  1. Mar 31, 2017 at 8:18 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Lectric
  2. Mar 31, 2017 at 8:23 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Cool cool, that's right. Anybody do a cable locker for our rears? I know in other parts of world there are a couple companies that do for Cruisers and Hilux's. Is our rear end used in any other international models by Toyota? Anyone know off hand?
  3. Mar 31, 2017 at 8:25 AM
    Speedytech7
    If you already have the elocker axle there are cable conversions for it as well as at least one air actuator conversion.
  4. Mar 31, 2017 at 8:29 AM
    cruiserguy
    Elijah
    SEKS
    Oh okay, and non e-locked axles are SOL then for a cable locker? I'll prolly just have to go lunchbox locker than, when the time comes.
  5. Mar 31, 2017 at 8:51 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Ahh. I see. Thank you
  6. Mar 31, 2017 at 10:03 AM
    Ak4T777
    Ak4T777 Well-Known Member
    Kevin
    2003 Tacoma crew cab
    OME lift 3" lift 1.5" lift shackles Aftermarket bumpers 1" body lift
    Just the lighting. Its mystic gold I believe
  7. Mar 31, 2017 at 10:15 AM
    Dannny boy
    Dannny boy Stab it and Steer
    AZ
    2002 loaded salvage, and a brand newly aquired 2000
    grey wire, buzzer yank, last click defrost, tack welded column, deckplate, intake silencer delete, led map/red overhead, led backups, underhood dual battery, onboard air, CS-144 big fucking alternator, big fucking alternator wiring, overhead rifle rack, airbag pistol safe, cab to camper 12 volt evap cooler, bug screen cab windows, onboard shower, solar panel and beer fridge!
    I must have one for my Desertaco. Would look awesome on the rear cabside with the gold paint.
    FLBAdrian[QUOTED] likes this.
  8. Mar 31, 2017 at 10:16 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Anyone know if I could fit the elongated '01-'04 style speakers in my '98 (with the round speaker style) without chopping up the door frame? What size factor is it?
  9. Mar 31, 2017 at 10:22 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Harrops are what the new Toyota Tacomas have in their diff basically. They are an electromagnetic elocker. There are no external parts like on our E lockers. They engage Instantly, every time unlike our elockers. They also have a sweet roll back feature where they temporarily disengage if you say, kill the the truck while going up a steep ledge and start rolling backwards. This decreases the chances of binding by a lot in a bad situation.
    In theory, should be the most reliable locker out there. Nothing to get gunked up over time like our OEM elocker and no Air lines to break off/get snagged of filled with water. No OBA needed either, just power.
    You can get them for around 1300 i believe.
  10. Mar 31, 2017 at 10:29 AM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    Yes the harrop is more expensive, came out to 1200 for the harrop with 75$ install, just no worry of air leaks and what @Blackdawg said
    Fernando and stumbles like this.
  11. Mar 31, 2017 at 10:34 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Are these available for the both the 7.5" front and the 8.4" rear?
  12. Mar 31, 2017 at 10:38 AM
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
    Digiratus[QUOTED] likes this.
  13. Mar 31, 2017 at 10:41 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yes both.
  14. Mar 31, 2017 at 10:41 AM
    Prayn4surf
    Socal
    I believe so...Ward @Cruiser Brothers didnt mention a different axle being needed for the rear, @Blackdawg mentioned you might need a different axle for the rear. Only reason I didnt get the rear was cause i already have one with the stock elocker. And I didnt have the extra 1200 or so to purchase it. If I need a new axle then glad I didn't Ward or @Blackdawg can explain better than I...i was sold on the fail safe of the harrop. No airlines, no little motor to fail, or gears to bind together, just push the button and activate the electromagnet
  15. Mar 31, 2017 at 10:43 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Harrop rear Elocker is for the OEM Open diff/axle in our tacomas ONLY. It is more well known on here as the 8.4'' diff vs the 8'' of the Elocker our trucks come with. (they are still both 8'' ring gears fyi..just a weird name thing)
    So i you don't have an elocker from the factory, the ARB and Harrop are good choices.
    Prayn4surf[QUOTED] likes this.
  16. Mar 31, 2017 at 10:52 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    The harrops sound so damn appealing but would cost me an extra $800 over the life of my truck for something that only gets used in really bad situations and can even potentially make a situation worse if abused/used improperly. One day on my next build maybe.
    jubei likes this.
  17. Mar 31, 2017 at 10:53 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea i brought that up to them that the cost difference..is rather big. They say that it gets offset because you don't need OBA...
    But then i pointed out you can run ARBs cheaply and more reliably than an air compressor with small CO2 bottles. And you need OBA anyways so more people see that as a good investment....
    Maybe some day they will come down a bit. But until then, i don't see a lot of people going for them over ARBs really..
  18. Mar 31, 2017 at 10:54 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Doesnt sound like a bad option
    Prayn4surf and Blackdawg[QUOTED] like this.
  19. Mar 31, 2017 at 10:56 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Not to mention ARB is running the promo right now that gives you a cksa12 or ckma12 with the purchase of one or two lockers respectively. I'll be ordering my diffs before the promo ends April 30th to take advantage of it.
    Blackdawg[QUOTED], stumbles and jubei like this.
  20. Mar 31, 2017 at 10:58 AM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Blackdawg and Prayn4surf like this.
