  1. Apr 9, 2017 at 6:14 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    Part numbers please?!?!?!
  2. Apr 9, 2017 at 6:27 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I have not, but worth a try
    How would one check those? I've never had to check because they usually work, no I'm not but would that really affect it that much?
  3. Apr 9, 2017 at 7:13 AM
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    TacoVio, cruiserguy, sente3 and 9 others like this.
  4. Apr 9, 2017 at 7:16 AM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Part #s 4806135040 is the front bushing and 4806135050 is the rear bushing.
    https://parts.camelbacktoyota.com/p...siteid=214329&vehicleid=69991&diagram=8510190
  5. Apr 9, 2017 at 10:22 AM
    GreenMachine8
    GreenMachine8 Well-Known Member
    Elko, NV
    1996 Olive Drab Tacoma DLX 2.7L 4X4
    Off road fiber glass, rhino lined olive drab, retrofit headlights, kings/total chaos mid travel suspension.
    Need some help! Ordered an enclosed subwoofer/amplifier from Rockville. I have a 4 gauge wire running as my power source, 8 gauge wire running to my ground, and a 12 gauge wire running as my remote wire. I have the remote wire tapped into my cigarette lighter fuse. I've been getting the red "problem" light. Does it have to do with my remote wire? Does it have to go into the back of my stereo? Any options or help would be great.
  6. Apr 9, 2017 at 10:28 AM
    Madjik_Man
    Colorado Front Range
    I would imagine the remote needs to run to the back of your head unit so the sub recognizes the signal telling it to turn on
  7. Apr 9, 2017 at 10:33 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Did you double check you routed the wires in the correct configuration? It's pretty easy to do wrong. :anonymous:
  8. Apr 9, 2017 at 10:39 AM
    GreenMachine8
    Elko, NV
    So even though the red light is blinking it might not be on?? I have no idea in hell where the remote wire needs to go into the wire harness. I have a jvc kd-s36
  9. Apr 9, 2017 at 10:48 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Yeah I doubt checked to make sure the wires are set to 1-2 3-4 5-6 so I know it's not a mess up on the wiring
  10. Apr 9, 2017 at 10:49 AM
    Squeaky Penguin
    Brett
    That's not the right order.
  11. Apr 9, 2017 at 11:00 AM
    Madjik_Man
    I don't know what powered sub you have so its hard for me to troubleshoot. But if you have a lead, it's grounded and you have a remote hooked up to the cigarette lighter you will get power to the sub when the key is turned to the ACC setting. But your powered sub isn't getting the correct signal so it's probably telling you so by a bLinking red light.
    You have to hook the remote wire from your head unit to the power sub. Google your head unit model wire harness. It's simple. It's typically a blue wire or a blue wire with a stripe. But just find your wiring harness diagram and make the appropriate connection.
  12. Apr 9, 2017 at 11:03 AM
    Madjik_Man
  13. Apr 9, 2017 at 11:05 AM
    GreenMachine8
    Elko, NV
    So I just need to find the wire that goes to the wire harness and tap into that wire? I bought the Rockville rw10ca.
  14. Apr 9, 2017 at 11:06 AM
    Madjik_Man
    Blackdawg likes this.
  15. Apr 9, 2017 at 11:09 AM
    GreenMachine8
    Elko, NV
    Oh awesome! Just use the same gauge wire and I should be all set??
  16. Apr 9, 2017 at 11:12 AM
    Madjik_Man
    Correct.
  17. Apr 9, 2017 at 11:13 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Its not on. You need to tell the amp to turn on, thats what the part aon the amp(usually right next to the power and negative wires) is for. Doesn't need to be big. There will be a connection for it on your units harnness...unless it doesn't support subs in which case you need a new unit. But it should still have the remote wire for any external amps.
    Like Brett said..that is far from the right order. Definitely your problem! haha
  18. Apr 9, 2017 at 11:15 AM
    GreenMachine8
    Elko, NV
    Okay awesome! Thank you gents!
    Blackdawg[QUOTED] likes this.
  19. Apr 9, 2017 at 11:38 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Im no wire tech but i have seen my buddy do plenty of my audio. The remote wire does need to come out of the head unit to the amp
  20. Apr 9, 2017 at 12:23 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Hmm just tried it and it seems like it's not getting enough gas
