  1. Mar 9, 2017 at 7:50 AM
    Burnett
    Burnett Well-Known Member
    Nolan
    North Georgia
    98' Xtra cab v6 4x4 evergreen pearl
    Bilsteins 5100's & 5125's, OME Dakar leafs Custom toolbox Custom bedstep/towhook/reverse light combo Custom Bedrack
    Good deal, I've got Dakar's already on and rear nitros on the way so I figured a complete package designed to work together should be pretty decent
  2. Mar 9, 2017 at 7:55 AM
    Blues0010
    Blues0010 Well-Known Member
    Ben
    Boise, ID
    2001 Tacoma SR5
    I can't compare to what you have now. I'm currently on 881s, Nitrochargers and Dakars. I came from stock suspension. Ride is much stiffer but as a result handling is much better. They've begun to soften up a tiny bit over the last couple thousand miles. I'm happy with them. Your truck is definitely heavier than mine too.
    Burnett[QUOTED] likes this.
  3. Mar 9, 2017 at 7:55 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    I was never a fan of how the dakars and rear nitrochargers rode, too stiff unless they're heavily loaded for me. The fronts ride nice though, you'll get quite a bit of sag with the 881's and a heavy bumper like that.
  4. Mar 9, 2017 at 8:04 AM
    Burnett
    Nolan
    North Georgia
    Ya I tried to get stuff enough coil to support bumper without being too stiff. ARB bumper only weighs 68 lbs though so hopefully I'll be good
  5. Mar 9, 2017 at 8:05 AM
    Burnett
    Nolan
    North Georgia
    ARB isn't actually as heavy as it looks, I'm hoping it won't sag too bad. I believe the 881's are rated for about 100 extra lbs up front. We shall see
    drr[QUOTED] likes this.
  6. Mar 9, 2017 at 8:07 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    there will likely be a touch of sag. But should work okay. Might ride nice that way really.
    Burnett likes this.
  7. Mar 9, 2017 at 8:07 AM
    Burnett
    Nolan
    North Georgia
    No winch currently, no immediate plans for one. Probably upgrade coils if I go that route
    Right now the ARB is just a big deer basher
  8. Mar 9, 2017 at 8:08 AM
    Burnett
    Nolan
    North Georgia
    Ya I think it'll work out nice
  9. Mar 9, 2017 at 8:16 AM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Interesting, I was always under the impression that the ARB bull bar was one of the heavier plate bumpers. I have an all-pro apex plate bumper with winch, lights, etc, running the 882 coils, which are the same spring rate as the 881, just a little longer. It has definitely sagged over the years, but rides nice with all the weight on them, and maintains ~2" of lift.
  10. Mar 9, 2017 at 8:18 AM
    WildLand
    WildLand Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    While we are on the subject and not getting much help from my thread.
    I'm planning on 5100s all the way around. If I plan on getting a small valence bumper and winch (~120 lbs total), should I order 881s? Or would stock coils with the 5100s be fine if I crank the 5100s to the 1st or 2nd setting?
    Probably know the answer - spend the extra $175 and get the coils
    BYJOSHCOOK and Burnett like this.
  11. Mar 9, 2017 at 8:40 AM
    Burnett
    Nolan
    North Georgia
    Not sure but you should def buy my 5100's after I do my install. :D
  12. Mar 9, 2017 at 8:41 AM
    WildLand
    Josh
    NM
    16T4RSR54WD
    :spy: how many miles?
  13. Mar 9, 2017 at 8:48 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    get the coils. always.
    preloading coils makes any shock ride more and more like a brick, especially with progressive coils. Preloading my kings a touch alone made it ride more stiff.
    WildLand[QUOTED] likes this.
  14. Mar 9, 2017 at 8:55 AM
    WildLand
    Josh
    NM
    16T4RSR54WD
    Thanks for the info! That's what I kind been reading but just making sure and trying to understand it fully.
  15. Mar 9, 2017 at 9:15 AM
    Burnett
    Nolan
    North Georgia
    My 5100's (front) and 5125's (rear) have 15k miles give or take. And ya I would get new coils, mine are set at the top notch. There's nothing wrong with them, I've just always wanted to try OME
  16. Mar 9, 2017 at 10:37 AM
    WildLand
    Josh
    NM
    16T4RSR54WD
    5125s have a different mount setup in the rear don't they?
  17. Mar 9, 2017 at 10:41 AM
    Burnett
    Nolan
    North Georgia
    I really don't know, I can get some pics later if you like. They are a generic valving, not necessarily designed just for Tacoma's
    WildLand likes this.
  18. Mar 9, 2017 at 11:15 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    same valving as 5100s.
    the difference is size's available.
    5100s are speced to fit OEM applications with some lift(generally)..5125s..aren't. There are size difference and 5125s come in lots of different lengths(so do 5100 but different lengths).
  19. Mar 9, 2017 at 12:39 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    So I found the full PDF to a 2001 Tacoma FSM for free. Let me know if anyone needs it. If you open it in iBooks you'll always have it and can search for keywords.
  20. Mar 9, 2017 at 12:46 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Yo, I could use it. I had the 2000 fsm on my SD card and then lost everything on that card when I did hard reboot of my phone for some reason.
