  1. Apr 20, 2017 at 7:23 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Possibly the light in the ashtray?
  2. Apr 20, 2017 at 7:25 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    No I have the wires for that one already still hooked up. and it didn't match the wires I cut that used to light the ring on the cigg lighter either.
    Also anyone know this one? It's not hot and is on the left side of the dash. I am assuming it's for that button auto guys have for towing or whatever but not sure.
  3. Apr 20, 2017 at 8:00 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    White-green and white-black wires? By dimmer for dash lights? Extra plug for dimmer rheostat differant level of options model truck. Can be used to dim added accessories with dash lights. On ground side of lights. The one in the center I'm not sure of.
  4. Apr 20, 2017 at 8:03 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    This one is the one i mentioned above
  5. Apr 20, 2017 at 8:03 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    This one was for the center dash, already confirmed it's on the dimmer circuit lol
    It' can't be that, I tested it and there is no hot to it.
    mechanicjon[QUOTED] likes this.
  6. Apr 20, 2017 at 8:05 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Color wires does center one have.
  7. Apr 20, 2017 at 8:35 AM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    Lol I'm heading to pick n pull today, I'll grab one if I see it, passenger side yeah?
  8. Apr 20, 2017 at 8:43 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Are you asking about a front CV axle? Or a rear axle? Which side, driver or passenger?
    What is your evidence that axle is 'bent'?
  9. Apr 20, 2017 at 8:51 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Going to take more then a hammer to bend a shaft
  10. Apr 20, 2017 at 9:09 AM
    GreenMachine8
    GreenMachine8 Well-Known Member
    Elko, NV
    1996 Olive Drab Tacoma DLX 2.7L 4X4
    Off road fiber glass, rhino lined olive drab, retrofit headlights, kings/total chaos mid travel suspension.
    If you're 4 wheel drive does this part have to be extended?? Hopefully dsm didn't get confused on my custom shocks :confused:
  11. Apr 20, 2017 at 9:11 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    :confused:
    Are you talking about extended travel or like 2nd gen Kings
  12. Apr 20, 2017 at 9:14 AM
    GreenMachine8
    Elko, NV
    Well I ordered custom with the reservoirs. So I should've got extended travel shocks with resis for a 4 wheel drive.
  13. Apr 20, 2017 at 9:16 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Extended travel just takes out a spacer on the inside IIRC so you won't be able to tell from just looking at it
  14. Apr 20, 2017 at 9:19 AM
    GreenMachine8
    Elko, NV
    I just heard somewhere that that bottom piece has to be extended for our 4X4's??
  15. Apr 20, 2017 at 9:33 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I'm 4x4 and these are what mine look like
  16. Apr 20, 2017 at 9:33 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Not that I've seen. But i don't have personal experience with Kings. There's enough pics on here to be able to find a picture of it.
  17. Apr 20, 2017 at 9:34 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Prerunners look identical to your original ones.
  18. Apr 20, 2017 at 9:36 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Yeah I know same shock can work for all first gens except 5-lugs
  19. Apr 20, 2017 at 9:59 AM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    These Depo tail light assemblies from Amazon seem to be built pretty nice. I can't really tell much difference from the OEMs. I am modifying them for red and amber Vleds.
    TacoVio, 2002Tacoma4x4 and FLBAdrian like this.
  20. Apr 20, 2017 at 10:11 AM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Here's a pic with the VLEDS.
    04yota likes this.
