  1. Mar 18, 2017 at 6:33 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I give up, what is it?
  2. Mar 18, 2017 at 6:34 PM
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    Not Arnold on the motorcycle...
    jubei likes this.
  3. Mar 18, 2017 at 6:35 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Ohhhhhh
    Looks like David Hasselhoff lol
    Prayn4surf likes this.
  4. Mar 18, 2017 at 7:13 PM
    beez
    beez Well-Known Member
    Nate
    04 single cab PreRunner
    Yeah I had the bumper off the truck when I did this so measuring/fitting was easier. I don't think that it will make much difference where on the bumper you mount them, they are so bright, everything will be lit up.
    How did you wire them? I want to wire them to an override switch, in the cab.
  5. Mar 18, 2017 at 7:25 PM
    2002Tacoma4x4
    2002Tacoma4x4 TRD 4x4 double cab
    C K
    Limited Edition Double Cab TRD off road 4WD
    Jean claude vandamn!
    cruiserguy likes this.
  6. Mar 18, 2017 at 7:35 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    Drove to a glacier...
    BC955AE3-1DA2-4F18-BF22-C268F2F9850B_zps_7fc561ca90d990e8eda9e5759b10ba04dd2858a4.jpg
    82EA6BFA-279F-4309-8D3A-0FB0467554C7_zps_20927ac1c0f158ca107ed982dc1ab3efd697fdd8.jpg
    A9BB83C6-ED6C-465C-B0C2-1E0B38D685F7_zps_7f9f128360da260511e82d815648f3a4cf1717f2.jpg
    Prayn4surf and KenLyns like this.
  7. Mar 18, 2017 at 7:35 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    1. Arnold's stunt double on motorcycle.
    2. Ed Furlong's stunt double on dirt bike.
    3. Since Ed Furlong's stunt double is adult-sized, the dirt bike is a scaled-up prop to keep things in proportion. (It's bigger than the Harley!)
  8. Mar 18, 2017 at 8:03 PM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    Hell yea I got some last week still need to install. You get the plus?
  9. Mar 18, 2017 at 8:04 PM
    Misplaced Nebraskan
    Zach
    Austin
    Yup. Didn't know if it was worth it over the regular, but didn't want the Elite. I try to minimize Chrome... It's a battle with the wife:D
    FLBAdrian[QUOTED] likes this.
  10. Mar 18, 2017 at 8:11 PM
    FLBAdrian
    Adrian
    Hanford Ca,
    Too many…
    Yeah I got regular. See how it goes.
  11. Mar 18, 2017 at 8:14 PM
    Dannny boy
    Dannny boy Stab it and Steer
    AZ
    2002 loaded salvage, and a brand newly aquired 2000
    grey wire, buzzer yank, last click defrost, tack welded column, deckplate, intake silencer delete, led map/red overhead, led backups, underhood dual battery, onboard air, CS-144 big fucking alternator, big fucking alternator wiring, overhead rifle rack, airbag pistol safe, cab to camper 12 volt evap cooler, bug screen cab windows, onboard shower, solar panel and beer fridge!
    I just tapped the power wire straight into the backup wire for the stock units using some scotch locks, grounded the black wire to frame. I considered running a separate wire to select them from the cab. I'd just run a 16 gauge wire to a relay near the back bumper that was between the stock backup wire and the lights. It would allow the lights to be illuminated when switched on and backing up.
  12. Mar 18, 2017 at 8:19 PM
    Misplaced Nebraskan
    Zach
    Austin
    Hopefully I'll get around to it on Tuesday or Wednesday. Pics to follow for sure.
  13. Mar 19, 2017 at 1:11 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
  14. Mar 19, 2017 at 6:09 AM
    Trim taco
    Trim taco Just one more stupid question
    Bourbon capital of the world
    Was: 96 SR5 5MT Is: 19 OR 6MT
    Bunch 'o random stuff
    Thanks for the reply. Sounds exactly like what mine's doing. I'll crawl under and check it out.
    Do you happen to have a part number?
  15. Mar 19, 2017 at 6:13 AM
    fiziks
    fiziks Well-Known Member
    Isaac
    El Paso TX
    01 DC Prerunner 4x4 5pd Conversion
    5 sp 4x4 conversion, OME lift, SCS F5s
    If it turns out to be the seal for the front driveshaft output, here's the part number.
    2002Tacoma4x4 and Digiratus like this.
  16. Mar 19, 2017 at 6:16 AM
    Trim taco
    This place rocks!
    Digiratus and 2002Tacoma4x4 like this.
  17. Mar 19, 2017 at 6:30 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    This is the guide I used when I did mine:
    Digiratus and jubei like this.
  18. Mar 19, 2017 at 6:32 AM
    Xjman1
    Xjman1 Well-Known Member
    JB
    2004 Tacoma TRD 4X4 X-CAB
    King coil overs, Rear shackle lift
    10 hour road trip. Oxnard to kelso depot. Through Mohave preserve to Williams az.
    Today is Williams to Jerome,az then Sedona
  19. Mar 19, 2017 at 6:41 AM
    Trim taco
    Looks easy enough!
    Again, thx to all.
  20. Mar 19, 2017 at 9:35 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    This is the write-up I used as well.
    This job was not all that difficult. As I recall, more tedious than anything. That stake nut was a bit of a pain. If you decide to replace it, here is the part number for it: 90179-22016
