  1. Apr 24, 2017 at 9:43 PM
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    That would possibly work for the height but the width wouldn't clear other components to fit in the upper slot. Gonna pick up the other aforementioned alternator and install it since it's the correct one :D
  2. Apr 24, 2017 at 9:52 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Not likely. Taco calipers barely clear as it is.
  3. Apr 24, 2017 at 10:00 PM
    Tacofart
    Tacofart Well-Known Member
    Brennan
    San Diego
    04 3.4 4x4 Dual cases/ Lockers
    Threw code po306. Replaced sparkplugs and wires.
  4. Apr 24, 2017 at 10:01 PM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    Why'd you remove the manifold to do plugs/wires?
  5. Apr 24, 2017 at 10:06 PM
    Tacofart
    Brennan
    San Diego
    Clean and check fuel injectors
  6. Apr 24, 2017 at 10:07 PM
    sente3
    sente3 -
    North Jersey
    Ah gotcha :thumbsup:
  7. Apr 24, 2017 at 10:17 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Awesome! Thanks for the reply. I need to weigh my little pig
  8. Apr 25, 2017 at 4:10 AM
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    Anything else I should do / check / clean when I do my VCG this month? Someone just mentioned cleaning injectors?
    I have the VCG, spark plug tube gaskets, cam shaft caps, half moons, PVC gasket and new valve.
  9. Apr 25, 2017 at 4:14 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Check valve clearance.
    jjsul[QUOTED] likes this.
  10. Apr 25, 2017 at 5:52 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Are you eliminating the LPV?
  11. Apr 25, 2017 at 6:18 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Yeah that has been gone for a long time, I'm 4 linked
    mechanicjon[QUOTED] likes this.
  12. Apr 25, 2017 at 6:50 AM
    col. sandurz
    col. sandurz Well-Known Member
    thanks for tip. So these would work well with multiple lights/light bars..... i.e. Toggle up for bumper mounted light bar, toggle down for bumper plus a windshield/roof light bar for maximum blindness.
    I could use it for bumper mounted light bar and second switch for reverse led lights. Just means that when using revers lights to back up and trailer I would have to have the front light bar on also. Maybe a moot point until I figure out which size switch fits the punchout.
  13. Apr 25, 2017 at 8:00 AM
    Sonam
    Sonam Active Member
    2002 Tacoma Xtracab SR5 4WD
    This past week, I replaced all the non-iridium spark plugs at 91,000 miles, did oil and filter change, and picked up this new cap. Got a really good deal on it, especially for how good a condition it is in. Now I'm ready for camping after 7 months of searching for a fiberglass high-top shell that doesn't leak. Besides the fact that I love camping, it is also part of my job in the summer! And the bonus is the rack on top (I'm thinking about getting cargo bag. Anyone got one for cheap?), interior dome light and LED 3rd brake light. I set up the wiring for the lights thanks to the instructions I found here on TW. Probably will install reflectix insulation on the interior and/or headliner. Then make it nice for camping but easy enough to remove camping gear for when I need to haul stuff throughout the summer. Keeping it dynamic is important for my purposes.
  14. Apr 25, 2017 at 10:50 AM
    99SuperTaco4x4
    99SuperTaco4x4 Well-Known Member
    1999 3.4L V6 Tacoma, 4x4, TRD Supercharger
    Does the shell bang the cabin at all being that close?
  15. Apr 25, 2017 at 10:59 AM
    AZ4x4Taco
    AZ4x4Taco Well-Known Member
    Jeremy
    Tucson AZ
    01 4x4 TRD
    Cheap spacers and blocks, 33's, poor man upgrades.
    Have any pics of those projecting at night? wondering their output
  16. Apr 25, 2017 at 11:03 AM
    Sonam
    Sonam Active Member
    I haven't noticed yet. I pushed it pretty tight against the cab, probably will experiment with it pulled back a little bit so it isn't touching or banging or scraping. A few days this week I noticed some rumble/banging noise, but discovered it was because I hadn't closed the driver side door all the way.
  17. Apr 25, 2017 at 11:18 AM
    Reh5108
    Idaho
    If you take it off road you'd be surprised at how much your bed flexes. I'd give a minimum of and inch clearance at the top.
  18. Apr 25, 2017 at 11:26 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Took a little bit more time to get a pic but here it is with the hood on. Finally installed my hood struts which is why the hood was off
  19. Apr 25, 2017 at 12:13 PM
    TacoSauce04
    TacoSauce04 Well-Known Member
    David
    2004 Lunar Mist SR5 TRD Double Cab 4x4 Tow Package
    ARE Shell
    Hello, I am thinking about buying this bumper for my 04
    Is it gonna work? I know ill have to weld it but I want to know for sure before I drive 3.5 hours to get it.
    https://austin.craigslist.org/pts/6101079727.html
    Can I install it on my truck?
  20. Apr 25, 2017 at 12:20 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    @cynicalrider has installed one on his 01. So it'll work
    scottalot likes this.
