  1. Apr 4, 2017 at 10:59 AM
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Yeah that shouldn't be a problem.
  2. Apr 4, 2017 at 11:23 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    So does my 04 DC
  3. Apr 4, 2017 at 11:25 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    My '98 SR5 had it but the wife's did not.
  4. Apr 4, 2017 at 11:33 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Not sure packages meant much on these trucks. I don't have auto windows, locks, cruise control, or even a sliding rear glass. But you bet your ass I have a washer light and a clock. o_O
  5. Apr 4, 2017 at 12:10 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    who fuckin knows lol Some guy at the factory is laughing maliciously about im sure.
    Jarob11 and rngr[QUOTED] like this.
  6. Apr 4, 2017 at 2:04 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    So what's better for rock crawling? Progressive, linear or digressive? Or is it just personal opinion. To me digressive seem like they would be great for dropping ledges
  7. Apr 4, 2017 at 2:17 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Mostly personal.
    Reh5108[QUOTED] likes this.
  8. Apr 4, 2017 at 2:44 PM
    Penten
    Penten Well-Known Member
    Peter
    Iowa
    My horn did work . I can't remember if it was before or after I turned my wheel though lol . I'll double check on my day off tomorrow
  9. Apr 4, 2017 at 3:15 PM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    Anyone ever lube the CV boot? while changing the LBJ I noticed that the rubber on the CV boot is looking dry. afraid it may crack. Inner CV boot have been changed when I did boot slide about 1.5 years ago. any lubricant spray that I can put on to keep it from drying and cracking?
  10. Apr 4, 2017 at 5:26 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    The FSM is pretty much useless. Does anyone know if the spacer and ABS ring are suppose to be loose on the front hub? Do they lock in place after the CV axle nut is tight? I want get this job over with
  11. Apr 4, 2017 at 6:09 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I took a long look at the dash in the sunlight, and there is indeed a low fluid indicator adjacent to the gas gauge. Looks like mine is broken from the silicone solution from the RainX.
    I bought some Windex washer fluid to replace it, it works better than the old one.
  12. Apr 4, 2017 at 6:10 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    well. Another 1000 pages gone by.
  13. Apr 4, 2017 at 6:13 PM
    koditten
    Kirk
    Central Michigan
    Pages, or posts?
  14. Apr 4, 2017 at 6:36 PM
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    I'm practicing on my new to me Lincoln 180 in preparation of welding on some sliders I bought of CL.
    Question about scab plates. Trail gear's scab plates are 3/16" and pretty cheap. Any reason to go to a thinner or thicker metal and fab some on my own? Did I read that our frames are 1/8" steel? should I match the thickness?
    Speedytech7 likes this.
  15. Apr 4, 2017 at 6:39 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Wasted some gas
  16. Apr 4, 2017 at 6:40 PM
    koditten
    Kirk
    Central Michigan
    I wouldn't waste much time thinking about it. The difference is very small. You will only have to change your settings a small amount, if any at all.
    jjsul likes this.
  17. Apr 4, 2017 at 6:45 PM
    Willrox1
    Willrox1 Well-Known Member
    Will
    NC
    2002 Tacoma TRD Off-road - manual
    BFG AT KO2 31 Bilstein 5100 OME 883
  18. Apr 4, 2017 at 6:52 PM
    Reh5108
    Idaho
    I think I remember mine being loose when I replaced the bearings. That doesn't mean it's right though.
  19. Apr 4, 2017 at 6:56 PM
    Itchyfeet
    There's tight as in no slop, but they just spin on the hub if that makes sense. Weird thing is I can't pull them off.
  20. Apr 4, 2017 at 7:04 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Glued some padding down. The super 77 doesn't hold well enough on the tighter turns, going to try something else but really this is just to smooth out under the future vinyl and add some padding while not potentially mold like jute padding would.
