  1. Mar 4, 2017 at 6:25 PM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    Use the "bump the starter" trick to get it of... I'm not an expert but I think you need a new one.
  2. Mar 4, 2017 at 8:15 PM
    Toyota4x46921
    Toyota4x46921 Well-Known Member
    Michael
    Warner Robins, GA
    drr and Malek[QUOTED] like this.
  3. Mar 4, 2017 at 9:21 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    It's dirty already :devil:
    jubei and Robmonster117[QUOTED] like this.
  4. Mar 4, 2017 at 9:46 PM
    MtRSQ
    MtRSQ I am that I am.
    Brandon
    Utah
    3rd Gen, White, 4Door, V6, TRD, 6MT.
    285 70 R17 BFG KO2's,17” Bronze SCS Billet Wheels, 2.5" Ebaich Lift, MagnaFloe Overland Catback Exhaust (turned down @ axle), Rear Axle Breather Mod,
  5. Mar 4, 2017 at 10:07 PM
    Penten
    Penten Well-Known Member
    Peter
    Iowa
    Ha I really don't wanna have to its like 250... I need to determine any structural damage to the mounting surface
  6. Mar 4, 2017 at 10:44 PM
    Robmonster117
    Robmonster117 Well-Known Member
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Hehe dont you try and ruin my good time.:boom:Its actually not though the suede just isnt all brushed in the same direction so it looks like that
    TacoVio[QUOTED] likes this.
  7. Mar 4, 2017 at 10:48 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Love the look really, but I just know it would be tan again after one trip down a dirt road. A lot of the dust comes in through our vents because we don't have any filter.
    Nedrolls likes this.
  8. Mar 4, 2017 at 11:26 PM
    Malek
    Malek Well-Known Member
    Malek
    Denver
    02 DC TRD
    1UZFE VVTi 5spd Swap
    Yeah, I stood on it all the way to the end.
    91 Octane with EGR..has quite a few miles on it too so lobes probably aren't sealing like they used to.
    7.65psi is a nice number for a stock pulley!
    drr[QUOTED] likes this.
  9. Mar 5, 2017 at 1:23 AM
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Going to be working on a solution for that pretty soon here. We talked about it in here a bit. Im going to try and retrofit one into the ac intake under the passenger cowl. Just need to do some testing to see how moisture is in that area. Dont want the filter where its going to get moldy.
    But theres always going to be dirt I know that. Ill find out how well the dirt vaccums off the dash after I get this princess off the pavement again
    Silver02Taco and Prayn4surf like this.
  10. Mar 5, 2017 at 1:45 AM
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Today I changed all the brake fluid and bled then brakes, put new fender flare plastic tabs on to hold the flare itself better on the truck, prepped sanded and painted sliders again, checked all nuts/bolts (prep for moab)
    Fairly productive :notsure::popcorn:
    Jaysjammin and jjsul like this.
  11. Mar 5, 2017 at 1:56 AM
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    Nice. I have my Hertz still in a box... need to order a few more pieces still. Which adapter's did you go with? 6.5" speakers correct? Thanks
    I just added the Gentex to my list. Didn't know about the homelink model. Other than the new mount, anything required to run the homelink that you know of?
  12. Mar 5, 2017 at 4:28 AM
    ClevSix
    IL/IA
    Pricey little bastard. You'd probably be fine running it but I would want to replace it. Check local junkyards? The ones around here never have older Toyota parts.
  13. Mar 5, 2017 at 6:06 AM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    Yeah I still wanna mess around with that. It's just that it's been so damn cold lately. Hit the negatives last night. Not good weather for doing anything with the truck, especially not non-essentials.
    robupstateny likes this.
  14. Mar 5, 2017 at 7:02 AM
    Penten
    Peter
    Iowa
    I agree I'll probably do it once I find one on the cheaper side . I'm sure a 4runner one will work fine
    ClevSix[QUOTED] likes this.
  15. Mar 5, 2017 at 9:48 AM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    How is that on the back. Mine was so close to duckts on the left side that I had to fabricate a custom plug for backup camera. Also stock mounting brackets in 95 Tacoma had different hole locations than modern radios. I drilled maching holes in stock brackets an the doble din fit like from factory. No frames needed.
  16. Mar 5, 2017 at 9:58 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    IMG_0453.jpg IMG_0454.jpg First one up this road in a couple months
  17. Mar 5, 2017 at 10:24 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yeah I have a 2.2" pulley ready to go on but I'm a little concerned that I'll be pushing like 10 psi and I'll need to do injectors, rail, etc. and tune the crap out of it lol
    Are you running a 7th injector setup or a standalone tuner or anything?
  18. Mar 5, 2017 at 10:33 AM
    Nedrolls
    Nedrolls Well-Known Member
    Scott
    Coquille, Oregon
    1999 Ext cab beater. 2016 Pro 4Runner(wife's)
    20170304_162722.jpg Drove ol goldy up in the snow, bald tires and all
  19. Mar 5, 2017 at 10:50 AM
    willie64
    willie64 Willie64
    willie64
    BEND OR
    (slowly becoming less than) Stock '03 3.4L 4x4 TRD SR5
    144 watt led lights on front 36 watts x2 led on the back, cb, Kenwood ham, icon 3" lift, 285/75/16 Fierce Attitude tires, JoeZilla sliders, 4x innovation rear bumper, ARB front bumper. Snorkel. On the workbench: more stuff I can't afford.
    Bald tires are the bestest. They're more gooder on that snow.
  20. Mar 5, 2017 at 10:52 AM
    Nedrolls
    Scott
    Coquille, Oregon
    Lol yes, I'm definitely in need of tires
