  1. Apr 13, 2017 at 12:08 PM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    Drive it to and from Massachusetts this week. Longest drive I've done on the truck. Did just fine. Really glad I opted to take care of all those sway bar parts. There were some times, I could tell a huge difference from before.
    Also, I lost both halves of my cat's heat shield on the streets of Boston :p
    Is it possible to buy a shield somewhere?
    jjsul likes this.
  2. Apr 13, 2017 at 12:23 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    After a three week stint on jack stands I'm back in baby's arms. The front end refresh from hell included:
    Koyo bearings
    New backing plates (old ones were rusty)
    New spindles (so many bolts broke off in the old ones that it would have been a cluster trying to remove them)
    ABS sensors (ouch $$ I guess after 13 years they bonded in place)
    Rotors
    Pads
    Brake hardware kit pins and springs
    Upper balljoints
    Lower ball joints
    Energy steering rack bushings
    Good ridge stainless brake lines
    Tie rods ends
    Bilstein shocks
    A metric tonne of hardware to attach all said parts. I'm sure the parts counter guy thought i was nuts.
    With the exception of the pads, rotors and bearings everything was OEM Toyota
    Check those lower ball joints guys mine felt tight on the truck and had a notchy feeling off the truck.
  3. Apr 13, 2017 at 12:49 PM
    sente3
    sente3 -
    North Jersey
    That's one hell of a refresher. Don't want to imagine the cost, especially with so many OEM parts.
  4. Apr 13, 2017 at 1:00 PM
    Itchyfeet
    The spindles and the ABS sensors stung pretty bad. One expects the spindles to be $$ the ABS sensors not so much, they're over $200 a side and aftermarket ones are just a huge nope.
  5. Apr 13, 2017 at 1:07 PM
    JKU3000
    JKU3000 Well-Known Member
    Birmingham, Alabama
    2014 Tacoma
    Hey guys I need some 4 gauge wire for my aux fuse box. Could I get some at lowes, or better to order off of Amazon?
  6. Apr 13, 2017 at 1:24 PM
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Are LCA skids really worth it?
    Seen them around but don't think I've ever hit them... have hit everything else though :notsure::popcorn:
  7. Apr 13, 2017 at 1:50 PM
    GreenMachine8
    GreenMachine8 Well-Known Member
    Elko, NV
    1996 Olive Drab Tacoma DLX 2.7L 4X4
    Off road fiber glass, rhino lined olive drab, retrofit headlights, kings/total chaos mid travel suspension.
    I got some from a local audio shop. You might have some luck there.
    JKU3000[QUOTED] likes this.
  8. Apr 13, 2017 at 2:05 PM
    JKU3000
    Birmingham, Alabama
    2014 Tacoma
    Thank you great idea
  9. Apr 13, 2017 at 2:24 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    should of just deleted the abs. Its not very good on these trucks anyways.
  10. Apr 13, 2017 at 2:26 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    When shopping for the wire make sure you get all copper strand - some cheap wires are aluminum with copper surface. Lowes wires are very stiff, very thick and low number of strands. Look for something with thin strands. Some welding cables are good too.
  11. Apr 13, 2017 at 2:27 PM
    RysiuM
    Rysiu
    Your old LBJ were OEM, right?
  12. Apr 13, 2017 at 2:38 PM
    Itchyfeet
    I have zero interest in dealing with dash lights or if I pass this truck on explaining how the ABS was deleted.
    The old ball joints were OEM I don't know if they were original.
  13. Apr 13, 2017 at 2:47 PM
    2004TacomaNavy
    2004TacomaNavy Well-Known Member
    Brian
    Oak Harbor, WA.
    04 Extra Cab 4X4 SR5
    All Pro rock sliders, U-Bolt flip kit, Shock mount relocation tabs, All Pro Billy 3" lift front and back, 2014 Tundra Bed Rail tie down system, Fuel 17X8.5 Wheels on 32's, LED front light bar, Raptor style grill W/lights, Tinted Headlights w/LEDs, ARB Dual Air Compressor W/ 2 Gal. Tank, Smoked Tail Lights, Double Din Sat radio w/ back-up camera, Redline Hood Struts, ARB Dual air compressor W/ 20 Gal. air tank, Sig P320C Security System!
    Please do NOT go to MAACO!!! They chemically etch the surface and do NOT use the proper method of sanding to repaint the surface and then clear coat it. The paint does not last or stick properly. There is a reason they are cheap. They cut corners and do NOT use the proper process. They also do NOT remove the glass and rubber like they should. If your going to do it, do it right!
    Deathbysnusnu likes this.
  14. Apr 13, 2017 at 3:15 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Changed out winter tires.
    Aligned lights.
  15. Apr 13, 2017 at 3:30 PM
    Madjik_Man
    Colorado Front Range
    That's a sexy truck
    2002Tacoma4x4 likes this.
  16. Apr 13, 2017 at 3:44 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Finally finished the table on my swing out.
    -40, j0shu4, Silver02Taco and 11 others like this.
  17. Apr 13, 2017 at 3:45 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Very nice. What kind of extra support did you do for the frame ends? Any pics?
  18. Apr 13, 2017 at 4:16 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    For the most part wrapped up my vinyl install. What a pain in the dick. Still have some other shit to wrap up before I put the back wall/drivers side panel fully back.
    Also mocked up my second paranoid panel.
  19. Apr 13, 2017 at 4:19 PM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    That looks really good, Mike!
  20. Apr 13, 2017 at 4:22 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Thanks man! I still need to wrap the cubby covers in vinyl too. I kinda hate the bulges at the corners going up the cubby wall but I am hoping it will settle eventually. Cutting all the holes for the seat belts/seat bolts and reconfiguring the center console to sit lower were also huge obstacles.
    jjsul likes this.
