  1. Apr 18, 2017 at 4:50 AM
    TacoSauce04
    TacoSauce04 Well-Known Member
    David
    2004 Lunar Mist SR5 TRD Double Cab 4x4 Tow Package
    ARE Shell
    3" Fabtech Level kit
    New Comptech 7069 15x8 alloy wheels
    New BF Goodrich tires. 33x12.5x15
    Black lug nuts
    X3 Yakima bike holders
    X6 Quick Fists
  2. Apr 18, 2017 at 6:33 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Mine is just zip tied to that dash surround.
  3. Apr 18, 2017 at 6:44 AM
    2002Tacoma4x4
    2002Tacoma4x4 TRD 4x4 double cab
    C K
    Limited Edition Double Cab TRD off road 4WD
    Nice looking truck , one day I will get armor and loaded, for now I think I have the same sliders got them second hand without the screws to install them , can you please send me a picture of how are they set up to to frame ? I guess need to purchase X amount of screws, X size\ length ? Thanks in advance.
  4. Apr 18, 2017 at 10:41 AM
    BerndtTaco
    BerndtTaco Active Member
    95.5 Tacoma 2.7 4x4
    3 inch Rancho lift, custom front and rear bumpers
  5. Apr 18, 2017 at 11:24 AM
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
  6. Apr 18, 2017 at 11:26 AM
    BerndtTaco
    95.5 Tacoma 2.7 4x4
    Nope they said only the right one was wrong. Called toyota. The part number of the one I got is for a 4 runner not the one I ordered so it looks like I'll be doing it myself in the driveway. I've heard on here that the lowers aren't hard to do. I'll have to contact the seller
  7. Apr 18, 2017 at 11:59 AM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
  8. Apr 18, 2017 at 12:16 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yeah the 4runner ones are different..believe it or not. The ball joint itself is the same. But the connection to the tie rod is different. The tacoma's outer tie rod ends are much larger then the 4runners. And they are straight vs bent like ours.
    No idea why though.
  9. Apr 18, 2017 at 12:31 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    x2 Trail damage multipliers. :rolleyes:
    Ak4T777, alee891 and 2002Tacoma4x4 like this.
  10. Apr 18, 2017 at 12:37 PM
    2002Tacoma4x4
    C K
    Thank you both , good to know , let see if Tacosauce can give me closer look \ pictures on how the installation points looks like \where to install and the bolt sizes need it for those nerds.....i pulled the trigger on a benjamin , didnt know the difference but match the chrome of this DINO. I guess i will have to use them for city until eventually get the sliders for off road later on.
  11. Apr 18, 2017 at 1:11 PM
    TacoSauce04
    David
    ARE Shell
    Ill send pics asap. Still in my cubicle
    2002Tacoma4x4 likes this.
  12. Apr 18, 2017 at 1:47 PM
    TACO MASTER
    TACO MASTER Well-Known Member
    Maroon 1996 Tacoma SR5 V6 4X4
    OME front and rear suspension, ABR deluxe bull bar, Black FJ 17 inch SEMA wheel with treadwright 265/70/R17 E, Bushwacker fender flares, Stock rear bumper, Eagle 4 wheel camper.
    Need a bit of advice folks. I am trying to get my transfer case fluid changed and I am unable to get the fill plug out. I might have been cross threaded when Toyota changed it last. I tried a pry bar....and impact wrench. Any other ideas ???
    Rear of case fill and drain
    Drain plug
    F'd up fill plug
  13. Apr 18, 2017 at 1:53 PM
    BigSam1991
    BigSam1991 Well-Known Member
    Sam
    sick truck dude.
  14. Apr 18, 2017 at 1:58 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Flex test :) will eventually have a sway bar and would never flex this far with shocks anyway but that would be 30" difference at the wheels with no binding
  15. Apr 18, 2017 at 2:23 PM
    AZ4x4Taco
    AZ4x4Taco Well-Known Member
    Jeremy
    Tucson AZ
    01 4x4 TRD
    Cheap spacers and blocks, 33's, poor man upgrades.
    Milwaukee quad????? i love their tools
  16. Apr 18, 2017 at 2:26 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    I had to buy a socket one size smaller and hammer it on there to get it off when it was like that. It happened to me on my rear diff fill plug.
  17. Apr 18, 2017 at 4:20 PM
    TacoSauce04
    David
    ARE Shell
    Here are the brackets for the tube side steps
    2002Tacoma4x4[QUOTED] likes this.
  18. Apr 18, 2017 at 4:26 PM
    2002Tacoma4x4
    C K
    Thanks a lot:)
  19. Apr 18, 2017 at 6:41 PM
    TACO MASTER
    Ok thanks...That's a good idea. I was gonna try some heat to it with a torch.
  20. Apr 18, 2017 at 6:46 PM
    TacoSauce04
    David
    ARE Shell
    Bye bye for now, chrome.
    Front chrome got plastidipped. I will remove it later. Ill sand it all down/prime/paint when i get satoshi grill material. This is good enough for now.
