  1. Apr 3, 2017 at 11:46 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    How far did you turn the steering wheel? As long as you did not turn it more than 2.5 turns from center, you should be ok.
    Regardless, its not a hard fix. The clock spring is under the steering wheel. Once the wheel is removed, its right there in the middle of the column.
  2. Apr 4, 2017 at 12:03 AM
    Penten
    Penten Well-Known Member
    Peter
    Iowa
    Yeah I'll need to replace it I tried lining the wheel up with the rack when I should have done it the other way around
  3. Apr 4, 2017 at 3:34 AM
    2002Tacoma4x4
    2002Tacoma4x4 TRD 4x4 double cab
    C K
    Limited Edition Double Cab TRD off road 4WD
    Do the inside of the frane with eastwood internal frame, took me awhile to water pressure, dry then air pressure then paint, i ordered 3 cans they did ok but If I will have to do it again, then next time i will order 5 or 6 to apply a more generous coat.
  4. Apr 4, 2017 at 6:49 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    There is a set of deavers (J59's) for sale near me that I can get for $350 with only a couple thousand miles on them. I know as is with the tool box, tube bumper, jerry cans, and 35" spare the deavers don't stand a chance, but was contemplating putting a chevy spring in them to assist with the weight. But at that point I am spending the same amount as dakars go for brand new. I think those are going to be the route I end up going since I have no need for an all pro expo pack I feel. Been mulling this shit over for quite some time now.
    Word. Impact helps a great bit on that staked nut.
    jubei likes this.
  5. Apr 4, 2017 at 7:53 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    So I finally ran out of windshield washer fluid (nothing comes out and I can hear the pump whining), but the low washer fluid level warning light never turned on.
    Is the sensor broken?
    EDIT: Well after some investigation, the RainX fluid I was using damages the fluid level sensor. There's a class action lawsuit against RainX since they are refusing to acknowledge that their fluid damages vehicles.
    EDIT 2: Okay maybe I'm really dumb, but does the Tacoma even have a sensor light? I could have sworn the dash has a low washer fluid light.
    DustStorm4x4 and 2002Tacoma4x4 like this.
  6. Apr 4, 2017 at 8:57 AM
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    I remember when I used to have a windshield wiper reservoir :rolleyes:
    Silver02Taco and jubei like this.
  7. Apr 4, 2017 at 9:00 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    There is a low level light. But only in certain years..im struggling to remember the start year though..
    95-97s didn't have a low sensor though.
  8. Apr 4, 2017 at 9:04 AM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    My 95 did not have sensor and of course no light. When the original washer fluid reservoir shattered I bought oem new one just to find out that it has a big round hole at the bottom. Parts guy told me that my original without the sensor is not available anymore, so I have to buy a sensor (even I don't have any wires to connect it to) just to plug a hole. I was cheap, and I used a round plug instead.
    So I guess all newer models have washer fluid level sensor and light, my 1st gen was cheap, no sensor, not light. Heck, I don't even have a low fuel warning light. My only warning is see the needle goes near E.
    2002Tacoma4x4 likes this.
  9. Apr 4, 2017 at 9:07 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    I didn't realize my dashboard had a lot of warning lights... until I shone a bright flashlight at it.
    It has the low fuel warning light, low washer fluid light (I think), and even the ABS light (even though my truck did not come with an ABS system). It even has the cutout in the center for the 4WD system.
    It probably has more, it's just hard to see them.
  10. Apr 4, 2017 at 9:08 AM
    Keep on Truckin'
    Keep on Truckin' Well-Known Member
    Jarvis
    Indiana
    02 Imp. Red - Ext. Cab SR5 4x4- 2.7- Auto
    Rear Locker, TRD Alloy Wheels & Cooper AT3 Tires, Camper Shell ,, K&N ,Icon AALS
    I used Icon 1 1/2" AAL -3 leaves & removed the factory overload it was a little high in the beginning ( 6 mos. ago) but now sits level -flexes well
  11. Apr 4, 2017 at 9:24 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Toyota just used the same cluster for everything and only added lights and wiring if you had them.
    land crusiers i think all have an OEM front diff locker light..but most don't have that option from the factory so people wire it up and it looks OEM.....i think its LCs...can't remember where i saw that.
  12. Apr 4, 2017 at 9:27 AM
    Keep on Truckin'
    Jarvis
    Indiana
    My 2002 doesn't have a sensor.
  13. Apr 4, 2017 at 9:29 AM
    Keep on Truckin'
    Jarvis
    Indiana
    Love the Labs, I had a black for ten years best dog ever.
  14. Apr 4, 2017 at 9:32 AM
    Keep on Truckin'
    Jarvis
    Indiana
    Does /did your horns work ? My clock spring broke & took out the horns also.
  15. Apr 4, 2017 at 9:59 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Should have built a new one. :p
    snowboard704[QUOTED] likes this.
  16. Apr 4, 2017 at 10:09 AM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Yea I still can. Out of like pvc/a different reservoir but haven't got around it it. Haven't really missed it actually :notsure:
  17. Apr 4, 2017 at 10:10 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I was able to build one using the stock internals out of a plastic bottle. Came out great haha
    jubei likes this.
  18. Apr 4, 2017 at 10:11 AM
    Manoa_Makia
    Manoa_Makia Member
    Painted the fender flares today
  19. Apr 4, 2017 at 10:22 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    must be a package thing then :notsure:
    my 03 does.
  20. Apr 4, 2017 at 10:26 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I have 3 and ones about to have puppies.
