  1. Mar 22, 2017 at 12:40 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    You could always go with used stuff. Not as exciting maybe but it works all the same. My suspension is and always has been mostly used parts from other members. My old Billies came from a member (lasted around 35k miles in my care before I managed to kill them, they already had 25k when I got them), my Icons are used and up until I put them on the truck this last weekend were entirely unknown condition. I forget if I bought my Dakars new or not, but they weren't expensive at all. Now my new to me rear shocks that I have to build a crossmember for are the next priority so I can pull some leafs and finish lowering my truck to a more normal stance.
  2. Mar 22, 2017 at 1:03 AM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    I wouldn't be against used parts. The issue is that I don't see them too often, and they are quick to go when they appear. And timing is hard. I can buy new at any point I have the funds. Used are much more NOW OR NEVER. But it definitely is nice knowing Kings can be rebuilt, so used aren't a big turn off or anything there.
    As for springs. Well, I don't often have big weight in the back, so I don't want leafs made for hauling. Dakars are said to be a bit rough without weight. I am looking at All-Pro standards. My reading tells me they match the kind of ride I am looking for. I also considered a pair of Deavers on CL for $400 cuz damn that's good but I think they give too little lift so idk.
    Regardless, suspension is well aways for me. I have time to figure it out 100%
  3. Mar 22, 2017 at 1:05 AM
    Speedytech7
    Might want to have a look at General Spring, they are decently priced and can give you exactly what you want lift and stiffness wise.
  4. Mar 22, 2017 at 1:05 AM
    SKINNER902
    SKINNER902 Active Member
    1998 Tacoma TRD Off Road
    Newer isn't always better am I right!? :thumbsup:
    Awesome dude thanks a lot, now my only question is where does the interval come from?
    Also, on the topic of LBJ my driver side shows some signs of seepage. I know you can jack er up and give it a wiggle to check the play, but without doing that does that mean it should be changed out? Im just curious because I don't know the history of the vehicle and I don't have any evidence that they were ever changed so im a bit nervous since weve all heard the horror stories.
    2002Tacoma4x4 likes this.
  5. Mar 22, 2017 at 1:07 AM
    Speedytech7
    What's peace of mind worth to you? In all reality if they have never been done and you're over 100K they are due, they are a wear item and the wear is slowed by the grease trapped in there with it. When that grease goes away or becomes contaminated the amount they wear per mile just goes up.
  6. Mar 22, 2017 at 1:11 AM
    SKINNER902
    Yeah your totally right, I know I seen a vid on the replacement in the DIY thread... Let the fun begin!
    Speedytech7[QUOTED] likes this.
  7. Mar 22, 2017 at 1:16 AM
    Speedytech7
    Not the greatest video but good enough, just double check the torque specs in the FSM because I'm pretty sure this video has the wrong spec listed.
    https://youtu.be/qaQCb894F_M
    MtRSQ, erice and SKINNER902[QUOTED] like this.
  8. Mar 22, 2017 at 1:21 AM
    SKINNER902
    Unreal dude, this is why TW is the SH!T.
  9. Mar 22, 2017 at 2:35 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Hahahaha
  10. Mar 22, 2017 at 4:31 AM
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
    I know ive seen the amount they are allowed to move before in this thread but if they move visibly they are long past due
    SKINNER902[QUOTED] likes this.
  11. Mar 22, 2017 at 4:40 AM
    2002Tacoma4x4
    2002Tacoma4x4 TRD 4x4 double cab
    C K
    Limited Edition Double Cab TRD off road 4WD
    Before spending money on LBJ, check VIN at dealer got both free since Recall
  12. Mar 22, 2017 at 4:45 AM
    SKINNER902
    Yeah your right worst case ill jack it up and give it a go, wish me luck ! lol
    YES! very good call, I've been meaning to do this since I got it and keep forgetting. I will definitely look into it before I drop any cash, thanks for the reminder!
    2002Tacoma4x4[QUOTED] likes this.
  13. Mar 22, 2017 at 5:46 AM
    BerndtTaco
    BerndtTaco Active Member
    95.5 Tacoma 2.7 4x4
    3 inch Rancho lift, custom front and rear bumpers
    What we're the dimensions of the bolts you ordered? Going to do ball joints soon and want to replace the bolts as well.
  14. Mar 22, 2017 at 6:01 AM
    BerndtTaco
    95.5 Tacoma 2.7 4x4
    Going OEM on the joints but I suppose I could just find these bolts from Lowe's or Home Depot much cheaper. Just as long as they are a high grade bolt correct?
  15. Mar 22, 2017 at 6:02 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Someone here shared this with me before I ordered. There are two different part numbers listed for each side. One was a couple dollars more expensive than the other. I ordered those and they came with bolts. part numbers below.
  16. Mar 22, 2017 at 6:11 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Not today but just uploaded pics finally from Saturday. Installed my rotopax to the roof rack and finally installed my maglite
    jubei, sente3, SwampYota and 2 others like this.
  17. Mar 22, 2017 at 7:17 AM
    Alex58
    Alex58 Member
    Alex
    2010 Gray Toyota Tacoma Pre Runner TRD Sport Double Cab
    Nothing... yet
    IMG_6466.PNG.jpg Since my last post I've gotten a 3 inch lift, dual mounted cb radio antennas, installed a loud speaker, and about to swap my cubes with a 20inch bar.
    JKU3000, 2002Tacoma4x4 and 49erfan like this.
  18. Mar 22, 2017 at 9:33 AM
    TACO MASTER
    TACO MASTER Well-Known Member
    Maroon 1996 Tacoma SR5 V6 4X4
    OME front and rear suspension, ABR deluxe bull bar, Black FJ 17 inch SEMA wheel with treadwright 265/70/R17 E, Bushwacker fender flares, Stock rear bumper, Eagle 4 wheel camper.
    Well I just dropped the Benjamin's for these sliders. Any suggestions on install folks ?!?! Last of the big items...just a bunch o of wiring in left now on this build up.
    jjsul, SwampYota, rngr and 2 others like this.
  19. Mar 22, 2017 at 9:41 AM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    I have those, I welded them on myself rather than bolt on.
  20. Mar 22, 2017 at 9:42 AM
    49erfan
    49erfan Well-Known Member
    Kevin
    Dallas
    04 DC Prerunner Lunar Mist
    weld
