  1. Mar 23, 2017 at 7:55 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Looks like way more then a 2.5'' spacer..holy hell.
  2. Mar 23, 2017 at 7:59 PM
    Isais101
    Isais101 Active Member
    It's and 2.5 spacer in front and a 1.5 blocks in rear use to measure 36inches before lift and 38 now
    Do you recommend a diff drop
  3. Mar 23, 2017 at 8:12 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    What coils are they? that looks insanely high. You probably have no down travel at all.
    Id recommend taking it all off personally..
  4. Mar 23, 2017 at 8:26 PM
    Isais101
    I bought some Monroe strut assembly before I put the spacers
  5. Mar 23, 2017 at 8:35 PM
    SellyKlater
    SellyKlater Well-Known Member
    Ponce Inlet, Fl
    2004 Tacoma 3.4L Double Cab TRD
    3" ome lift 883. Fnfx pros.
    What's it measure from mid hub to fender? It doesn't look too crazy lifted....just that the tires are small.
  6. Mar 23, 2017 at 8:39 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    I didnt shave mine. No issues. Love how they feel too
    2002Tacoma4x4 likes this.
  7. Mar 23, 2017 at 8:42 PM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    :rofl::rofl::rofl:
  8. Mar 23, 2017 at 8:44 PM
    -40
    -40 Well-Known Member
    North Dakota
    01 DC Camburg LT & 17 OR OME BP-51
    1 st Gen TRD Supercharger. URD 7th Inj. Camburg 4x4 LT Kit. Tundra Brakes. 3rd Gen just get’n started, OME BP51 Dakar HD, Camburg UCA & various armor.
    Did a little bit of everything today. image.jpg image.jpg image.jpg image.jpg image.jpg image.jpg image.jpg image.jpg image.jpg image.jpg
  9. Mar 23, 2017 at 8:50 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    I walked into that. My fault...i blame it on the pills and the booze..lol
    jubei[QUOTED] likes this.
  10. Mar 23, 2017 at 8:50 PM
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    2002Tacoma4x4, JPinFL and jubei like this.
  11. Mar 23, 2017 at 8:55 PM
    -40
    North Dakota
    That's where I'll strap at droop.
    Misplaced Nebraskan likes this.
  12. Mar 23, 2017 at 9:15 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I changed my first set at 82K. No electrode wear whatsoever. At the time, was doing the TB/WP. Did not do it because of loss of performance or MPG.
    Now at 85K on the current set. Same story, no loss of performance or unusual MPGs. I will swap in a new set along with new wires (still on originals) in the upcoming TB/WP swap.
    On my truck, there is no reason to do new plugs at 30K. In fact, 50K makes no sense based on history.
    2002Tacoma4x4, TheSaint and koditten like this.
  13. Mar 23, 2017 at 9:21 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I agree. No reason unless you are having performance issues. I'm a firm believer in keeping up on maintenance. I was the point I was changing all the shocks every 20k miles because I would blow one.
    If the plugs exhibited symptoms of failure, I would have changed them.
  14. Mar 23, 2017 at 9:32 PM
    Misplaced Nebraskan
    Zach
    Austin
    Looks like you had some fun. Love the Methods. Rubber specs?
  15. Mar 23, 2017 at 9:44 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I too believe in being pro-active with maintenance but some things I choose not to wait for signs of failure. Lower ball joints and the waterpunp are items I believe need to be changed before they become a problem. The waterpump because getting to it is a complex process. LBJs because a sudden failure is catastrophic.
    However, I don't see the value of doing this with spark plug. Sudden failures of spark plugs is unlikely.
  16. Mar 23, 2017 at 9:46 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Any chance you wanna lend a hand when I change my LBJs this week?
  17. Mar 23, 2017 at 9:49 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, I can help you. Where were you gonna do it? You want to come over and do it?
  18. Mar 23, 2017 at 9:55 PM
    Speedytech7
    Yeah that'd be great. Camelback said they're on their way
  19. Mar 23, 2017 at 10:04 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Weekend is better for me. But I will help regardless.
  20. Mar 23, 2017 at 10:05 PM
    Speedytech7
    The weekend after this could possibly work, we'll see what works when they make it to my doorstep.
    Digiratus[QUOTED] likes this.
