  1. Apr 26, 2017 at 4:39 PM
    2002Tacoma4x4
    2002Tacoma4x4 TRD 4x4 double cab
    C K
    Limited Edition Double Cab TRD off road 4WD
    Is this 1st time doing this change? if no codes what will be the rule ? 100k miles ? So far 64k and dealer said i still got the original, they recommend what u just did for 290!?&$@@ wtf...
  2. Apr 26, 2017 at 4:43 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    DIY. Super easy. The plugs are cheap. OEM wires are not though. Easy to do them. Just don't cross up the wires.
    Id do plugs ever 30-50k personally. But you can check them to see if they need replaced easily. You don't have to remove the intake like he did.
    2002Tacoma4x4[QUOTED] likes this.
  3. Apr 26, 2017 at 4:46 PM
    2002Tacoma4x4
    C K
    I drive over 83 mph with MT tire or is AT? Oh well is the E load 245/16/R16 keller safari, no vibes at all....smooth as an suv.
  4. Apr 26, 2017 at 5:24 PM
    2002Tacoma4x4
    C K
    Changed all the fluids to synthetic all at once and fuel injection cleaned it runs even smother than before.. it will be my imagination? All BG products.
    cruiserguy likes this.
  5. Apr 26, 2017 at 5:33 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Got the VLEDS mocked up.
    2004TacomaNavy, TacoVio and SwampYota like this.
  6. Apr 26, 2017 at 6:05 PM
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    May try it first with current belt as it's pretty new, but I'll be ready for the other if needed. And you know if there are any issues... You'll get the notification:thumbsup::rofl:
    Blackdawg[QUOTED] likes this.
  7. Apr 26, 2017 at 6:38 PM
    Ak4T777
    Ak4T777 Well-Known Member
    Kevin
    2003 Tacoma crew cab
    OME lift 3" lift 1.5" lift shackles Aftermarket bumpers 1" body lift
    Swapped out the chrome lug nuts for some black ones. Looks way better!!!
    B4....
    After....
  8. Apr 26, 2017 at 6:39 PM
    Misplaced Nebraskan
    Zach
    Austin
    Such a small thing that makes a big difference. :thumbsup:
    MtRSQ and Ak4T777[QUOTED] like this.
  9. Apr 26, 2017 at 6:45 PM
    Ak4T777
    Kevin
    I know right!!
  10. Apr 26, 2017 at 6:48 PM
    Ak4T777
    Kevin
    Also put some shiny valve stem caps on! Old ones were getting dull. Yes, they are spent .40 cal shell casings from my XDM :D
  11. Apr 26, 2017 at 6:49 PM
    Misplaced Nebraskan
    Zach
    Austin
    did you thread the casing? or is it pressed over?
  12. Apr 26, 2017 at 6:56 PM
    Ak4T777
    Kevin
    Just took a razor blade and cut off some of the "ribbed" notches on the plastic caps and pushed the casings on. No glue, just friction holding them on. The old ones were on for over a yr and driven at 85mph at times on the highway :) never lost one.
  13. Apr 26, 2017 at 6:57 PM
    Misplaced Nebraskan
    Zach
    Austin
    :thumbsup: matches the Bullet Hole style wheels theme nicely too.
    Ak4T777[QUOTED] likes this.
  14. Apr 26, 2017 at 7:20 PM
    Ak4T777
    Kevin
    Never really noticed that until you said that. Now I like them even more haha. Goes with my plate well too! Nice and subtle. Only AK peeps understand it, and yes I also support 1st responders!
  15. Apr 26, 2017 at 7:23 PM
    Ace115
    Ace115 Well-Known Member
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    UPS delivered
  16. Apr 26, 2017 at 7:24 PM
    Misplaced Nebraskan
    Zach
    Austin
    interesting plate holder? What do you got going on there?
    Ak4T777[QUOTED] and Ace115 like this.
  17. Apr 26, 2017 at 7:24 PM
    Ace115
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    So I installed
  18. Apr 26, 2017 at 7:24 PM
    Misplaced Nebraskan
    Zach
    Austin
    Damn. Brown Santa was generous!
    Ace115[QUOTED] likes this.
  19. Apr 26, 2017 at 7:25 PM
    Ak4T777
    Kevin
    Holy crap! :drool: :bowdown:
  20. Apr 26, 2017 at 7:27 PM
    Ak4T777
    Kevin
    Gotta meet up with all these Tucson peeps someday. Seems like quite a few are on here. Truck looks great btw!
