  1. Apr 9, 2017 at 6:36 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    So the receivers on the seats are from the 4runner?
  2. Apr 9, 2017 at 6:50 PM
    djcharlee
    djcharlee RETIRED SSGT OF MARINES
    Carlos
    Chula Vista, CA
    2020 Double Cab TRD OR
    Pro Comp Leveling Spacer 17" Icon Wheels Falken Wildpeak AT3W 285/70R17
    Un-Plastidipped my front bumper and polished it.
  3. Apr 9, 2017 at 7:13 PM
    2BeersPlease
    2BeersPlease Well-Known Member
    Removed that malignant growth from my front end (Waag bull bar) in preparation for a little sum sum from Homertaco. And gave her a bath too.
    Fender-matched my rear bumper with some left over Rust-Oleum bed coating. Went straight over the chrome, so I'm not expecting a durable finish.
  4. Apr 9, 2017 at 7:20 PM
    Madjik_Man
    Colorado Front Range
    Do you have a good ground? What did you ground it to? Any paint on either surface the ground wire is mated to?
  5. Apr 9, 2017 at 7:30 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Does anyone know if the 01-04 double cab interior door handles are interchangeable with the front and rear?
    I need to order two new ones for the front doors, and the ones made for the rear are 10 dollars cheaper than the ones made for the front door. The rear ones are also shipped with Amazon Prime, lol.
    TO RECAP: Will the rear doublecab interior door handles work with the front doors?
  6. Apr 9, 2017 at 8:17 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    That wheel tire combo looks bad ass, hombre.
  7. Apr 9, 2017 at 8:23 PM
    2BeersPlease
    Thanks. Looking forward to getting them dirty. Just need a month or so of warm weather to melt the snow. Might not be until the end of May.
  8. Apr 9, 2017 at 9:09 PM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    I parked my truck on the drive way and I noticed some oil on the ground. I look under and I see this is full of oil. This there a thread on more info on it, or the name of it. IMG_1147.jpgIMG_1150.jpg
  9. Apr 9, 2017 at 9:25 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Anyone ever replaced oem body mount bushings with poly's? Noticed my cab is sagging 1/4"+ compared to the bed by body line comaprison. Removing the front bumper necessary?
  10. Apr 9, 2017 at 9:36 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yes you must remove the bumper to reach them, actually with the relentless it may be possible to leave it on. I wouldn't do poly though, suspension is fine with poly because high stress and weight makes the impact less noticeable to the driver. But holding the cab I have a feeling unless it was a super soft durometer it would be more jarring. I'd get new rubber mounts.
  11. Apr 9, 2017 at 11:14 PM
    TacoVio
    Kolton
    CO/WY
    I thought about that also. Energy claims to be better than new oem both with longer life and better ride but i dont know. Need to find someone who has done it
  12. Apr 10, 2017 at 4:41 AM
    glenn27
    glenn27 Well-Known Member
    Central Virginia
    2002 Toyota Tacoma SR5 TRD package/Xtend cab
    I just washed mine Saturday--that's all...:bananadance::bananadance:
    j0shu4 likes this.
  13. Apr 10, 2017 at 6:11 AM
    BigSam1991
    BigSam1991 Well-Known Member
    Sam
    Picked her up today. Bone stock.
    muddog67, j0shu4, sente3 and 12 others like this.
  14. Apr 10, 2017 at 6:40 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I've got a set of ES body mount bushings that should be going in soon. Will report back.
    TacoVio[QUOTED] and SilverGhost like this.
  15. Apr 10, 2017 at 6:48 AM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    I've had stock mounts, ES poly mounts, and now a poly Daystar 1" body lift (oh noes!) that is integral to the mounts. So far, I definitely prefer the poly, but then again, I don't have any experience with brand new rubber mounts. I'm sure they ride nicely.
    One thing I noticed about the poly after the factory rubber was a reduction in higher frequency vibes and noise with a slightly harder feel on sharp hits to the suspension. But the poly also felt more 'planted' on turns, so that helped offset the slightly harsher feel on big hits. YMMV.
  16. Apr 10, 2017 at 7:19 AM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
  17. Apr 10, 2017 at 7:28 AM
    mystik cabs
    mystik cabs Well-Known Member
    Brian
    North Stonington, CT
    '04 TRD DBL Cab
    Proper torque spec for Spidertrax is 85 ft lbs, correct? red or blue Loctite?
  18. Apr 10, 2017 at 7:30 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I always did 90. Never used locktite on my spacers. Would check them time to time..never got loose once.
  19. Apr 10, 2017 at 7:40 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    How would you convince someone not to do Moog LBJ's? "They've got a lifetime warrenty"
  20. Apr 10, 2017 at 7:40 AM
    ToxicTwin
    ToxicTwin Money Talks...It Says Goodbye
    Robert
    Glendale AZ
    2009 TRD OR
    No, have to swap to Tacoma receivers... ordered from dealer online, cost reasonable and easy to swap.
