  1. Apr 25, 2017 at 12:26 PM
    TacoSauce04
    TacoSauce04 Well-Known Member
    David
    2004 Lunar Mist SR5 TRD Double Cab 4x4 Tow Package
    ARE Shell
    Awesome thanks for the quick response, hitting the road now! My first trip out of town in my Tacoma. Can't go very fast on my M/T tires but ill get there.
    2002Tacoma4x4 likes this.
  2. Apr 25, 2017 at 12:30 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    it'll fit. But not bolt on.
  3. Apr 25, 2017 at 12:34 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Bout to go and have a look see at Whitey's for ya
    Blackdawg[QUOTED] likes this.
  4. Apr 25, 2017 at 12:36 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    SWEEETTTT
    Lemme know :popcorn: If this doesn't work..pulling the blower off.
    Speedytech7[QUOTED] likes this.
  5. Apr 25, 2017 at 12:49 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    This. Which is kinda a down side. Ideally you should cut the old welds off and separate it from the frame, and then build a crossmember for it to bolt to. Addicted designed these to bolt onto a welded crossmember the supplied. OR if that thing is just bolted to the frame parts, un bolt it and use that crossmember to weld in. You have a decent amount of work ahead of you to make it work but it's a great looking bumper to have.
    Okay back to my regularly scheduled vacation :p
    jjsul, jubei, SwampYota and 4 others like this.
  6. Apr 25, 2017 at 12:50 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Knew you were on vacation figured you'd see it when ya got back. Have a good one :cheers:
  7. Apr 25, 2017 at 1:10 PM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    You took the hood off just to install struts? Never heard of someone doing that. I didn't. They install just fine with the hood on. If you were to install those coil springs instead of struts, I would understand, but with struts I don't see a reason.
    But hood struts were a great mod. So very much worth it.
  8. Apr 25, 2017 at 1:11 PM
    Speedytech7
    For the record I still think it's mechanical
    He had to get his ditch bracket to clear the snork so that made it easy to reach bolts.
    BYJOSHCOOK likes this.
  9. Apr 25, 2017 at 1:13 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    ^^^^ I had to remove my ditch brackets to make sure the snorkel cleared. Since I couldn't get my drill in there last time I tried to install the struts. So since it was Thursday night and I had till Saturday morning to get everything done I said screw it hoods coming off
  10. Apr 25, 2017 at 1:14 PM
    sente3
    sente3 -
    North Jersey
    Ah ok. Hadn't considered that getting in the way.
  11. Apr 25, 2017 at 1:16 PM
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    Installed an ADD W1 catch can today. Not really where I wanted it but I sheared a bolt in the location I really wanted it. This might be better though incase I relocate the washer reservoir over the passenger side wheel well. We shall see what the catch can catches...
    muddog67, Ace115, Nebrasker and 6 others like this.
  12. Apr 25, 2017 at 1:17 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Hahaha I'm just messing man. I actually forgot to bring a magazine to the beach today so hopped on here on my phone. And thanks! Def have been loving it down here.
    BYJOSHCOOK[QUOTED] likes this.
  13. Apr 25, 2017 at 1:42 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    in what way?? run fine other then it feeling held back and choked off.
  14. Apr 25, 2017 at 1:55 PM
    Xjman1
    Xjman1 Well-Known Member
    JB
    2004 Tacoma TRD 4X4 X-CAB
    King coil overs, Rear shackle lift
    Stuffed it in garage last night and dug Jeep out. Blew SAW CO in Gorman this past weekend and need to order parts. Turns out Jeep needs valve cover gasket and injector o rings too. Just cant catch a break on these vehicles. At least its all small stuff
  15. Apr 25, 2017 at 2:42 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Anyone have anymore info on the Front Range kit yet? Mainly price...
    Ceddingermtb and ClevSix like this.
  16. Apr 25, 2017 at 3:33 PM
    Sonam
    Sonam Active Member
    2002 Tacoma Xtracab SR5 4WD
    Yeah, I noticed how much the bed flexes when I had another cap on the truck. The window frame on that cap protruded out, so there was this rapid banging against the truck cab window. Luckily, I noticed it and immediately moved the cap back about 1/2 inch or something and it was fine. Never went off-road with that cap, but did with this new red cap. I still didn't notice any banging, but I think it is probably rubbing then, perhaps causing just as much damage as a bang-action. The top of this cap doesn't touch, only the sides. In any case, I appreciate you pointing this out. I'm going to adjust it soon for sure.
    TheSaint and Reh5108[QUOTED] like this.
  17. Apr 25, 2017 at 4:21 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Also waiting...anxiously
  18. Apr 25, 2017 at 4:27 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Is there a thread on this anywhere?
  19. Apr 25, 2017 at 4:35 PM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    Where did you buy that washer fluid tank?
  20. Apr 25, 2017 at 4:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I've emailed them asking. No response.
    Guessing it'll be similar to a normal LT kit though since it'll take custom CV shafts.
    So id guess 2 grand.
    Reh5108 likes this.
