  1. Mar 28, 2017 at 5:35 PM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    Today I decided to go try 27 PSI in all tires which really makes a HUGE difference in ride quality over the 29 PSI stated on the door sticker. It rides really ruff at anything over 30 PSI and the handling suffers at anything under 25 PSI. I may go back to 29 PSI just because the tires look low at 27... I tend to run about 10-18 PSI on trails, depending on terrain. All this may change once I get new tires in a couple weeks. It never ceases to amaze me how much a small change in tire pressure effects everything.
    What air pressure are you guys running for DD/Street use or trail use?
  2. Mar 28, 2017 at 5:39 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    it varies if you have differnet wheels and tire sizes.
    Best way is to do the chalk test to figure out what your truck takes.
    For instance, with an 8'' wide wheel and 12.5'' wide tires...32psi is where i go to get even wear.
    My other truck is around 40psi. Skinnier tire and wider rim.
    27 seems pretty low.
    Low tire pressure makes a big difference though in ride, but too low and it can feel floaty at high speeds and increase wear and tear plus not wear even.
    ClevSix[QUOTED] likes this.
  3. Mar 28, 2017 at 5:40 PM
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    It hangs over the sides though
  4. Mar 28, 2017 at 5:47 PM
    ClevSix
    IL/IA
    Yea, the Chalk Test is one good way or if you have a good scale you can do the math to get the "ideal" pressure for tire wear. I'm not too worried about wear on my current tires. They will shred from dry rot before the tread wears out. Once I get new tires I will care more about wear.
  5. Mar 28, 2017 at 5:55 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    TIRE PRESSURE
    I ran 30 psi on my new 31" tires (28 in the rear). I checked the tread depth after 6 months, and they were wearing more on the outside than the inside. So I switched to 34/32 psi. Still rides nice (good quality tires and suspension)
    ClevSix likes this.
  6. Mar 28, 2017 at 6:03 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    And?
    Speedytech7 likes this.
  7. Mar 28, 2017 at 6:09 PM
    CStoy
    CStoy mountain-top maniac.
    majestic gold 4x4... 1/4 million miles and counting!
    improved toyota goodness.
    thats less than my smallest toolbox thats always in the bed weighs...oh, add a V6, double cab, 60lb skid, tools, porky tires, more tools, camper shell, spare fluids, food, tools, shoes, carseat, junk bag.... no wonder this thing is as low and slow as it is...
  8. Mar 28, 2017 at 6:14 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Damn. 116 per spark plug wire. Thats insane. Camelback is 85 a piece. Still crazy high
  9. Mar 28, 2017 at 6:16 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Get the NGK aftermarket set... Great quality and much cheaper for the whole set of three
    The stock wires are made by Sumitomo if you feel like you need to track them down instead though.
    cruiserguy and Fernando[QUOTED] like this.
  10. Mar 28, 2017 at 6:18 PM
    Speedytech7
    Also my LBJs came in today and apparently I did not need to order bolts as they came with them. So now I've got spares I guess.
    jjsul, sente3 and Digiratus like this.
  11. Mar 28, 2017 at 6:28 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    Where did you order them from?
  12. Mar 28, 2017 at 6:29 PM
    Speedytech7
    Camelback Toyota, I used the little TW discount too and got like $7 off lol
    Sicyota04[QUOTED] likes this.
  13. Mar 28, 2017 at 6:30 PM
    ID4VID
    ID4VID Gooner for Life
    David
    San Francisco
    1999 Tacoma SR5 4X4 "Great White"
    2.5" ICONs & ICON rear shocks 2.0
    Finally got around to welding my sliders, can't wait to hit the trails :woot:
    jjsul, sente3, 2002Tacoma4x4 and 5 others like this.
  14. Mar 28, 2017 at 6:31 PM
    Taco302
    Taco302 Well-Known Member
    Greenbow, Alabama
    2003 2.7L 5 spd 4x4 xtracab
    Gave "WhistlePig" a good wash and wax..cleaned her interior as well. While washing her wells i noticed her flaps were slack, so i snugged her bolts up with a wrench.
    2002Tacoma4x4 likes this.
  15. Mar 28, 2017 at 6:35 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Gonna call oreillys right now! Thank you!
    Nice rig
  16. Mar 28, 2017 at 6:47 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    i think the 01-04 PN for LBJs doesn't come with bolts.
  17. Mar 28, 2017 at 7:00 PM
    Sicyota04
    Morgan
    California
    04 DC 4x4
    I had my LBJ's replaced in 2010 under that recall Toyota had. That was at 180,000 miles and now I have 253,000 miles. So I've been shopping around for OEM. I've seen Concelli, Camelback, Toyotapartznet.com and 1 other website. Do you need to do the bushings on the LCA's too? I see the 01-04 3.4 4x4 LBJ's & bushings are more expensive than the 4 cyl 2wd's
  18. Mar 28, 2017 at 7:01 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Yeah I saw the uppers can be a PITA, I imagine going to be even more difficult with my spindle gussets on too from what I've seen in videos. It seems like the one is actually in decent shape but the other is definitely shot. Going to see how much it is for the machine shop to put those in too while they are doing my bearings. If it's $20-30 more then it's worth it to have them do it.
  19. Mar 28, 2017 at 7:04 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea you should think about doing them soon.
    2wd trucks have totally different suspension setups. At least the 5luger 2wd ones do which is what that is refering too. You'll want the 4wd ones.
    That said, OEM bushing replacement means replacing the entire LCA as the bushings don't press in and out.
    You can burn them out and press them out then install While Line 4runner LCA bushings though. Much cheaper but much more involved on the install. But not terrible. Good Saturday job.
    At 250k id do the LCA bushings, im sure they are near if not already dead.
  20. Mar 28, 2017 at 7:05 PM
    Speedytech7
    You don't have to do the bushings, and if you do decide to I would go with the Whitelines rather than press in new rubber.
