so why not have both in the arsenal. I have all three just in case
    ClevSix[QUOTED] and Digiratus like this.
  14. Feb 26, 2017 at 9:27 PM
    Bennett707
    Oregon
    when you coming down ?
  15. Feb 26, 2017 at 9:28 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Agreed. For smaller stuff, definitely soldering over crushing with pliers and such.
    The discussion today was about doing the 'big 3' wire upgrade without buying a pre-made kit. The minimum gauge wire for the big 3 upgrade should be 4AWG. With wire that big a hydraulic crimper like the $40 Amazon/eBay unit is the way to go.
    I used the exact unit I posted a link to on my dual battery setup with 1/0 gauge. Was the perfect tool for the job.
  16. Feb 26, 2017 at 9:29 PM
    Speedytech7
    I have no plans to go to Portland anytime soon. But if you come up I have good beer and a warm garage for modding.
  17. Feb 26, 2017 at 9:31 PM
    Bennett707
    Oregon
    If it wasn't for i5 traffic i would be much more inclined to do day trips.
  18. Feb 26, 2017 at 9:32 PM
    Speedytech7
    Yeah not only that it's also boring drive to boot.
  19. Feb 26, 2017 at 9:34 PM
    Bennett707
    Oregon
    mhmmm
    I couldn't have been happier when Alex offered to make the drive down for me.
  20. Feb 26, 2017 at 10:10 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    That is the one to get.
